Conopy glue
Old May 17th 04, 12:16 PM
Pete Reinhart
Default Conopy glue
All,
Advice needed
My canopy frame and caopy are beginning to disbond.
Need to know what to use to glu them back together.
Current thoughts a epoxy and flox, poluerthane cement, acrylic cement
(for plexiglas crack repair), and adhesive sealant like 3M 5200.
Ideas please. Nolaminar?, JJ?
Thanks!!!
Pete Reinhart
Austin, Texas
Old May 17th 04, 02:14 PM
JJ Sinclair
Yo Pete,
The big problem is your canopy wasn't sanded enough before it was glued on last
time. I mask it off and then sand the hell out of the 20 mm area where the
epoxy glue and cotton flox will be applied. I sand with 40 grit till all the
shiny is gone and then blow it off and glue her on. A few wood screws may be
necessary to keep it in place, but I remove them before the epoxy gets rock
hard.
If it is that loose, can you take it completely off and start over? If not, you
need to get some ruffage up there in between the glass and the frame. If that's
not possible, you can drill some holes and let the epoxy ooze out through these
holes. That might be enough to keep her down.
Mask everything off, its much easier than removing fingerprints etched in
epoxy.
JJ Sinclair
Glue question [email protected] Owning 1 December 6th 04 03:25 PM
Glue for wing step grippy thingies Steven Barnes Owning 6 November 28th 04 09:56 PM
Drywall Gussets Veeduber Home Built 5 October 27th 03 09:03 PM
Qn: Casein Glue recognition Vassilios Mazis Soaring 0 August 20th 03 10:00 PM
Glue Adair Home Built 3 July 18th 03 10:15 PM
