#21
Ahhh, that fall season is upon us...as hours in the
air decrease, the semi-annual return of the PCC, PW5 and 2-33 threads reappear ![]() religion and politics as their old standbys. Although some might see Mark's post as a troll attempt...I think he makes some interesting points. IIRC on the HP site, an analysis was done that 1 in 1,000 hottelier connections are done incorrectly...not sure how that data was collected. Attitudes on PCC's seem to be 1.) I have done it safely for years, others should be able too. 2.) I used to think (1.) until almost killed by disconnect. 3.) It's a crappy design and I ain't going near it. I am a #3 guy myself. At 02:42 23 September 2004, Mark James Boyd wrote: I think the best way to do this isn't mirrors or safety pins or PCCs or bits of string or feel or training or flashlights.... I prefer a big ass port (or two) that lets you look directly at the entire connection from all sides. If the designer made an ity-bity port, and you have to rely on a PCC because you can't see the dang connection close up, then that's just a crappy design. If the fuse is really so flimsy the port has to be 5 inches wide instead of 8 or 9 inches, and it can't be right near the connection, then the designer needs to go to the drawing board. The Pegasus elevator connection is out in the breeze, and real easy to visually inspect. If anyone ever failed a PCC of that elevator connection, I'd have to recommend they do the connection inspection next time with eyes open, perhaps with their bifocals on, during daylight hours. I think the (over)emphasis on a PCC is bunk. The connection inspection is the key. If I'm ever in a situation where a PCC discovers something, I'll either not fly that glider again (the design doesn't allow good enough direct connection inspections) or I'll not fly ANY gliders (since I'm too stupid or too hurried to look right at a connection and determine if it's connected). The exception to this is something like the bellcrank failure that happened last year to a dive brake during a PCC. No connection inspection is going to find that. But one wonders if the tens of thousands of PCCs CAUSED the failure itself, by wearing out the bellcrank faster... -- ------------+ Mark J. Boyd |
Good post Stew, indeed winter is not too far away.
Automatic control hook-up's is the final answer, but we still have a bunch of sailplanes out there without the final solution. I have twice failed to hook up the outboard flap connections on our ASH-25 (now sold). Both times I was talking to someone and reverted to my Nimbus 3, habit patern where there is only 2 connections to be made, both after the wing is completely in place. The ASH-25 requires the flap connection to be made while the wing is about 2 inches from mating and then 2 more connections after sliding the wing all the way into the inboard sections. In both cases, I found my mistake in the PCC. If I may start the winter season with a political remark, How about adjoining jail cells for Martha Stewart ans Dan Rather? At 16:42 23 September 2004, Stewart Kissel wrote: Ahhh, that fall season is upon us...as hours in the air decrease, the semi-annual return of the PCC, PW5 and 2-33 threads reappear ![]() religion and politics as their old standbys. Although some might see Mark's post as a troll attempt...I think he makes some interesting points. IIRC on the HP site, an analysis was done that 1 in 1,000 hottelier connections are done incorrectly...not sure how that data was collected. Attitudes on PCC's seem to be 1.) I have done it safely for years, others should be able too. 2.) I used to think (1.) until almost killed by disconnect. 3.) It's a crappy design and I ain't going near it. I am a #3 guy myself. At 02:42 23 September 2004, Mark James Boyd wrote: I think the best way to do this isn't mirrors or safety pins or PCCs or bits of string or feel or training or flashlights.... I prefer a big ass port (or two) that lets you look directly at the entire connection from all sides. If the designer made an ity-bity port, and you have to rely on a PCC because you can't see the dang connection close up, then that's just a crappy design. If the fuse is really so flimsy the port has to be 5 inches wide instead of 8 or 9 inches, and it can't be right near the connection, then the designer needs to go to the drawing board. The Pegasus elevator connection is out in the breeze, and real easy to visually inspect. If anyone ever failed a PCC of that elevator connection, I'd have to recommend they do the connection inspection next time with eyes open, perhaps with their bifocals on, during daylight hours. I think the (over)emphasis on a PCC is bunk. The connection inspection is the key. If I'm ever in a situation where a PCC discovers something, I'll either not fly that glider again (the design doesn't allow good enough direct connection inspections) or I'll not fly ANY gliders (since I'm too stupid or too hurried to look right at a connection and determine if it's connected). The exception to this is something like the bellcrank failure that happened last year to a dive brake during a PCC. No connection inspection is going to find that. But one wonders if the tens of thousands of PCCs CAUSED the failure itself, by wearing out the bellcrank faster... -- ------------+ Mark J. Boyd |
John Sinclair wrote:
