#81
Marc or others,
As I've dug deeper into this subject, the issue of geometric altitude appears to be one of the true obstacles to the adoption of COTS units. Is there a public record anywhere of specifically what objections the "members of the IGC, or even GFAC" have raised? In doing just some basic research (along with the help of a major instrument manufacturer) it became pretty obvious that geometric altitude is the way to go at this stage. Regards, Erik Mann "Marc Ramsey" wrote in message . com... My is opinion is (and has been for years) that the IGC should switch over to using geometric altitude, which would allow use of GPS-derived altitude with appropriate error bars. But, my opinion is not that of the majority of members of the IGC, or even GFAC, at this point. Marc |
#82
Papa3 wrote:
Marc or others, As I've dug deeper into this subject, the issue of geometric altitude appears to be one of the true obstacles to the adoption of COTS units. Is there a public record anywhere of specifically what objections the "members of the IGC, or even GFAC" have raised? In doing just some basic research (along with the help of a major instrument manufacturer) it became pretty obvious that geometric altitude is the way to go at this stage. Regards, Erik Mann "Marc Ramsey" wrote in message . com... My is opinion is (and has been for years) that the IGC should switch over to using geometric altitude, which would allow use of GPS-derived altitude with appropriate error bars. But, my opinion is not that of the majority of members of the IGC, or even GFAC, at this point. Marc Suppose that one switches to "geometric altitude". What about people who used to document their flights with barogaphs? Here all clubs have barographs and lend them to the pilots when necessary. Hence the cost is nil, which is certainly cheaper than the cheapest GPS. -- Michel TALON |
#83
![]() So far you seemed to be the most competent in the GFAC team, who else think different than you and what are the reasons behind such an opinion? Can we involve him/her in this open discussion? Maybe that member should visit an average club and see how these barographs and barograms are treated... /Janos Marc Ramsey wrote My is opinion is (and has been for years) that the IGC should switch over to using geometric altitude, which would allow use of GPS-derived altitude with appropriate error bars. But, my opinion is not that of the majority of members of the IGC, or even GFAC, at this point. |
#84
Michael,
Good point. I'll add it to the list of "issues to be resolved". My gut is that for Silver/Gold badge flights a barogram could be an acceptable means of altitude verification in combination with camera (if distance is involved), as long as that method of validation continues to be supported by the IGC. In terms of the cost being "nil", at some point the barograph has to be sent to an approved facility for recalibration, no? Around here, that sets us back around $40. So, there is a recurring cost, whereas the GPS cost is a one-time event. P3 "Michel Talon" wrote in message ... Papa3 wrote: Marc or others, As I've dug deeper into this subject, the issue of geometric altitude appears to be one of the true obstacles to the adoption of COTS units. Is there a public record anywhere of specifically what objections the "members of the IGC, or even GFAC" have raised? In doing just some basic research (along with the help of a major instrument manufacturer) it became pretty obvious that geometric altitude is the way to go at this stage. Regards, Erik Mann "Marc Ramsey" wrote in message . com... My is opinion is (and has been for years) that the IGC should switch over to using geometric altitude, which would allow use of GPS-derived altitude with appropriate error bars. But, my opinion is not that of the majority of members of the IGC, or even GFAC, at this point. Marc Suppose that one switches to "geometric altitude". What about people who used to document their flights with barogaphs? Here all clubs have barographs and lend them to the pilots when necessary. Hence the cost is nil, which is certainly cheaper than the cheapest GPS. -- Michel TALON |
#85
Marc Ramsey wrote:
Graeme Cant wrote: I've heard no reason whatsoever why a GPS in a lunchbox is any different from a sealed barograph. Of course it would be possible. So I'm puzzled why it doesn't happen. My guess is it's as much to do with WHO's telling me it can't be done as it is to WHY. You are focused on imagined draconian security requirements (which are actually rather minimal for badge-only flight recorders), and glossing over the major objection. It only takes a few small requirements to make an OTS recorder unusable for soaring. I see the aim as being to be able to use OTS equipment straight out of the box. Some years ago in Oz, protectionist car "safety" requirements for IIRC only tail lights and wipers made the importation of most European cars almost impossible. It doesn't take much to stymie things. ...snip... My opinion is (and has been for