Performance World Class design proposal
Old August 28th 04, 06:34 PM
iPilot
I don't believe that monoclass as a principle has failed. It is PW-5 which
failed. And it failed because it doesn't stand the competition on glider
market.
"Andreas Maurer" wrote in message
On Sat, 28 Aug 2004 02:06:58 GMT, "Gldcomp"
Applied to Soaring, where a possible "Olympic Class" may still happen one
day, the L/D DOES NOT MATTER.
As it happens with other olympic equipment, the design has to be made
PUBLIC
and available to a central organizing body.
It has to be manufacturable in any part of the world at a reasonable
cost.
External shapes and CGs have to be ABSOLUTELY the same.
... which is unfortunately precisely the concept that already failed
with the PW-5.
Bye
Andreas
  #33
Old August 29th 04, 12:35 AM
Ian Strachan
In article , iPilot
writes
Racing with PW-5's on Olympics is more like racing with Optimist class of
sailboats. We're working to get the Laser done. Or at least Dragon.
How about the IGC Club Class, which already exists and can embrace the
soaring equivalent of Optimist, Dragon and Laser because it is not just
"one design" but compensates over a small performance bracket by
handicapping according to glider performance. You can certainly have a
viable IGC Club Class competition with PW5, Russia, K6, Skylarks and
gliders of similar performance. The organisers simply set the
performance bracket a bit lower than is normally done for Club Class
competitions (which rather sums up why the PW5 has not caught the
imagination of the world gliding movement).
It would appear that the world gliding movement is either too small or
too fragmented to embrace a successful one-design class. It might have
succeeded in the 1940 Olympics (which did not happen for obvious
reasons) with Hans Jacobs' great design, the Meise (also known as the
Olympia), but things have moved on since then. The Standard Class of
the 1950s was a great step forward in making gliders of reasonable cost
viable in competition up to the world level. It also spawned that fine
design the K6 and others. But it did not attempt to be a one-design
class and maybe that is why not only succeeded but is still with us
today. Is there a moral here that we should heed?
Ian Strachan
Lasham Gliding Centre
  #34
Old August 29th 04, 04:38 PM
iPilot
Club Class will never make it to Olympics becuse of the coeficent system and
the fact that technical differences can still make the difference.
"Ian Strachan" wrote in message
In article , iPilot
writes
Ian Strachan
  #35
Old August 30th 04, 08:01 AM
Gldcomp
"iPilot" wrote in message
and
Correct.
Nothing in the olympics has any form of handicapping because it has to be a
strictly athlete agains athlete kind of thing.
A simple handicap system like the German will benefit some gliders in weak
weather and others in strong weather.
Certain Handicaps systems, such as the Brazilian one, do compensate for the
effects of weather by applying a "Thermal Index" to the final handicap,
which is extracted from the first glider to complete the task.
But it still is nearly impossible to compensate for longer wingspans having
the freedom to search for the strongest thermals while the "short wings"
have to take more thermal, including weak ones.
In other words, no Handicap system is perfect and they do not work with
olympic sports.
  #36
Old August 30th 04, 08:46 AM
Bert Willing
I think that's a theoretical discussion.
The biggest market for sailplanes is in Europe, and it's exactly there where
the idea of a monoclass or a PW5 doesn't interest anybody - at least nobody
who has money to put on the table (be it private owners or clusbs).
Soaring in the rest of the world is just not big enough that anybody could
make a decent living by making monoclass gliders.
And in these conditions, talking about an Olympic Class with an event every
4 years ?! ...
Bert Willing
ASW20 "TW"
"iPilot" a écrit dans le message de
market.
one
PUBLIC
cost.
with the PW-5.
Bye
Andreas
  #37
Old August 30th 04, 11:49 AM
iPilot
Gerhard. You should look at the Bob's webpage (www.hpaircraft.com) about the work he's doing on HP
24. I personally know a person wh's self educated in aerodynamics and who's building a modern
version of the Horten 3 (different seating position, different profiles, stiffer construction) and
there's and Australian (or NZ?) group of people who are building a short-tailed glider. All of them
are amateurs and afaik, none of them is learned aerodynamics in school.
About the Performance World Class. If the outer shape of the glider is defined precisely enough,
anyone can build a copy without aerodynamical analysis - only construction has to be engineered.
Regards,
Kaido
"Gerhard Wesp" wrote in message ...
Bob Kuykendall wrote:
Eric, you know I disagree that these are huge expenses. I continue to
believe that with modern softwares, and using modern
commercially-available composite products, that sailplane development
is within the grasp of a conscientious amateur.
I disagree. IMHO, sailplane development is an extremely complex task
far out of reach of anybody without some very sound aeronautical
engineering education. And not only that, it also requires a good deal
of experience---read: your first design will not necessarily be the best
one. :-)
That said, I'm open to be proven wrong by counter-examples. Anybody
knows any?
Cheers
-Gerhard
  #38
Old August 30th 04, 02:23 PM
iPilot
Once more. The reason, why PW5 failed was the fact that it's performance per money spent was dismal.
But the fact that it still got sold somewhat, talks that there is an interest towards monoclass.
If, for example we declare LS-4 a monoclass it'd have a huge number of gliders available already on
the market plus additional production.
And when it's good for a FINN sailor to buy a $20 000 boat for a one competition in 4 years, why it
shall be bad for a LS-4 pilot. National pride is going to open many currently closed pockets forl
gliding.
"Bert Willing" wrote in message
4 years ?! ...
Bert Willing
ASW20 "TW"
market.
one
PUBLIC
cost.
with the PW-5.
Bye
Andreas
  #39
Old August 30th 04, 03:45 PM
Ian Strachan
In article , Gldcomp
writes
OK, if that is so, it's probably the Standard and/or 15 metre class, if
the IGC want to try and get into the Olympics in the future.
The main barrier to new sports getting in seems to be the Olympic
organisation itself. I understand that the President and General
Secretary of FAI have made presentations about air sports to IOC
meetings, particularly on parachuting. The International Parachuting
Commission of FAI have wanted to get into the Olympics for some years
now.
Ian Strachan
UK
  #40
Old August 30th 04, 07:50 PM
Robert Ehrlich
Another difference with the Laser is that, as far as I remember, it was not
designed for Olympics, just as a modern sailboat with good performance and
state of the art design operated by a single person. The success of the design
later made it an Olympic class, not the opposite.
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Region 7 contest attracts former Open Class World Champion Rich Carlson Soaring 2 May 14th 04 06:04 AM
World Class: Recent Great News Charles Yeates Soaring 58 March 19th 04 06:58 PM
