Notes from a Small Island - 1015K in UK.
Old June 30th 04, 01:50 AM
Tom Serkowski
Hm,I just started using gliderpilot.net instead of google
to view RAS.Looks like it strips all line breaks and decided to
post my message more than once.-Tom
Tom Serkowski
ASH-26E
To email me, place '@' after Tom, and append '.com'
Old June 30th 04, 08:48 AM
Bruce Greeff
No speculation.
After such a long flight, having been cooled by the high altitude the chances
that the battery would be able to crank the pylon up is remote. (It should be at
full nominal charge as it is charged in flight by a generator)
If it did extend, the chances that there would be enough power available spin a
two stroke engine at well below freezing point, fast enough to start is even
more remote.
Then you have fuel that may have gelled at low temperature, and the probability
of carburettor icing.
I don't think there is much speculation. The chances of starting your engine
under these circumstances must be almost zero.
Bruce
Alan Irving wrote:
Speculation on whose part? I'm merely reporting what
Ohlmann himself said. Perhaps he was speculating that
the engine wouldn't start after spending 15 hours at
sub zero temperatures - do you actually think it would?
Seeing how meticulous he was in all other facets of
his preparation, I imagine he might have tried the
motor during a local flight to confirm that it wouldn't
start. But that's just speculation...
At 15:12 28 June 2004, Andrew Henderson wrote:
That's speculation, and the record whilst a magnificent
flight is not the same as one without an engine.
Are you saying that in all of Klaus's previous practise
flights at these heights he never started the engine
to get home because the flight 'wasn't on'? I think
not.
Andy Henderson
At 14:18 28 June 2004, Alan Irving wrote:
When Klaus Ohlmann talked about his Argentinian record
flights at the BGA conference a few years back, I believe
he said that having spent all day at 20,000+ feet the
engine in the Stemme would be highly unlikely to start.
Hence there is no more 'opt out' than if the flight
had been done in a pure sailplane, and the aachievement
is no less valid.
Old June 30th 04, 05:24 PM
tango4
To play devils advocate for a moment .....
No one is going to start the engine at 20000' and minus 25 degrees C. Its
started at 2000' agl and in Argentina the temperature may be 30 degrees or
more at that altitude. I'll give you that it might take a while for the
engine to warm up to that temperature but would a pilot fly all the way down
without starting to employ energy/height saving measures
Generally two stroke engines don't have crankcases full of oil, lubrication
being acheived by the fuel oil mixture.
If it's a turbo it doesn't need cranking, it windmill starts and the
ignition is magneto's - no battery needed.
The Stemme uses a 4 stroke powerplant I think.
Ian
"Bruce Greeff" wrote in message
No speculation.
chances
be at
spin a
even
more remote.
probability
engine
Bruce
not.
Andy Henderson
is no less valid.
Old June 30th 04, 06:44 PM
Bruce Greeff
Ian
No speculation.
chances
be at
spin a
even
more remote.
probability
engine
Bruce
not.
Andy Henderson
is no less valid.
Hi Ian
Comment based on information provided by Stemmme among others, where they
commented that they had to leave the engine overnight to warm up before it was
warm enough to start without fear of damage. This on some of the record flights
they were involved in.
Similarly any oil has a temperature range in which it works as specified. After
a good long cold soak, I doubt the short descent to 2000 AGL will significantly
warm the engine or the fuel/oil mix. Not only because of time, but because much
of the ground in the Andes is well over 10,000 MSL, so you are unlikely to be
getting the balmy plains temperatures when you are in trouble in the mountains.
Look at some of the videos, they show snow as far as the eye can see, in most
directions for much of the flight.
The Solo used in the Nimbus is not a turbo, so needs battery power to start.
The first obstacle is probably enough to make the starting issue moot. Very cold
batteries simply do not deliver much power. I doubt you could get the jackscrew
to crank the pylon up...
Old June 30th 04, 10:02 PM
Mike Lindsay
Incidentally, am I right in thinking that a Bocian held one of the
world women's two-seater records before they were abolished? Free
distance, perhaps?
Ian
What!! Women have been abolished???
Mike Lindsay
Old July 1st 04, 04:09 AM
Tom Serkowski
Tom Serkowski
ASH-26E
Old July 1st 04, 12:29 PM
Graeme Cant
I'd be interested in the windmill start procedure for a Stemme.
....and with NO battery?
Graeme Cant
  #29
Old July 1st 04, 04:21 PM
Martin Gregorie
On Thu, 01 Jul 2004 21:29:23 +1000, Graeme Cant
Don't forget all the bits that slide and open, like the nose cone and
vents, before you can start a Stemme. Cold-soak all that grease for a
few hours and then I bet you'd struggle to expose the prop and open
the air intakes, let alone get a start.
Just a thought.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
  #30
Old July 1st 04, 07:48 PM
Ian Johnston
On Wed, 30 Jun 2004 21:02:30 UTC, Mike Lindsay
: Incidentally, am I right in thinking that a Bocian held one of the
: world women's two-seater records before they were abolished? Free
: distance, perhaps?
: What!! Women have been abolished???
No, silly. Bocians.
Ian
Small Aircraft Transportation System (SATS) first practical trial Larry Dighera Piloting 0 November 27th 03 03:11 PM
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! Small Blue Planet Toys Aviation Marketplace 0 October 15th 03 05:26 PM
Air Force announces small diameter bomb contract award Otis Willie Military Aviation 0 October 9th 03 09:52 PM
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble Small Blue Planet Toys Aviation Marketplace 0 July 11th 03 04:00 PM
HUGE Summer SALE + Free Shipping @ Small Blue Planet Toys Small Blue Planet Toys Aviation Marketplace 0 July 8th 03 11:53 PM
