Being perverse, I should say that the FIA only do motor
racing. You want http://www.fai.org/sporting_code/sc3_2003.pdf Rule 1.4.3d (i) and 1.4.3d (ii) apply for 1000k records, see also the definition of CLOSED COURSE 1.1.15. Such a course is okay for distance records, 3.1.41 implies that it's also good for speed records. However, if you are after a 1000k diploma rather than a record, any 1000k course with 1,2 or 3 pre declared turnpoints, at least 10km apart, rounded in any order, would do (1.4.5b). At 20:36 05 August 2004, Tim Taylor wrote: Can someone point me to the rules for setting up a 1000k FIA legal triangle with the start at or near the midpoint of a leg. I know I have seen it, but can't find it. Thanks, Tim |
Andrew,
Thanks, that was the section I was looking for. I am looking at doing the 1000k diploma, but also want to insure it was Hilton Cup legal as well. And yes my fingers are dyslectic at times when typing ;-). Tim Andrew Warbrick wrote in message ... Being perverse, I should say that the FIA only do motor racing. You want http://www.fai.org/sporting_code/sc3_2003.pdf Rule 1.4.3d (i) and 1.4.3d (ii) apply for 1000k records, see also the definition of CLOSED COURSE 1.1.15. Such a course is okay for distance records, 3.1.41 implies that it's also good for speed records. However, if you are after a 1000k diploma rather than a record, any 1000k course with 1,2 or 3 pre declared turnpoints, at least 10km apart, rounded in any order, would do (1.4.5b). At 20:36 05 August 2004, Tim Taylor wrote: Can someone point me to the rules for setting up a 1000k FIA legal triangle with the start at or near the midpoint of a leg. I know I have seen it, but can't find it. Thanks, Tim |
Are there any altitude restrictions at start or on course and at landing?
Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 05:35 PM |
FLASH! U.S.A. Rules Committee to Address Rules Complexity? | SoarPoint | Soaring | 1 | February 3rd 04 02:36 AM |
New SRA Site - New 2003 Rules Minutes and 2004 Rules Summary | Ken Kochanski | Soaring | 0 | December 17th 03 03:38 AM |
Start Anywhere Cylinder (SSA rules proposal) | Mark Navarre | Soaring | 15 | September 25th 03 01:13 PM |
Safety Rules | Pat Russell | Soaring | 3 | September 20th 03 02:58 PM |