If I may start the winter season with a political remark, How about adjoining jail cells for Martha Stewart ans Dan Rather? If we are going to jail people for using poorly authenticated information, we could start at the top of the food chain, couldn't we? -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#24
How about adjoining jail cells for Martha Stewart ans Dan Rather? If we are going to jail people for using poorly authenticated information, we could start at the top of the food chain, couldn't we? Ohmigod...I saw "The Daily Show" with John Stewart on Comedy Central yesterday. I had tears it was so funny. I dunno if we could get him to do a show on Hotelliers, unless their the Hilton sisters... -- ------------+ Mark J. Boyd |
#25
Dan Rather? I think Jay Leno got it right ....... Dan Rather is defending the documents as 'fake but accurate', doesn't that sounds more like breasts in California?...'fake but accurate' ![]() At 18:00 23 September 2004, John Sinclair wrote: Good post Stew, indeed winter is not too far away. Automatic control hook-up's is the final answer, but we still have a bunch of sailplanes out there without the final solution. I have twice failed to hook up the outboard flap connections on our ASH-25 (now sold). Both times I was talking to someone and reverted to my Nimbus 3, habit patern where there is only 2 connections to be made, both after the wing is completely in place. The ASH-25 requires the flap connection to be made while the wing is about 2 inches from mating and then 2 more connections after sliding the wing all the way into the inboard sections. In both cases, I found my mistake in the PCC. If I may start the winter season with a political remark, How about adjoining jail cells for Martha Stewart ans Dan Rather? At 16:42 23 September 2004, Stewart Kissel wrote: Ahhh, that fall season is upon us...as hours in the air decrease, the semi-annual return of the PCC, PW5 and 2-33 threads reappear ![]() religion and politics as their old standbys. Although some might see Mark's post as a troll attempt...I think he makes some interesting points. IIRC on the HP site, an analysis was done that 1 in 1,000 hottelier connections are done incorrectly...not sure how that data was collected. Attitudes on PCC's seem to be 1.) I have done it safely for years, others should be able too. 2.) I used to think (1.) until almost killed by disconnect. 3.) It's a crappy design and I ain't going near it. I am a #3 guy myself. At 02:42 23 September 2004, Mark James Boyd wrote: I think the best way to do this isn't mirrors or safety pins or PCCs or bits of string or feel or training or flashlights.... I prefer a big ass port (or two) that lets you look directly at the entire connection from all sides. If the designer made an ity-bity port, and you have to rely on a PCC because you can't see the dang connection close up, then that's just a crappy design. If the fuse is really so flimsy the port has to be 5 inches wide instead of 8 or 9 inches, and it can't be right near the connection, then the designer needs to go to the drawing board. The Pegasus elevator connection is out in the breeze, and real easy to visually inspect. If anyone ever failed a PCC of that elevator connection, I'd have to recommend they do the connection inspection next time with eyes open, perhaps with their bifocals on, during daylight hours. I think the (over)emphasis on a PCC is bunk. The connection inspection is the key. If I'm ever in a situation where a PCC discovers something, I'll either not fly that glider again (the design doesn't allow good enough direct connection inspections) or I'll not fly ANY gliders (since I'm too stupid or too hurried to look right at a connection and determine if it's connected). The exception to this is something like the bellcrank failure that happened last year to a dive brake during a PCC. No connection inspection is going to find that. But one wonders if the tens of thousands of PCCs CAUSED the failure itself, by wearing out the bellcrank faster... -- ------------+ Mark J. Boyd |
#26
Wow, I didn't realize there was aversion by some against
L'hotellier fittings and even refusal to fly gliders that use them. Hmm, I guess if it's possible to put a 'dualie' landing gear on a Libelle H201, then it's bound to be possible to retrofit L'Hotelier fittings with automatic connections. Of course, the cost to do so on something like my LS-1d would be about the same as the total value of the glider. Or a lot more. Since I can't make the jump to a ship with automatic connections, I'll continue to fly mine, but not before I make a Positive Control Check after assembly. Ray Lovinggood Carrboro, North Carolina, USA LS-1d, 'W8' |
#27
![]() "Ray Lovinggood" wrote in message ... Wow, I didn't realize there was aversion by some against L'hotellier fittings and even refusal to fly gliders that use them. Hmm, I guess if it's possible to put a 'dualie' landing gear on a Libelle H201, then it's bound to be possible to retrofit L'Hotelier fittings with automatic connections. Of course, the cost to do so on something like my LS-1d would be about the same as the total value of the glider. Or a lot more. Since I can't make the jump to a ship with automatic connections, I'll continue to fly mine, but not before I make a Positive Control Check after assembly. Ray Lovinggood Carrboro, North Carolina, USA LS-1d, 'W8' Does anybody have a first person story of a L'Hotellier fitting coming loose when it was CERTAIN that it was connected and safetied correctly in the first place? I attach and safety pin mine by feel and then check them visually and by tugging at right angles on each one in turn. Then I also do a PCC. Bill Daniels |
