TAT scoring question
Old August 31st 04, 09:48 PM
Erik mann
(John Cochrane) wrote in message . com...
However, as far as I can tell, you CAN call your first passage the
"finish" for scoring purposes if you're willing to take the land-out
risk. For example, if you try another turnpoint in a MAT but then turn
around and land home, or even if you make it but it gives you a slower
time overall, nothing stops you from calling the first passage a
"finish."
I agree with John' interpretation, and I think the way you accomplish
this is based on the contents of the landing card. Using the MAT
example for a second, if we have a task with: Start, Turn 1, Turn 2
assigned and assuming the pilot completes Turns 1 and 2, then the
options for the next CLAIMED point a
- Finish
- Turn 3
If the landing card says the pilot claims Finish (irrespective of
whether the trace shows he actually made Turn 3), then the scorer is
obligated to score the flight that way. As long as he was within the
limits of the Finish Cylinder, I see no reason why that isn't
legitimate. If the landing card says the pilot claims Turn 3, then
that's how it is scored. It's not unlike the old PST where you might
take a picture of a turnpoint as you went by it "just in case". You
might opt not to include it if you were going to exceed your 11
turnpoints, for example.
HOWEVER, rule 11.2.2.1 says that the landing card shall "accurately
reflect the flight that the pilot completed". As I recall, the intent
of that rule was to prevent someone from intentionally under-reporting
their flight in order to cancel out a day. That's certainly how I
would interpret this rule if I were on the Contest Competition
Committee (3.1.4).
As far as radio usage is concerned, the Appendix to the rules makes it
clear that the radio finish calls are for safety or nostalgia only
"Pilots and gate personnel should understand that the radio call... is
now mostly for show"
No?
P3
Old September 1st 04, 02:47 AM
Jonathan Gere
(Tom Serkowski) wrote in message
Suppose I'm flying a POST and do the following:
Start, A, B, Home, C, D, Finish
If the 'Home' TP happens to coincide with the Finish cylinder, then
I'm unable to claim part of my valid task by your definition. If the
finish cylinder is on the B - Home or Home - C leg, must I go around
it?
It is easy to fly through the start/finish zones without starting or
finishing:
1) Don't announce a S or F on the radio
2) Don't claim a S or F at that point on your landing card
What if I come home and plan to go to C, but circumstances are such
that I decide to finish instead. Do have to reenter the finish
cylinder to get a valid finish or did that entry I made 10 minutes (or
2 hours, since I spent that time at 500' a mile the other side of the
airport) ago count for a finish?
It did not count for a finish, because you didn't announce it on the
radio. If you did call a finish, you are done after one lap and can't
go on later. I'm not speaking of what WinScore will say, only of what
the rules require. It is unambiguous that S's and F's "shall" be
announced on the radio. Maybe it can be a finish, but you take a
penalty for not announcing.
Finish announcements are, IMHO, purely for safety and operations.
Scoring is done by validating your landing card claim with the IGC
log.
I think they also prevent pilots from having multiple starts and
finishes in play simultaneously.
IF a pilot chooses to go around twice without landing after the first
(announced or stealthy) finish, then he is at risk of getting distance
points if he lands out or starts the engine on the second attempt.
Making a landing and officially observed takeoff, allows him to use
the first flight if the second attempt ends with a landout.
agreed, but do you think he has the option of claiming either one or
the combination of the two attempts if he goes around twice in one
flight?
Tom Serkowski
Suppose S(tart)=F(inish)=TP C. No designated turn MAT. You fly
S-A-B-(FSC)-A-B-(FSC)-A-B-(FSC)-A-B-F (i.e. 11 TPs - 4 times around a
triangle) then after landing claim the best scoring of any one of 10
combinations of consecutive laps:
1,1+2,1+2+3,1+2+3+4,2,2+3,2+3+4,3,3+4,or 4.
Will this work? Can you openly announce all 4 S's and all 4 F's on
the radio to avoid the penalties for not doing so, and choose which to
discard by leaving them off your landing card?
If not, why not, under your interpretation of the rules.
If so, why do so many pilots go undertime on no turn MAT's, when they
could easily bank insurance laps during the start gate roulette?
Jonathan Gere
Old September 1st 04, 05:16 AM
Andy Durbin
(Erik mann) wrote in message . com...
"finish."
- Finish
- Turn 3
Committee (3.1.4).
No?
P3
The start and finish are not required to be entered on the landing
card. Finishing is implied by checking the task complete box. Neither
the start, not the finish, are turnpoints although turnpoints may be
colocated with the start or finish. Your example of a completed
landing card does not seem to be valid.
