A small experiment
Old May 21st 04, 10:30 PM
Mike Borgelt
Default A small experiment
Would anyone like to carry out the following experiment?
Upon touchdown on a sealed runway, close the brakes, don't use the
wheel brake and see how far the glider rolls.
If you feel like doing this please let me know the results and include
glider type, approximate weight, wind, altitude, temperature, slope.
I'm trying to find out the frictional forces acting on the glider on
the ground as part of the ongoing jet project. Some statistics would
be nice.
Thanks.
Progress seems to be rapid amongst the jet engine manufacturers in the
last few months with one 22Kg thrust engine available and two 25 Kg
engines in development including one with a really neat 11 stage axial
flow compressor.
I'm convinced these micro turbines are a breakthrough, disruptive
technology for soaring.
We have a small group in SE Queensland working on applying these
engines to gliders.
Mike Borgelt
Old May 21st 04, 10:34 PM
BTIZ
"Mike Borgelt" wrote in message
snip Would anyone like to carry out the following experiment? We have a
engines to gliders.
snip
I believe someone already did .. with the "Silent"
BT
Old May 21st 04, 10:48 PM
Marc Ramsey
You mean the "Not So Silent" 8^)
Marc
Old May 22nd 04, 12:12 AM
BTIZ
yes... I believe you can here it whine on the video..
BT
"Marc Ramsey" wrote in message
. com...
Marc
Old May 22nd 04, 05:12 AM
Leon McAtee
Mike Borgelt wrote in message . ..
flow compressor.
Mike Borgelt
Is there a web site where one could get an update?
I also think that small jets have lots of potential for self-launch
use but rather than increase the efficency of the small turbines with
multi stage compressors (fuel use is rather unimportant IMHO)I'd like
to see one of the micro turbine manufactures develop a high bypass
version. What we need for glider use is higher mass flow at low
speeds.
Leon McAtee
Old May 24th 04, 12:32 AM
Mike Borgelt
On 21 May 2004 21:12:14 -0700, (Leon McAtee)
flow compressor.
Mike Borgelt
If you go to
www.airtoi.com and click on the turbine specs you will
get to most of the known manufacturers.
Also check www.nybro.com.au for the axial compressor.
Also www.jet-rpm.com
speeds.
Not necessarily. Higher thrust for the same fuel consumption isn't bad
either.
The turbofan is likely much more complicated and expensive. Most
turbofans are two shaft engines which basically means one engine built
inside the other or an aft fan/turbine(see the original Whittle
inventions).
Fuel consumption is OK for our use as is and turbojets have a slower
drop off in thrust with airspeed.
I'm aware of the jet Silent but it isn't that relevant as it is a
lightweight glider. Our interest is in retrofits of existing 15/18m
motorless sailplanes.
Towing to measure the drag forces on the ground will be done by
members of the group.
Measuring ground roll is actually very neat and elegant as the drag
forces are integrated over the length of roll.
As for regulatory requirements in the US and Australia we have
Experimental Air racing/exhibition.
There is a Caproni A21(non powered) jet conversion project going on in
Australia already. I saw it fly a couple of years ago. This has a
single engine similar to the one in the A21SJ but an allegedly
improved installation. I have some time in the original Caproni built
jet.
I've heard the small turbines run and they aren't that bad, confirmed
by consulting some of the model airplane jet people.
The crash loads design the mount for the engines but unlike propellor
motor gliders the moments are low and the crash loads are only about
twice the normal thrust loads. The sort of structural margin you would
need anyway.
That should answer most of the point raised.
Thanks for the roll data so far.
Mike Borgelt
Old May 26th 04, 05:01 AM
bsquared
See www.silentwingsairshows.com. I saw it fly at Turf. Wasn't a really
impressive climb rate, but it did climb.
"BTIZ" wrote in message
news:_Burc.5849$7y5.5751@fed1read03...
engines to gliders.
snip
BT
Old May 27th 04, 04:59 PM
Michael Stringfellow
This would probably be easy to measure with a spring balance and a tow rope.
The forces you need once airborne can readily be calculated - for instance,
an 800 pound glider with a 40:1 L/D has 20 pounds of drag. If you assume
this increases 50% with a deployed engine, this increases to 30 pounds of
drag. So a single engine with 40 to 45 pounds of thrust would probably be a
minimal sustainer. Two such engines would give you a climb rate in the
hundred feet a minute range.
Watching the jet-powered Silent on its recent visit to Arizona, the problem
appeared to be more the energy needed to accelerate and climb with the
glider's mass than to overcome friction. (The noise wasn't objectionable,
by the way. Certainly nothing like a pulse jet!)
On the other hand, I know of a Nimbus 3DM that operates from a grass strip
and sometimes uses auto tow to get it airborne to reduce the take-off roll,
so friction on the ground is not negligible.
Mike ASW 20 WA
be nice.
Thanks.
flow compressor.
engines to gliders.
Mike Borgelt
Old May 28th 04, 09:00 AM
Mike Borgelt
On Thu, 27 May 2004 08:59:42 -0700, "Michael Stringfellow"
We'll do that too but getting a steady reading on rough ground will
likely be difficult.
Performance calculations for jet are pretty straightforward even
including the effect of thrust fall off with increasing airspeed. You
can calculate that from the mass flow of the engine and sea level
thrust.
The Silent has a max gross of 640 lbs according to their website. It
also is only a 31:1 glider. Jets have the interesting characteristic
that the power available increases with airspeed. Unlike propellor
aircraft the best rate of climb speed occurs at relatively high speed
which favors gliders with good performance at high speed.
With two 55lb thrust engines(which are going to be available soon) a
900lb glider will have a sea level climb rate of around 650 feet/min-
at 80 to 100 knots IAS. The takeoff run will be the big issue and the
rolling friction will play a large part in this. Preliminary estimates
are that it won't be all bad and will meet JAR22 in this regard. It
will also have single engine climb capability.
What altitude above sea level and what temperature when you saw the
Silent fly?
Having owned one of them and operated off a sealed strip at 2100 feet
on warm days I can say it has no problem. At 5000AMSL it was
considerably less good. At high altiude on grass I can see the
problem.
Mike
Old June 1st 04, 08:36 PM
Robert Ehrlich
If I do that with any glider in my club, it will become airborne
again when I close the brakes.
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! Small Blue Planet Toys Aviation Marketplace 0 October 15th 03 05:26 PM
Air Force announces small diameter bomb contract award Otis Willie Military Aviation 0 October 9th 03 09:52 PM
Air Force announces winner in Small Diameter Bomb competition Otis Willie Military Aviation 0 August 30th 03 03:06 AM
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble Small Blue Planet Toys Aviation Marketplace 0 July 11th 03 04:00 PM
HUGE Summer SALE + Free Shipping @ Small Blue Planet Toys Small Blue Planet Toys Aviation Marketplace 0 July 8th 03 11:53 PM
