CAI 302 repair advise needed
Old October 17th 04, 05:18 AM
Jamey Jacobs
Default CAI 302 repair advise needed
The adjustment knob on the lower left of my 302 came loose today. It
was still attached to the metal rod that goes into the instrument and
it appears that a set-screw came loose from the far end of the rod.
Has anyone had this same failure?
Does you know if I can easily repair this or does it require breaking
some quality / calibration seal to get inside the case? I don't want
to take my panel apart thinking I can fix it before I fly Monday, if I
really should plan on sending it back.
Old October 17th 04, 02:39 PM
Mark Zivley
Take a small knife and carefully pry the very end of the knob off. The
seam may be hard to see, but there is a cap on the foremost portion of
the knob. Once you get the cap loose that will expose a screw down
inside the knob. Tighten that up and it will probably fix your problem.
No need to dig farther or even remove the unit from the panel.
Careful that the cap is small and can get away from you!
Old October 18th 04, 04:22 AM
Andy Durbin
Mark Zivley wrote in message om...
I don't think you read what he said. Sorry it's going to be opened up
and that will require factory or dealer re-seal.
Andy
Old October 18th 04, 01:14 PM
Mark Zivley
I did read what he said. I think he just might be mistaken as to where
the knob is loose. He may have assumed it was something inside the unit
not realizing the knob is designed to come off for installation....
Andy
Old October 18th 04, 06:00 PM
Paul Remde
Hi Jamey,
If the rod came loose out of the box with the knob you will have to send it
back to Cambridge or a dealer for repair. The repair requires opening the
unit and re-sealing it.
I'm a dealer and I would be glad to fix it for you as long as that is OK
with Cambridge (I think it will be). But sending it back to the factory
would be just as fast and they may even pay the return shipping for you (I'm
not certain).
I've seen the problem only once before on an early 302 in the Ventus I used
to own. It was fixed quickly by Cambridge. If I remember correctly they
fixed it for free while doing the calibration (not free).
You can get the contact data for the factory from their web site he
http://www.cambridge-aero.com
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Jamey Jacobs" wrote in message
om...
Old October 19th 04, 03:06 AM
Jamey Jacobs
Thanks for your recommendations. The set screw deep inside the
instrument came loose, and the knob and shaft came out as one piece.
I removed the instrument from the panel and could hear the set screw
shaking around inside the case.
Cambridge told me not to operate the instrument while trying to use
the loose rod, if it shifted wrong, it (or the loose set screw) could
short a circuit board and cause damage requiring $$$ repairs. It's
going back to CAI to be fixed and re-sealed.
I'm posting this to warn others if their CAI 302 adjustment knob comes
loose and the shaft is still attached, you need to turn off the vario
to avoid possible damage due to shorting internal components. At
least, carefully remove the knob and rod if you are still flying.
(Jamey Jacobs) wrote in message . com...
De-ice boot repair gbessert Owning 3 August 29th 17 07:30 PM
Advised on FAA Repair Station outside USA tbm700 Owning 0 September 23rd 04 05:50 PM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 03:09 AM
Terra Switch repair George A. Graham Home Built 1 October 25th 03 12:15 AM
Cambridge Aero: Repair Situation Update Chip Bearden Soaring 2 October 2nd 03 06:56 PM
