Doing a electronic declaration for a 300/500k cross country flight is
it possible to have the starting point be "Release from Tow" or does that require a written declaration. I use the 302. |
Hal wrote:
Doing a electronic declaration for a 300/500k cross country flight is it possible to have the starting point be "Release from Tow" or does that require a written declaration. Yes, the release point can be the start point, no written declaration is required, as the release point will be documented by the flight recorder (remember to notch, or make a tight 360 degree turn, and also make sure you don't release so high as to run afoul of the loss of height rules). Note, however, if you are attempting a triangle or out/return for Diamond goal, your start and finish points must coincide, which can be most easily accomplished by either releasing directly over the airport, or electronically declaring the same waypoint as start and finish. Marc |
| Fiberglass release agent? | [email protected] | Home Built | 14 | July 9th 04 11:26 PM |
| Fiberglass / Mold release advice requested | Mark Zivley | Home Built | 10 | April 3rd 04 12:15 AM |
| Air Force Museum Working Group to release final report | Otis Willie | Military Aviation | 0 | November 18th 03 01:28 AM |
| ANN: flyWithCE news release - November 2003 | Uros Podlogar | Soaring | 0 | November 16th 03 10:23 AM |
| XCSOAR Next Release?? | Michael Pitoniak | Soaring | 0 | August 4th 03 01:30 AM |
