Boom (gooseneck) Vs ambiance microphone
Old September 28th 04, 08:32 PM
Flavio Formosa
I once self-made one by extracting the mic capsule
from a 25€ hand-held PTT-mike (the type used with ground
VHF units) and wiring it to the mic harness of the
radio (Becker AR3201). It was cheap and perfectly functional.
You need some soldering skills though, and you may
want to insert it in the panel in a presentable fashion.
I had glued the capsule behind a hole on the back of
the panel, and glued a black round metal grille on
the front (this latter taken from a discarded walkman
headset's earpiece!). If you want to see the effect,
go to www.segelflug.de on the segelflugzeug-testberichte
page, find the LS7WL test report and check the picture
where my instrument panel is (the one with a Filser
DX50 on the top row): the home made mic is on the right
hand of the panel at mid height. Good luck!
At 14:06 28 September 2004, Ludovic Launer wrote:
Yes, thanks, that's just the one I had in mind.
I was wondering if anyone was using a more 'off the
shelf' component
though...
Try this:
http://www.md-flugzeugbau.de/flymic.html
Old October 7th 04, 04:20 AM
Serge Serfaty
shelf' component
though...
Try this:
Hi,
Were you able to buy that microphone?
Does it work as well as a gooseneck?
Is there a retailer in the USA?
Thanks
Advice: Boom Mic or alternative Vassilios Mazis Soaring 0 March 9th 04 10:09 PM
Bell X-1 sonic boom. Ed Majden Military Aviation 4 December 2nd 03 05:20 AM
Any problems: headsets to handheld? Michael Horowitz Home Built 9 September 30th 03 04:57 AM
Icom Boom Mike Kevin Neave Soaring 2 September 25th 03 09:39 AM
Telex 500T Microphone... DGRTEK Soaring 0 July 15th 03 10:55 PM
