Interested in info on TE probe locations, type of probes etc for
install on a SGS 2-33. Probe location seems problematic on a 2-33. Would a diaphragm be a better choice? TIA |
At 14:36 20 May 2004, Rod Pool wrote:
Interested in info on TE probe locations, type of probes etc for install on a SGS 2-33... I'd recommend a homemade Nicks tube mounted with the pitot/static cluster on the top of the nose. It would be inexpensive, effective, and commensurate with the prevailing aesthetic of the aircraft. The angle of the factory pitot/static cluster means that you wouldn't need the 20-degree bend normally specified for the Nicks probe. Here are links to two related articles: http://www.soaridaho.com/Schreder/Co...ROBE_ANTENNA.h tml http://www.ssa.org/Johnson/89-1998-04.pdf You should be able to put the whole thing together for about three dollars in parts. Bob K. http://www.hpaircraft.com |
Follow-up probe ordered into June 'friendly-fire' hit | Otis Willie | Military Aviation | 0 | March 3rd 04 03:46 AM |
Whats that probe which sticks out of the aircraft nose? | Gangatharan | Products | 1 | February 12th 04 03:06 PM |
Cleaning a 3-way TE probe | Jack Glendening | Soaring | 37 | November 5th 03 06:45 PM |
Cleaning TE probe - is this a good idea ? | JJ Sinclair | Soaring | 1 | October 7th 03 02:30 PM |
Broken line to Oil Temperature Probe, Repairable? | rkane33 | Owning | 2 | July 25th 03 03:19 AM |