In the case where a turnpoint falls inside the finish cylinder it is
perfectly legitimate to bag that turnpoint, then another, then return
to the finish. It is also true that a flight leg that happens to pass
through the finish cylinder does not force the pilot to abort the task
and land. No landing card claim need be associated with that event.
The radio call that "is for nostalgia" is the call of good finish by a
finish line ground observer. There have been cases where a good
finish call was given but the flight log shows no such valid finish
was made. It only applies to line finishes. The pilot call of
"finish" only applies to cylinder finishes.
Otherwise I think we are in agreement that there is no prohibition on
attempting another turnpoint after being inside the finish cylinder.
That's fortunate of course because often the start and finish are
colocated or overlap.
Andy
Old September 1st 04, 03:03 PM
Tom Serkowski
(Jonathan Gere) wrote in message . com...
Disagree, the finish announcement is purely a 'heads up, I'm here'
call. I don't recall seeing a rule about penalties for not calling a
finish. I suppose that a safety issue could be raised if a pilot
fails to announce and is in the middle of a finish gaggle, but that's
an operational, and not scoring issue.
log.
flight?
A start call, on the other hand, if required, must be made after each
start. It is up to the scorer to correlate the start calls with start
times to ensure it was done.
I don't beleive that making a start call after completing the task
will invalidate it. Again, this call is designed to provide some
feedback to other competitors that glider XX has recently started. In
the old days, one would just listen to the gate freq for this. Adding
a penalty for not making the call is just to force all competitors to
be out in the open about when they started. If the rules designers
had intended for this call to 'reset' the flight, then it would have
been spelled out plainly.
-Tom
Old September 2nd 04, 09:29 AM
Gary Ittner
the rules require.
No, this is what the rules requi
11.2.2.4.4 If all claimed turnpoints are valid, and the pilot obtained
a scored start time, a finish time prior to finish closing and landed at
the contest site, then the pilot has completed the task.
Please notice that this rule does NOT contain the phrase "and announced
his start and finish on the radio".
No, it is unambiguous that start *times* shall be reported within 15
minutes of a start, and it does not have to be on the radio (see rule
10.8.8.3). Finishes are announced by the pilot only when a finish
cylinder is used. With a finish line, the pilot only announces his
approach: "(Contest ID) four miles".
Now you are getting closer. It *is* a valid finish, and *maybe* you will
get a penalty for not announcing it on the radio. If a pilot repeatedly
refused to follow the radio procedures defined in the rules, the Contest
Director could make a good case for awarding a penalty for unsafe
flying or unsportsmanlike conduct. But I would have a low opinion of any
CD that handed out such a penalty automatically on first offense without
considering the circumstances.
On day 7 of the 2002 USA 15m Nats at Tonopah, Bill Bartell experienced a
double battery failure while on task: his primary battery became
unplugged, and his backup battery had a low charge. He turned off his
radio, his only vario, and his flight computer, saving his few remaining
electrons for the flight recorder. Bill finished and landed silently,
winning the day and moving into first place overall. Would you have
given him distance points only, or a penalty for not calling "four
miles"?
One day at the 2001 USA 15m Nats at Uvalde, the finish was so crowded
that the radio was squealing constantly from multiple pilots stepping on
each other trying to call "four miles", and Charlie Lite trying to
acknowledge each call. During the less than 2 minutes it took me to fly
at redline from "four miles out" to the finish line, there was not one
moment of clear frequency in which to announce my approach, and I chose
not to step on some other pilot's announcement. Would you have given me
a penalty?
There is nothing in the rules to prevent this scheme, but practical
considerations make it a useless strategy. Firstly, any of the lap
combinations that took significantly less than the minimum task time
would likely score very low.
And since maximum start altitude and minimum finish altitude are never
the same, in order to make an efficient finish and an efficient start
between each lap, you would have to finish at minimum finish altitude
and immediately pull up into a good thermal, climbing to maximum start
altitude before exiting the start cylinder, all without wasting time
searching for lift.
It is therefore unlikely that any combination of laps other than 1+2+3+4
would have both an efficient start and an efficient finish. And if any
number of laps less than four is sufficient to use up the minimum task
time, you will be beaten by the pilot who did a better job of
"bracketing" the day by not flying as far as your four laps.
Perhaps those pilots are not as adept as you are at mis-interpreting the
rules or devising poor racing strategies.
Gary Ittner P7
"Have glider, will race"
Old September 3rd 04, 01:02 PM
Jonathan Gere
Gary Ittner wrote in message ...
Is this a good argument?. I would guess there are quite a few
important rules that affect getting a speed score which are NOT
referenced in 11.2.2.4.4 or the narrow hierarchy of rules defining the
terms 11.2.2.4.4 references. If not, and 11.2.2.4.4 is the all
important master root of all rules that count, congratulations, but
why is it buried 5 levels deep in section 11?
