Retrofit ASW-19 CG hook?
Old May 31st 04, 08:31 PM
F.L. Whiteley
Default Retrofit ASW-19 CG hook?
If an ASW-19 were supplied originally with only a nose hook, how difficult
to add a CG hook?
TIA,
Frank Whiteley
Colorado
Old June 1st 04, 01:15 AM
Duane Eisenbeiss
"F.L. Whiteley" wrote in message
to add a CG hook?
Some ASW-19s came with a CG hook. Have you removed the seatpan and looked
to see if the mounting structure is already there? Perhaps all that would
be required is to cut a small hole in the skin and mount a towhook.
Old June 1st 04, 01:40 AM
F.L. Whiteley
"Duane Eisenbeiss" wrote in message
news:YUPuc.26745$4A6.26021@attbi_s52...
difficult
to add a CG hook?
Since I don't own one, that's the salient point.
Frank
Old June 1st 04, 07:17 AM
Chris Rollings
Frank,
So far as I recall, the nose hook came as a later mod
on the ASW 19. I would be surprised if any left the
factory without a C of G hook.
Chris Rollings
hook, how difficult
to add a CG hook?
TIA,
Frank Whiteley
Colorado
Old June 1st 04, 01:41 PM
F.L. Whiteley
The factory apparently made it optional. Some in the US don't have the CG
hook. Now I'm wondering if any in the US lack the nose hook. IIRC, the
nose hook can be retro-fitted? Didn't the LBA require this at some point?
Frank
"Chris Rollings" wrote in message
Frank,
Chris Rollings
hook, how difficult
to add a CG hook?
TIA,
Frank Whiteley
Colorado
Old June 1st 04, 01:59 PM
F.L. Whiteley
nose hook can be retro-fitted? IIRC, the LBA required this at some point of
many gliders, including presumably the ASW19?
Frank
Frank,
Chris Rollings
hook, how difficult
to add a CG hook?
TIA,
Frank Whiteley
Colorado
Old June 1st 04, 02:13 PM
Andy Durbin
"F.L. Whiteley" wrote in message ...
to add a CG hook?
TIA,
Frank Whiteley
Colorado
I have a 19b with only a CG hook. I will exchange digital photos of
the installation if you have the forward hook.
My hook is described as:
Sicherheitskupplung Europa G 73
Werk-Nr 48208
Kennblatt-Nr 60.230/2
Andy
(my email address is valid)
Old June 1st 04, 02:21 PM
Ray Lovinggood
Frank,
A friend's ASW-19 does NOT have a nose hook, only the
CG hook. I don't know if it is a 'B' model, but I
think it is. I do know his first couple of takeoffs
in the 19 was his first time to experience a tow with
a CG hook. The takeoffs were a bit exciting.
(Is there a way to easily distinguish a 'B' model
from the previous version, other than looking at the
assorted paperwork?)
Ray Lovinggood
Carrboro, North Carolina, USA
this at some point?
Frank
'Chris Rollings' wrote in message
Frank,
mod
Chris Rollings
nose
hook, how difficult
to add a CG hook?
TIA,
Frank Whiteley
Colorado
Old June 1st 04, 02:55 PM
Hutnick
to add a CG hook?
TIA,
Frank Whiteley
Colorado
The factory produces a retrofit kit and drawings. It is available from
John Murray. It will locate a new tow hook between the front bulkhead
on the control stick and behind the rudder pedals. The kit is very
complete and is basically two wooden bulkheads, tow hook mounting
brackets, cables, pulleys and hardware for the tow release.
Old June 1st 04, 06:40 PM
F.L. Whiteley
"Hutnick" wrote in message
om...
difficult
to add a CG hook?
TIA,
Frank Whiteley
Colorado
John says nominally about $500 for parts. CG retrofit easier than nose
retrofit.
Frank
Tow Hook on Cessna 180 - Update Stuart Grant Soaring 13 April 10th 20 10:48 AM
Pull plane by tail hook Tarif Halabi Owning 19 February 24th 04 02:27 PM
Tow hook for a Cesna 185? Gary Boggs Soaring 4 February 13th 04 02:09 AM
Tow Hook on Cessna 180? Stuart Grant Soaring 3 October 2nd 03 12:50 AM
CG hook & Low Tow Ray Lovinggood Soaring 2 July 25th 03 06:20 AM
