Why does the Sporting code require "Goal" to be a finish point???
Old October 10th 04, 05:47 PM
Ian Cant
I got lost a long way back in this thread, so please
re-educate me. The FAI sporting code sect 4.2 defines
declaration requirements and says 'the last declaration
made before takeoff is the only one valid for the flight,
but a concurrently flown and different competition
task is allowed.' Seems that your electronic declaration
on the roll is the only one that counts.
Also, to confuse me further, Annex C sect 4.5 illustrates
multiple claims from a single declared flight. It
seems to say a Diamond goal may be claimed between
two declared turnpoints which are neither start nor
finish, but elements in a more complicated course.
In the given example, if I read it right, the 'goal'
is not the finish point...perhaps I am not the only
one confused here ?
Should we call in the lawyers ?
Ian
At 15:24 10 October 2004, Eric Greenwell wrote:
Mark Zivley wrote:
But what do you store in your logger as your task?
For 300k diamond
goal you would need to have both the O&R and the finish
point included.
You can't have both points in the task for the state
record 'goal'.
It's not required that the declaration be in the logger,
though that can
be the most convenient at times. For a dual declaration,
the easiest
would be two paper ones, or perhaps one in the logger,
one on paper. If
you had two loggers, you could do it that way.
Change 'netto' to 'net' to email me directly
Eric Greenwell
Washington State
USA
Old October 11th 04, 06:20 AM
Eric Greenwell
Only the most recent declaration is valid. The electronic declaration
can be made well before the takeoff (even months), and can be superceded
by a more recent declaration on paper. The paper one requires an
official observer to be valid; the electronic one doesn't (at least for
the recorders I am familier with).
Eric Greenwell
Washington State
USA
Old October 11th 04, 06:32 AM
Eric Greenwell
Mark Zivley wrote:
But what do you store in your logger as your task? For 300k diamond
goal you would need to have both the O&R and the finish point included.
You can't have both points in the task for the state record "goal".
Use paper declarations instead an electronic declaration, or carry two
loggers, one for the state record and one for the badge.
Eric Greenwell
Washington State
USA
Old October 11th 04, 08:34 AM
Judy Ruprecht
At 03:12 09 October 2004, Eric Greenwell wrote:
you should be able to have two declarations, one for
SSA and one for the FAI. I don't know if anyone has
tried this, but the
FAI badge rules and SSA State record rules don't prohibit
declarations
that aren't for their purposes.
Hmmmm. Don't bet the farm on it. State Record Rules
follow FAI Sporting Code requirements for World Records,
except as specifically amended for State Records. (State
Record Rules are online on the SSA web page, under
'Badges & Records' at the 'forms' link.)
I don't see an excption on the one-to-a-customer/last-one-before-t
ake-off approach to declarations.
Da Badge Lady
Old October 11th 04, 10:45 AM
Edward Downham
I would agree with the other posters here about only having one declaration. I
would be rather concerned (as an OO) if someone leafed through a bunch of
declarations before handing me the 'right' one...
However, my interpretation of the regulations for record/badge claims is this:
You can claim as many 'performances' as you like from one flight, as long as
they meet the criteria set down. You could declare a 1000Km triangle and if you
took over 5hrs to complete it and gained 5000m on the way round, you could
claim your Silver, Gold and Diamond badges plus the 1000Km Diploma.
In terms of records, this is true as well. If you take a particular segment of
the flight and it qualifies _in its own right_ for a soaring performance, then
you can claim it. The only exception I can find is this:
"3.0.2 Records in any one flight.
Any record or records may be broken in any one flight for which the
requirements
are met, except that only one speed record may be certificated for a flight
over a triangular or out and return course, the record being certificated for
record distance immediately less than the official distance of the flight."
So I take that as meaning I could declare a 3-TP quadrilateral 500Km, and claim
everything up to and including Diamond Distance (see SC-3 4.5). If I carried on
in the same direction-ish, and landed much further away I could maybe claim a
free distance record. I could also claim a 300Km triangle speed record and
maybe even a 100Km goal record, if it complied with the 1000m rule and crossed
a synthetic finish line/ FAI sector. And so on.
I think there is confusion over the application of the terms START, FINISH &
GOAL. I look at these in relative terms when considering a particular
performance from a flight segment. I don't decide on what they are then fix
this for all evidence related to that flight.
For instance, it's well known you can claim Silver Distance from one leg of a
triangle, provided you comply with the 1000m rule (assuming 100Km leg) or take
the penalty. You also have to prove a valid start & finish - at least one of
these will start off as a TP in the declaration and no-one seems to have a
problem with that...
Old October 12th 04, 12:48 AM
Eric Greenwell
tried this, but the
declarations
They do include FAI rules by reference, but USA State Records are not
FAI records in any way, and the FAI has no control over them at all.
Perhaps it's about what a "declaration" is: if it's on paper, the FAI OO
has to sign it; if it's in the logger, the logger validates it, but the
FAI OO has to verify the logger is on board glider during the flight.
