FAI Sporting Code Section 3 experts wanted
Old August 29th 04, 01:28 AM
Stewart Kissel
Default FAI Sporting Code Section 3 experts wanted
I googled this and could not find an answer...and I
reread the Code last night...so forgive my denseness...but
I cannot figure out---
For a distance task with 3 TP's and no Start Point
or Finish Point declared...does the release from tow
have to be the start or can it be declared post flight?
If so does the 1,000 meter tow penalty still take
effect?
The finish point can be declared afterward? It does
not have to be the landing? And the 1,000 meter difference
between start and finish is calculated from the post-flight
start and finishes?
Old August 29th 04, 01:50 AM
Marc Ramsey
effect?
start and finishes?
You can't post-declare start or finish points for a distance task. If
you want a start point other than the point of release, or a finish
point other than the point of landing, you need to declare them before
flight, along with the turnpoints. The 1000 meter allowance is between
the start point altitude and finish point altitude, so if neither start
nor finish is declared, the difference in altitude between the point of
release and the point of landing must be 1000 meters or less to avoid
the penalty.
Marc
Old August 29th 04, 02:28 AM
Stewart Kissel
http://www.abqsoaring.org/LONGXC_031025.pdf
Marc-
This is what got me curious...according to Karl an
'Undeclared Remote Start' can be used for a 1000k attempt.
I assume this is considered a distance task...or perhaps
it is not? Not trying to be argumentitive here...just
confused
Old August 29th 04, 04:59 AM
Judy Ruprecht
confused
I believe Carl is mistaken. Any Start Point other than
release from tow (or Means of Propulsion stop) must
be declared for badge flights including FAI Diplomes.
Similarly, any Finish Point other than landing (or
Means of Propulsion engaged) must be declared for badge
flights including Diplomes.
FWIW, there are huge differences between 'legal' tasks
for Badges and Records. It is possible to fly a 2,000Km
Free O&R record (declared per Sporting Code 4.2.1,
excluding item e) and not earn Silver Distance!
Judy
Old August 29th 04, 05:04 AM
Marc Ramsey
confused
I think what Carl is trying to say is that you can release from the
towplane an arbitrary distance from the airport, say, over high ground
20 miles away. This is actually fairly common for long flights, as the
early lift is often elsewhere. But, if no start point is declared, the
point of release is the start point...
Marc
Old August 29th 04, 05:10 AM
Stewart Kissel
Then perhaps he is describing a 3 TP free task?
Old August 29th 04, 05:37 AM
Judy Ruprecht
Could be. Importantly, however, none of the 'Free'
tasks described in Sporting Code 1.4.3 are available
for badge flights including the Diplomes.
Judy
Old August 29th 04, 05:42 AM
Eric Greenwell
effect?
start and finishes?
the penalty.
It's unlikely Stewart was talking about world records, but the Code says
1.4.3 Free distance performances for records only
The WAY POINT(S) of free distance record flight performances may be
declared post-flight.
Since the start and finish are way points, it sounds like they could be
declared post-flight. This would also work for USA State records, which
allow the free distance task.
For badges, it's pretty clear (note the last sentence):
1.4.5.b. DISTANCE USING UP TO THREE TURN POINTS
A flight from a START POINT via up to three TURN POINTS to a FINISH
POINT. If the FINISH POINT is the landing place it need not be declared.
The TURN POINTS must be at least 10 kilometres apart and may be claimed
once, in any sequence, or not at all. This course must be declared.
What I think is a quirk in the rules lets a motorglider pilot
effectively choose the end of the task by starting the motor, but the
unpowered glider pilot must either declare an end point or use the
landing point.
Eric Greenwell
Washington State
USA
Old August 29th 04, 06:07 AM
Stewart Kissel
So if a Start Point is declared....you can tow as high
as you want with out penalty? And a declared finish
point altitude is then subtracted from this?
effect?
does
difference
post-flight
start and finishes?
a distance task. If
or a finish
declare them before
so if neither start
or less to avoid
the penalty.
but the Code says
may be
like they could be
to a FINISH
and may be claimed
be declared.
pilot
the motor, but the
or use the
landing point.
Change 'netto' to 'net' to email me directly
Eric Greenwell
Washington State
USA
Old August 29th 04, 06:26 AM
Stewart Kissel
And if you use tow release as your start with no declared
finish...can you land anywhere you please?
effect?
does
difference
post-flight
start and finishes?
a distance task. If
or a finish
declare them before
so if neither start
or less to avoid
the penalty.
but the Code says
may be
like they could be
to a FINISH
and may be claimed
be declared.
pilot
the motor, but the
or use the
landing point.
Eric Greenwell
Washington State
USA
Run up for plug clearing Roger Long Piloting 78 October 18th 04 03:39 AM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 05:18 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Winch Experts wanted Ulrich Neumann Soaring 117 April 5th 04 06:52 AM