I am not in favor of radio procedure penalties or radio procedure
violations invalidating "normal" starts or finishes. I am only
clutching at straws to see how the rules might prohibit pre-pending or
appending TPs between multiple provisional starts and finishes. I
find the ability to be on multiple provisional starts / finishes /
tasks simultaneously an absurd consequence of the rules. It is little
comfort to me to have your assurance that it is strategically useless.
miles"?
a penalty?
Good arguments for CD discretion.
I'm shocked. This is weird. I don't believe that all variations of
this loophole are strategically useless. The 4 times around example
is just a good example of the absurdity of the loophole. Operational
exploitations can be much more profitable.
searching for lift.
In practice, one could just prepend optionally claimable S-one or more
TPs- Home TP-S combinations without going low to finish. Cheap
insurance against gross or possibly even minor undertime.
And if any
The insurance excursions would occur before the final start intended
to bracket the *expected* day. The insurance excursions would absorb
any inefficiency in getting ready for the "perfect" optimized start.
If not claimed, the excursions imperfect efficiency wouldn't matter.
On the other hand, 1hr at even 80% efficiency is a lot better than
nothing, when everyone else finished an hour undertime due to an
*unexpected* thunderstorm. 30 minutes at 90% efficiency might be
worth claiming to avoid a routine 5-10 minute undertime (at 0%
efficiency).
Thanks. You admit the loophole. I leave it to better pilots to work
out the operationally sound strategies.
Gary Ittner P7
Old September 3rd 04, 05:12 PM
Jonathan Gere
Quote
A11.2.2.1 ...
The landing card must reflect the flight actually accomplished, even
in the case where claiming a shorter flight might be in the pilot's
best interest. A deliberate violation of this rule could be considered
Unquote
If the intent here is only to preclude deliberately helping to cancel
or devalue the day, then this certainly should not apply to not
claiming TP's along the way which would invalidate the pilot's flight.
Examples might be exceeding 11 TP's, as you mention, or a TP which
winds up being a repeated TP. To claim the invalid TP's would be to
claim a "shorter" flight in the scoring sense anyway.
The issue I see is that in quaint olden days the starts and finishes
were fixed and known to the ground, so the pilot's longest (in
distance) task was his fastest task. The pilot would never be
contributing to devaluation or cancellation by reporting the subset of
his flight giving the best scoring speed. Also, a pilot could not
discard a later start and revert to a previous start and use some TP's
made before and some TP's made after the final start to get a better
distance.
But now:
What if his best attempt in one flight is complete, but grossly
undertime? This could cause devaluation under Rule 11.5.4. Must he
claim the maximum possible distance and/or time from the combination
of turnpoints reached in two attempts he never intended as a single
task attempt, even if it produces a slower scoring speed? An
unintended valid TP may even have been reached following an unintended
valid start with no intention of even being on course, must he claim
this under 11.2.2.1?
What if a pilot starts, gets a TP, gets slow, comes back without
landing, takes another start (an entirely new attempt he thinks) and
lands out short of minimum distance. Should he claim the maximum
possible distance from the combination of turnpoints reached in two
attempts he never intended as a single task attempt? Does good
sportsmanship require it? Do the rules require it?
Jonathan Gere 34
"finish."
- Finish
- Turn 3
Committee (3.1.4).
No?
P3
  #28
Old September 4th 04, 01:25 AM
Gary Ittner
It is difficult to prove a negative, isn't it? Perhaps I should not have
attempted to make things easier for you and instead simply said, "There
is no rule that invalidates a start or a finish due to lack of a radio
call", and put the burden of proof on you to support your opposing
statement.
All the rules count, but they cannot all be front and center in
paragraph one. And while some rules may be more important than others
for running a safe and fair contest, the importance of a rule is not
intended to be proportional to its subparagraph level in the rule book.
So, did you deliberately prevaricate when you stated that, according to
the rules, a start or finish is invalidated by the lack of a radio
announcement?
I find the ability to be on multiple provisional starts / finishes /
And I do not.
It is little
It is of great comfort to me. I believe there may an infinite number of
useless strategies for flying any of the tasks. One of the main purposes
of the rules is to ensure fair competition, but I see no benefit in
making our rulebook infinitely longer by specifically prohibiting every
strategy in which a pilot cannot gain an unfair advantage, or indeed any
advantage at all.
efficiency).
I will admit that it is not entirely impossible that you could gain by
this strategy, but the phrase "extremely unlikely" does not seem
powerful enough to describe it.
To recap, your insurance lap would only be useful with a no turn MAT
(rare nowadays), called on a day with no expected weather problems (when
other, less flexible tasks are *far* more likely to be called; no turn
MATs are usually called specifically because there are expected weather
problems), all of your competitors start (what turns out to be) too
late, and along comes a weather problem too severe for the flexibility
of the MAT to deal with. I'd call it a one in a million chance.