years) that the IGC should switch over to using geometric altitude, which would allow use of GPS-derived altitude with appropriate error bars. But, my opinion is not that of the majority of members of the IGC, or even GFAC, at this point. Yes, Marc, I picked up your opinion earlier - and its loneliness! So, next question, WHY don't the majority accept the change? Wide use of OTS recorders would be enormously useful to gliding. I can't see any technical objection to a parallel altitude standard being available for badges and comps. I can see there may be a comparability problem for records but that could be worked on after a geometric standard was established and in use. That's why I'm getting curious about the politics of these organisations. As Sherlock Holmes said - when all other explanations are eliminated, what remains is the truth. There has to be a political problem because the technical ones commonly turn out to be actually willpower. Graeme. |
#86
Michel Talon wrote:
Suppose that one switches to "geometric altitude". What about people who used to document their flights with barogaphs? Here all clubs have barographs and lend them to the pilots when necessary. Hence the cost is nil, which is certainly cheaper than the cheapest GPS. Have a parallel standard. Use whichever you want. You just have to use the same one throughout the flight (to state the obvious, I guess). I see no problem with badge flights since they're not compared to other flights which might use the other standard. Graeme. |
#87
Janos Bauer wrote:
So far you seemed to be the most competent in the GFAC team, It has nothing to do with competence. I agree with some of your opinions, others do not. who else think different than you and what are the reasons behind such an opinion? Tradition is a big factor. The perceived (but not adequately studied, in my opinion) inaccuracy of GPS altitude is another. Can we involve him/her in this open discussion? Maybe that member should visit an average club and see how these barographs and barograms are treated... It doesn't matter how they are treated, as long as they can be successfully calibrated within the set interval. The corrected pressure altitudes taken from a barogram may be off by a hundred feet or so, but they still provide a more accurate measurement of the precise form of altitude required by the current IGC rules, than any COTS GPS. Marc |
#88
Marc Ramsey wrote:
Janos Bauer wrote: So far you seemed to be the most competent in the GFAC team, It has nothing to do with competence. I agree with some of your opinions, others do not. I mean, you usually aware of the technical background (security, GPS issues, etc-etc). On the other hand you often refuse certain suggestions referring to existing rules and not to technical problems. who else think different than you and what are the reasons behind such an opinion? Tradition is a big factor. The perceived (but not adequately studied, in my opinion) inaccuracy of GPS altitude is another. I also haven't really studied it but last Sunday it was the second time when I had to fly xc without variometer and I was happy with the simple GPS (no WAAS etc.) based palm&soaringpilot combo. I think it would be impossible if there was really huge error (bigger than on those 20 year old barographs). Can we involve him/her in this open discussion? Maybe that member should visit an average club and see how these barographs and barograms are treated... It doesn't matter how they are treated, as long as they can be successfully calibrated within the set interval. The corrected pressure altitudes taken from a barogram may be off by a hundred feet or so, but they still provide a more accurate measurement of the precise form of altitude required by the current IGC rules, than any COTS GPS. I don't think they are calibrated for all the temperatures. I don't think all the mechanical impacts can be handled by calibration (I myself (saw others do it few times) locked out the needle of one old smoky barograph and we had to bent it back to working position, how do you handle such an "impact"?) And the most important issue, what I stated befo neither barographs nor cameras are sealed by OO on most of the places I visited... No one wants to cheat with them, it's just the way things going on some (maybe most) places. /Janos |
#89
Janos Bauer wrote:
