Pocket Nav NMEA sentences
Old August 16th 04, 02:59 AM
George B.
Default Pocket Nav NMEA sentences
I'm trying to get a Compaq Aero 1530 with PocketNav to receive NMEA
output from a Colibri logger so that it can display the moving map.
When I tried it for the first time in flight the PocketNav message was
"No NMEA Data" and it went into simulator mode. Can anyone tell me
what sentences to select in the Colibri's setup menu in order to get
this to work?
....George B.
Old August 20th 04, 09:53 PM
For Example John Smith
Try this (..from memory, email me if this doesn't work and I'll get the
actual devices and walk you through it)--
*before connecting the devices, go to the "make a new connection" page and
set one up--call it whatever you like, don't change any defaults
*physically connect the two devices
*tap the icon for the new connection you just created, say yes/ok to the
windows that come up
*tap the keyboard
*type NMEAenter data should start scrolling on your 1530 screen
*close the connection. Don't worry, the Colibri won't know you closed it
and will keep spewing data
*Open PocketNav
Brent
"George B." wrote in message
om...
this to work?
...George B.
Old August 23rd 04, 01:42 PM
Paul Remde
Hi George,
I'm sorry for the delay getting an answer to your question. I sell and
support Glide Navigator II which is the latest version of what was
Pocket-NAV. I forwarded your question to Chip Garner (GN II author) and his
response is below.
"GPRMC message for location, GPGGA if possible, this gives the GPS altitude
and allows differential final glide altitude."
You may want to consider getting Glide Navigator II as there a several nice
new features added since the days of Pocket-NAV such as the highlighting of
reachable airports on the map screen.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
om...
this to work?
...George B.
Old August 23rd 04, 03:53 PM
Eric Greenwell
Paul Remde wrote:
Hi George,
response is below.
And "Mark point"!
Eric Greenwell
Washington State
USA
Pocket PC GPS software. R.T. Owning 5 November 7th 04 01:18 AM
10,554+ NMEA-0183 Sentences Bob Carter Products 0 April 9th 04 07:44 PM
Garmin 196 NMEA *input* David Megginson Piloting 1 December 7th 03 02:47 AM
WingX for the Pocket PC - Version 1.2 Hilton Software LLC Products 1 October 17th 03 01:38 PM
WinPilot Now Supports Ipaqs with Pocket PC 2003 Ipaqs 2200, 5510, 5400, 5500 Series. rhpf Soaring 0 August 15th 03 01:21 AM