So, you can have a suitcase full of papers with all kinds of tasks on
them, but none qualify as declarations because they aren't signed by the
OO; similarly, you could carry several loggers, but if they aren't
verified as "on board" by the FAI OO, they are irrelevant. I don't know
of any restriction in the FAI rules on that suitcase full of tasks or
carrying more than one logger.
I think it's just a piece of paper until you point at it and say "that's
the declaration for my FAI badge flight attempt", and that's what it
becomes. If you point to another piece of paper and say "that's the
declaration for my Washington state record flight attempt", you aren't
making an FAI badge flight declaration.
I see no reason to prohibit concurrent declarations for things like
state records, club ladders, and so on. If the FAI rule about a single
declaration was intended to prohibit declarations for all non-FAI flight
purposes, they should explicitly state that, but as written, I think the
ban only applies to declarations for FAI purposes.
Eric Greenwell
Washington State
USA
Old October 15th 04, 08:21 AM
John Gilbert
Eric Greenwell wrote in message ...
tried this, but the
declarations
The (USA) State record rules say "Except as provided by these rules,
State Records shall comply with the FAI Sporting Code, Section 3
("SC3") and to the additional requirements of Section 6.0 below."
In the Sporting Code Section 3, Chapter 4.2.2 Declaration Validity,
paragraph a. "The last declaration made before takeoff is the only one
valid for the flight, but a concurrently flown and different
competition task is allowed."
So I don't see any way that more than one (valid) declaration can
exist for a flight AND still comply with the Sporting Code. Either
the one in the flight recorder is the last one made, or the paper one
is the last one made. Maybe you can talk an OO into verifying a flight
with two "valid" declarations, but I think it is not in the intention
of the rules to do so. It ain't, well, sporting.
Regards,
John
PS Volkslogger (and other?) flight recorder owners need to be aware
that the Volkslogger will automatically declare the most recently
stored declaration before each following flight, when power is turned
on. If you declare on paper, then climb in the glider and take off,
the last valid declaration will be in the flight recorder. You need to
declare on paper, after you power up the Volkslogger.
Old October 15th 04, 04:39 PM
Ian Cant
In the case of the Colibri, the declaration is made
automatically when logging starts, which is when you
reach forty knots or so on the takeoff roll. A little
hard to make [and photograph ?] a paper declaration
after that..?
Ian
Validity,
paragraph a. 'The last declaration made before takeoff
is the only one
different
competition task is allowed.'
can
Code. Either
or the paper one
verifying a flight
with two 'valid' declarations, but I think it is not
in the intention
Regards,
John
need to be aware
most recently
power is turned
and take off,
You need to
Old October 15th 04, 09:06 PM
Tom Serkowski
It may be copied into the flight log, but I doubt the declaration time
is changed to the current time. The time of the declaration should be
the time at which you pressed "save" when originally making it.
If you then make several flights, all will have this same declaration
time.
-Tom
(John Gilbert) wrote in message . com...
Old October 16th 04, 04:42 AM
Ian Cant
Todd,
You are absolutely correct that the pilot,
not the instrument, makes the declaration. Nevertheless,
'electronic declarations' do exist and are accepted
by the FAI. And the content of a full declaration
includes the date of flight, not just the date at which
the pilot defined the task. Quoting from my Colibri
manual 'the selected task is automatically declared
after takeoff'. This declaration, even though it is
implemented by the instrument, is acceptable for FAI
purposes. So if it exists, it is the latest declaration.
Agreed, the pilot may make paper declarations after
entering the FR task but before the flight, but if
he wants to make the paper declaration valid it is
his responsibility to deselect or disable the electronic
one prior to takeoff. And since the FR data is required
to document the flight, it is hard to pretend that
any associated electronic declaration does not exist.
I guess that if someone really wanted to flex the
spirit of the rules, he could carry a sheaf of paper
declarations and have several FRs running, then decide
after takeoff which one he wanted to use today - then
the latest declaration would be the one in the pilot's
head as he started his task, or maybe what he recalled
postflight as his last pre-start intention ??
Soaring season must be winding down.
Ian
after that..?
Ian
Only a pilot can make a declaration, not a Colibri.
The
declaration was made when the pilot entered data into
Colibri. That declaration could be superseded by a
subsequent paper or electronic declaration, regardless
of
what the Colibri does at 'forty knots or so on the
takeoff
roll.' :-)
Todd Pattist - 'WH' Ventus C
(Remove DONTSPAMME from address to email reply.)
Run up for plug clearing Roger Long Piloting 78 October 18th 04 03:39 AM
FAI Sporting Code Section 3 experts wanted Stewart Kissel Soaring 28 September 1st 04 05:58 PM
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 05:18 AM
Winscore source code now available Guy Byars Soaring 0 February 5th 04 10:43 AM
Need Help with Northstar M1 Loran Jerald Malin Owning 4 December 8th 03 05:38 PM