And I don't agree that this insurance is cheap; you simply haven't
calculated the cost. You might have to try this insurance lap trick many
times before the proper conditions arise to make it useful, and:
1. You might land out while your competitors are safely back near the
contest site playing start gate roulette. Believe me, I know what it
feels like to land out before one's expected start.
2. The conditions could change while you are on your insurance lap,
causing everyone else to start en masse before you get back for your
expected start. Even on a no turn MAT, there is often only one obvious
direction to go. Your competitors will have thermal markers, and you
will have none.
3. Even when the proper combination of conditions comes along, you
cannot be sure all of your competitors will start late. If one starts
early, he will have the advantage over you of being able to place a
higher proportion of his flight in the area of best lift. Your insurance
lap will necessarily be close to home, and, in my experience, that is
rarely where the best soaring conditions are located.
The premium you pay for your insurance lap is much higher than the
potential claim payout.
And if there are no operationally sound strategies, is it still a
loophole?
Gary Ittner P7
  #29
Old September 4th 04, 05:04 PM
Andy Blackburn
As I read the rules I am hard pressed to find any language
that indicates that radio calls are intended to determine
which starts or finishes are to be used. There is certainly
no specific language requiring this. To the contrary,
what language there is appears to indicate safety as
the reason, particularly for finishes. Furthermore,
the specific language in the 2004 rules makes start
calls optional at the CD's discretion.
10.8.8 Start time reporting
The CD *may* require pilots to report their start times
by radio.
When it's mandatory, the rules read *shall* rather
than *may*.
As to the efficacy Jonathan's 4-lap strategy, I guess
it is theoretically possible that you could have a
1.5 hour MAT called (with or without a first TP) on
a day with 6 hours of good soaring conditions after
the gate opens. Gary points out some of the practical
limitations (best conditions near the Start/Finish,
outlanding risk, needing to find a good thermal from
low altitude right after each intermediate finish).
The biggest negative for me is the fact that you would
need to take a start earlier than normal to get in
the first 'lap' and from then on you are 'on the clock'.
This means that you are forced at each subsequent finish
to get back out on course right away, rather than trying
to optimize the height or location or time of your
start. This is particularly true if you need more than
one lap to get over minimum time. There is also (as
John Cochrane would point out) a structural points
penalty associated with multi-lap strategies that put
you well over minimum time.
A potentially more likely scenario is a pilot who elects
to add turnpoints after 'finishing' a task - either
because he finds himself under time and/or sees conditions
ahead that allow him to quickly bag a couple of additional
turnpoints. I pursued this strategy one day at a contest
this summer, but never connected with a good thermal,
so I landed.
I personally don't have a problem with pilots pursuing
these strategies - practical or not. It doesn't seem
unfair and the rules required to preclude them would
just add complexity.
9B
  #30
Old September 4th 04, 05:54 PM
TomnKeyLargo
This bagging of turnpoints or laps before your start. Remember, the task start
time?? Remember what Winscore checks for?? Whenever you start, no matter when,
Winscore MUST see a gps trace to each and every turnpoint or turn area and a
finish. IF Winscore does NOT see this trace, then it gives you a landout. On A
MAT, Winscore must see this trace between turnpoints claimed or you will get a
landout. Winscore checks flight traces and turnpoints/ turn areas. Like it
connects the gps fixes to the dots and the circle has to be complete. Without a
proper flight trace you will get a landout, or no flight. Just as See you shows
you your flight, if you don't get to the turnpoint/turn area it shows you a
photo landing. Only a small power interuption is allowed. The finish and start
are not turnpoints. If you come back and finish, you better get a turnpoint for
the area you are in before you go back and try to increase your distance. and
then get a turnpoint on a mat and then landout, since you didn't land at the
home field, then Winscore will land you out. What you can not do is bag
turnpoints or laps before the start. Winscore again checks for traces between
the start and turnpoints and /or turn areas. If someone wishes to finish, then
head back to the turn area to get more mileage, he can do so, but he better
make it home and show a finish and not landout. And if anyone wishes to do this
and think it will increase his speed, please do so, I like to win. If cheaters
like to come and try to win this way, of bagging laps or turnpoints before the
start, then I have noticed that they make themselfs seen. As they have teeth
marks on their foreheads, as they have bitten their ass which their heads are
up. IMHO. # 711.
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
History of Contest Scoring Bill Feldbaumer Soaring 8 October 8th 03 02:14 PM
new TASKs and SCORING - or roll the dice CH Soaring 0 August 10th 03 07:32 AM