Marc Ramsey wrote: It has nothing to do with competence. I agree with some of your opinions, others do not. I mean, you usually aware of the technical background (security, GPS issues, etc-etc). On the other hand you often refuse certain suggestions referring to existing rules and not to technical problems. So, I must not be truly competent 8^) Tradition is a big factor. The perceived (but not adequately studied, in my opinion) inaccuracy of GPS altitude is another. I also haven't really studied it but last Sunday it was the second time when I had to fly xc without variometer and I was happy with the simple GPS (no WAAS etc.) based palm&soaringpilot combo. I think it would be impossible if there was really huge error (bigger than on those 20 year old barographs). You are comparing apples to oranges. GPS measures geometric altitude with a typical error of, say, +/- 50 feet. Barographs measure calibrated pressure altitude with a typical error of, say, +/- 50 feet. GPS altitude can not be corrected to pressure altitude with reasonable error bounds, unless specific meteorological data is provided for the time and place of the flight. Pressure altitude can not be corrected to geometric altitude with reasonable error bounds, unless specific meteorological data is provided for the time and place of the flight. Without making these meteorological corrections, geometric and calibrated pressure altitude can differ by as much as 1000 feet for a Diamond altitude gain. It doesn't matter how they are treated, as long as they can be successfully calibrated within the set interval. The corrected pressure altitudes taken from a barogram may be off by a hundred feet or so, but they still provide a more accurate measurement of the precise form of altitude required by the current IGC rules, than any COTS GPS. I don't think they are calibrated for all the temperatures. There is no requirement that barographs be corrected for temperature. I don't think all the mechanical impacts can be handled by calibration (I myself (saw others do it few times) locked out the needle of one old smoky barograph and we had to bent it back to working position, how do you handle such an "impact"?) That barograph should have been marked as potentially faulty. An OO, if aware of this, should refuse to certify a flight using it until it is repaired and recalibrated. And the most important issue, what I stated befo neither barographs nor cameras are sealed by OO on most of the places I visited... The Sporting Code requires sealing the barograph, but not necessarily the cameras (SC3 4.6.3, 4.7.2). If an OO is unable to follow these simple rules, how likely is it that he/she will follow the more technically complex procedures that might be required for a COTS GPS? No one wants to cheat with them, it's just the way things going on some (maybe most) places. I've seen similar things. Given this, the obvious solution would be to award badges using the honor system. If this is not acceptable, then some level of procedural and/or technical security measures must be in the rules (even if some do not follow them). How much security is enough? Marc |
#90
Marc Ramsey wrote:
You are comparing apples to oranges. GPS measures geometric altitude with a typical error of, say, +/- 50 feet. Barographs measure calibrated pressure altitude with a typical error of, say, +/- 50 feet. GPS altitude can not be corrected to pressure altitude with reasonable error bounds, unless specific meteorological data is provided for the time and place of the flight. Pressure altitude can not be corrected to geometric altitude with reasonable error bounds, unless specific meteorological data is provided for the time and place of the flight. Without making these meteorological corrections, geometric and calibrated pressure altitude can differ by as much as 1000 feet for a Diamond altitude gain. The whole altitude task is about the ability to gain certain amount of energy from air (thermal, wave, something else). For me it's a geometric issue. If someone is able to get from A to B and the altitude difference is more than X than it's fine. Not the air pressure at that altitude qualifies the pilot. You already agree with it so what do we argue about? ![]() I don't think they are calibrated for all the temperatures. There is no requirement that barographs be corrected for temperature. Hmm, those thin metal plates and other small parts could behave quite differently at +40C than -40C (typical wave temperature at my country). That barograph should have been marked as potentially faulty. An OO, if aware of this, should refuse to certify a flight using it until it is repaired and recalibrated. Should. And the most important issue, what I stated befo neither barographs nor cameras are sealed by OO on most of the places I visited... The Sporting Code requires sealing the barograph, but not necessarily the cameras (SC3 4.6.3, 4.7.2). If an OO is unable to follow these simple rules, how likely is it that he/she will follow the more technically complex procedures that might be required for a COTS GPS? No they won't. No one wants to cheat with them, it's just the way things going on some (maybe most) places. I've seen similar things. Given this, the obvious solution would be to award badges using the honor system. If this is not acceptable, then some level of procedural and/or technical security measures must be in the rules (even if some do not follow them). How much security is enough? I would accept any trace file and a sign from the OO. Yes, from the same OO who doesn't seal the barograph. It's the same level of security as the current barograph+photo process. /Janos |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
