Help With Westerboer VW 921 Needed
Old October 9th 04, 04:28 PM
ChuckPilot
Default Help With Westerboer VW 921 Needed
Is there anyone out there who is intimately familiar with a VW 921 flight
computer? If willing, would you please contact me directly? I am trying to get
a CAI Model 20 GPS to communicate to a VW 921, but have been unsuccessful. I
have had someone double-check the cable for correct design and continuity. All
appears well with the cable. The GPS also seems to be working properly.
The VW 921 was returned to the factory this past summer for software and
hardware upgrades, and was pronounced to be in good working order.
I am hopeful that there is some little trick or setting I am not aware of. I
have also contacted the Westerboer factory. They suggested a couple of things,
but nothing helped. I want to be certain that the problem is in the 921 before
I send it back to Germany.
I also was wondering where I could find the pin-out specs on the DB9 connector
on the Model 20? Is that listed on a website somewhere?
Thanks in advance for any help (useful help appreciated even more).
Chuck
Old October 10th 04, 11:35 PM
John Sinclair
Chuck,
Just a shot in the dark, but when the Cambridge model
20 is used to drive the Borgelt B-100, the red and
yellow leads in the NMEA cable (phone cable) must be
reversed. You might want to give it a try.
JJ
Old October 11th 04, 12:01 AM
John Sinclair
One more tid-bit, If you're using a Cambridge NMEA
cable, the white lead at the GPS box is on the RIGHT,
but when this same cable goes into the computer, the
white lead is on the LEFT. In other words, you must
use the correct end of the cable on the Model 20 end.
A standard phone cable may not work.
:) JJ
At 23:00 10 October 2004, John Sinclair wrote:
Chuck,
JJ
Military Helicopter/Trainer needed Jenna Military Aviation 0 January 30th 04 08:37 PM
Westerboer ? Phil Jeffery Soaring 0 December 2nd 03 11:40 PM
how many pounds thrust needed ? cdubya Soaring 10 September 14th 03 04:28 AM
E2-C wheel bearings needed CaptAro Restoration 1 July 19th 03 04:32 AM