#28
The whole issue with the safety pins was a rather 'knee jerk" reaction
rather than a cure. I don't honestly know of any of these connections when proper connected (that's the catch, so to speak) with or without safety pins installed...for years gliders with these connections never used the safety pins...the problem lies with the connectors not getting proper attached in the first place, and that is something rather easy to do, they can 'appear" to be connected and not fully connected...if the fittings are not worn out (subject of another AD note to measure these balls and sockets) then they don't become disconnected...many (most) gliders that used these fittings also however had them in such a location they were installed mostly by brail since you had to feel your way into a location that was many times impossible to see.... LS even went to the smoke and mirrors (less the smoke) method by installing tiny mirrors on the aft bulkheads so you could see the connections.. the L'Hotellier connections were simply a not nice way of connecting essential flight controls, several gliders have crashed when they became disconnected (never properly connected) and people died because of these....and, probably will in the future as well. Even some earlier gliders used "pip" pins for control connections, these were much better than the L'Hotellier fittings.....now, and in the future, every manufacturer should and most do use automatic connections.... tim Does anybody have a first person story of a L'Hotellier fitting coming loose when it was CERTAIN that it was connected and safetied correctly in the first place? I attach and safety pin mine by feel and then check them visually and by tugging at right angles on each one in turn. Then I also do a PCC. Bill Daniels |
#29
My observation is that the only way to insure they are properly connected is
by feel. If the cup is only partially engaged with the ball, the fitting will feel stiff. With the cup fully over the ball and the tab fully seated, the fitting will easily rotate on the ball with just finger pressure. When you KNOW a fitting is properly attached, run your finger tip over the opening of the cup to feel the position of the ball in the cup. When you learn what a good connection feels like, it's very easy to feel when the ball is not properly seated. I take some comfort in the fact that my L'Hotellier fittings are much harder to get off than on. Oh yes, I also clean them with solvent and re-lube them regularly. Bill Daniels "Tim Mara" wrote in message ... The whole issue with the safety pins was a rather 'knee jerk" reaction rather than a cure. I don't honestly know of any of these connections when proper connected (that's the catch, so to speak) with or without safety pins installed...for years gliders with these connections never used the safety pins...the problem lies with the connectors not getting proper attached in the first place, and that is something rather easy to do, they can 'appear" to be connected and not fully connected...if the fittings are not worn out (subject of another AD note to measure these balls and sockets) then they don't become disconnected...many (most) gliders that used these fittings also however had them in such a location they were installed mostly by brail since you had to feel your way into a location that was many times impossible to see.... LS even went to the smoke and mirrors (less the smoke) method by installing tiny mirrors on the aft bulkheads so you could see the connections.. the L'Hotellier connections were simply a not nice way of connecting essential flight controls, several gliders have crashed when they became disconnected (never properly connected) and people died because of these....and, probably will in the future as well. Even some earlier gliders used "pip" pins for control connections, these were much better than the L'Hotellier fittings.....now, and in the future, every manufacturer should and most do use automatic connections.... tim Does anybody have a first person story of a L'Hotellier fitting coming loose when it was CERTAIN that it was connected and safetied correctly in the first place? I attach and safety pin mine by feel and then check them visually and by tugging at right angles on each one in turn. Then I also do a PCC. Bill Daniels |
#30
Who are Martha Stewart and Dan Rather?
At 18:24 23 September 2004, Mark James Boyd wrote: If I may start the winter season with a political remark, How about adjoining jail cells for Martha Stewart ans Dan Rather? If we are going to jail people for using poorly authenticated information, we could start at the top of the food chain, couldn't we? Ohmigod...I saw 'The Daily Show' with John Stewart on Comedy Central yesterday. I had tears it was so funny. I dunno if we could get him to do a show on Hotelliers, unless their the Hilton sisters... -- ------------+ Mark J. Boyd |
Dittel FSG40S wiring connections | Anthony Manwaring | Soaring | 3 | June 23rd 14 05:42 PM |
Narco Com IIA Wiring connections? | Rod | Home Built | 4 | October 12th 11 07:08 AM |
NEW - Exposing more on the Felony Fraud SwiftLiars Organized Crime connections | Psalm 110 | Military Aviation | 0 | August 21st 04 09:40 PM |
NEW - Exposing more on the Felony Fraud SwiftLiars Organized Crime connections | Psalm 110 | Military Aviation | 0 | August 21st 04 09:39 PM |
Denso alternator connections | Paul Lee | Home Built | 2 | July 6th 04 09:22 PM |
