A tragedy - a Minden death today!
Old October 27th 04, 06:35 PM
Steve / Sperry
I think a better comparison is a car heater. It utilizes the
antifreeze and operates below boiling temperatures. I would think that
the oil temps would be greater than the water temps.
I would assume that at some point the oil will be hot enough to flow
through the oil cooler and not bypass the oil cooler.
So as long as fresh air is used to cool the oil cooler, the heat could
be directed into the cabin with an air bypass on the egress side of
the oil cooler. Or a second oil cooler could be installed in the cabin
with a heater box that could open or close an air vent.
I agree with the concern of running the air past the muffler. For that
reason I disconnect the air duct from the muffler to the heater
system. In the areas that I fly it does not get cold.
Exhaust heaters are beyond my margins for safety.
Steve
On Wed, 27 Oct 2004 09:17:19 -0400, Todd Pattist
(Ulrich Neumann) wrote:
Not quite so, Ian. The oil cooler would always be cooling the oil,
just what you do with the warm air downstream from it is the issue. A
simple vane valve diverts the warm air either into the cabine or out
into the atmosphere. Simple and light-weight!
Not so simple or light. Oil runs at a far lower max temp
than exhaust. It's also far more viscous, especially when
cold. To get comparable heat transfer you would need to
provide much more surface area than an exhaust muff. That
means more weight. You'd probably need to run the oil
through a heat exchanger, which means forcing viscous oil
through small diameter heat exchanger tubes. Of course, you
can't do that until the oil is hot, so you'd probably need a
bypass system and you've got to be careful not to block up
the heat exchanger tubes, stop oil flow and blow the
engine.
Todd Pattist - "WH" Ventus C
(Remove DONTSPAMME from address to email reply.)
Old October 27th 04, 06:43 PM
Tony Verhulst
Which is why the Sylane that I own (a small piece of) has a very good
electronic Carbon Monoxide dectector.
Tony V
Old October 27th 04, 08:32 PM
nafod40
Do these motors have generators or alternators of some sort? An
electrically heated seat (think heating pad) might not be a bad idea.
Old October 27th 04, 11:08 PM
Ian Cant
But I get cold feet at the thought of sitting in the
hot seat..
Ian
sort? An
not be a bad idea.
Old October 28th 04, 03:23 AM
COLIN LAMB
"Do these motors have generators or alternators of some sort? An
electrically heated seat (think heating pad) might not be a bad idea."
Electric heating is inefficient. Any energy used in heating a seat would
directly subtract from energy available for a climb. 10 amperes would
provide 100 watts of electric seat heating, however that is the easiest part
of the body to insulate without additional heat.
Although this thread seems to fear heat from the exhaust system, most of the
small aircraft use this method and FAA statistics indicate that it is the
cause of only a small percentage of the accidents. It is even less likely
to occur on a new exhaust manifold. A simple carbon monoxide detector can
alleviate concerns over this danger. My motorglider gets cabin heat over
the exhaust and that is a small concern. My biggest concern is the person
sitting in the front seat, as statistics generally point to them as the weak
link.
Colin N12HS
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.783 / Virus Database: 529 - Release Date: 10/25/04
Old October 28th 04, 03:49 AM
Jim Vincent
Sorry People, I had to rename this thread...it is rather off topic and does not
reflect the sensitivity the original postings had.
Jim Vincent
N483SZ
illspam
Motor-glider fatality at Minden today? Stewart Kissel Soaring 0 October 24th 04 03:19 AM
~ US JOINS CHINA & IRAN AS TOP DEATH PENALTY USERS ~ Matt Wiser Military Aviation 0 April 8th 04 02:55 PM
About death threats and other Usenet potpourri :-) Dudley Henriques Military Aviation 4 December 23rd 03 07:16 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
