#31
"goneill" wrote: You need to be "very very" quick on release if the down wing does not move forward with the winch launch as the upper wing starts flying and lifts up and can throw the glider/you into an end over end cartwheel, You don't start with a "down wing". You prop the wings so they're level. - mark |
#32
CV wrote: Bill Daniels wrote: Instant roll control and no prop wash to deal with. Actually, the prop wash will help, by providing some airflow over the wings and control surfaces, giving you a certain degree of control, even before the speed builds up. We're talking about a winch, CV. You don't have to wait until the speed builds up :-) - mark |
#33
Mark Newton wrote:
You don't start with a "down wing". You prop the wings so they're level. I always start with a "down wing" when being alone. No problem whatsoever. Stefan |
#34
The point is this "cartwheel scenario" has happened before.
I believe there was a case in Europe not that long ago. gary "Mark Newton" wrote in message ... In article , "goneill" wrote: You need to be "very very" quick on release if the down wing does not move forward with the winch launch as the upper wing starts flying and lifts up and can throw the glider/you into an end over end cartwheel, You don't start with a "down wing". You prop the wings so they're level. - mark |
#35
![]() "goneill" wrote in message ... The point is this "cartwheel scenario" has happened before. I believe there was a case in Europe not that long ago. gary Indeed! If a wing tip catches on something like tall grass, the combination of high acceleration and CG hook can be disastrous. This sometimes results in a flick roll and inverted crash. This is why the takeoff area of winch operations needs to be smooth and the pilots 'spring loaded' to release if the takeoff roll swerves. If the takeoff surface was smooth asphalt and the glider had tip wheels or low-friction skids then starting with a wingtip propped up on a stand or box might not be so dangerous. It pays to be careful though. Let me add just how sweet it is to accelerate and lift off without the turbulence, noise and dust of a tow plane. Compared to air tow, a winch launch area is downright civilized. Bill Daniels |
#36
Having ground looped once on a winch launch (inexperienced wing runner and
tall grass) I doubt I would ever consider this on grass or dirt. A paved surface might be okay with a very experienced pilot. A wings level assist would be good, but might be moot if the up slack just pulled the glider off the leveler. Holding a glider with airbrake/wheelbrake combo level doesn't seem prudent. The more bothersome aspect is the lack of another set of eyes to visually check the launch zone for encroachment. Think I'd prefer to file this in my never do list (from a winch driver perspective). 'Never winch launch unassisted' 'Never winch launch downwind' Frank "goneill" wrote in message ... The point is this "cartwheel scenario" has happened before. I believe there was a case in Europe not that long ago. gary "Mark Newton" wrote in message ... In article , "goneill" wrote: You need to be "very very" quick on release if the down wing does not move forward with the winch launch as the upper wing starts flying and lifts up and can throw the glider/you into an end over end cartwheel, You don't start with a "down wing". You prop the wings so they're level. - mark |
#37
We had it happen here a few years ago.
A very experienced pilot and single ground crew driving our tow car on a week day with no one else around. The glider was totaled and the pilot suffered serious injuries. Maybe ok in a 2-33. I got away with it once in an SHK but I don't think I would try it again. Cheers! "F.L. Whiteley" wrote in message ... Having ground looped once on a winch launch (inexperienced wing runner and tall grass) I doubt I would ever consider this on grass or dirt. A paved surface might be okay with a very experienced pilot. A wings level assist would be good, but might be moot if the up slack just pulled the glider off the leveler. Holding a glider with airbrake/wheelbrake combo level doesn't seem prudent. The more bothersome aspect is the lack of another set of eyes to visually check the launch zone for encroachment. Think I'd prefer to file this in my never do list (from a winch driver perspective). 'Never winch launch unassisted' 'Never winch launch downwind' Frank "goneill" wrote in message ... The point is this "cartwheel scenario" has happened before. I believe there was a case in Europe not that long ago. gary "Mark Newton" wrote in message ... In article , "goneill" wrote: You need to be "very very" quick on release if the down wing does not move forward with the winch launch as the upper wing starts flying and lifts up and can throw the glider/you into an end over end cartwheel, You don't start with a "down wing". You prop the wings so they're level. - mark |
#38
In article grOkd.76520$HA.7455@attbi_s01, Bill Daniels
writes Let me add just how sweet it is to accelerate and lift off without the turbulence, noise and dust of a tow plane. Compared to air tow, a winch launch area is downright civilized. Bill Daniels Although not as civilised as a bungee launch... -- Mike Lindsay |
#39
You want quiet launch?
Shoulder launch from the Mynd is pretty quiet, I am told. GA |
#40
"F.L. Whiteley" wrote:
Having ground looped once on a winch launch (inexperienced wing runner and tall grass) I doubt I would ever consider this on grass or dirt. A paved surface might be okay with a very experienced pilot. A wings level assist would be good, but might be moot if the up slack just pulled the glider off the leveler. Holding a glider with airbrake/wheelbrake combo level doesn't seem prudent. The more bothersome aspect is the lack of another set of eyes to visually check the launch zone for encroachment. Think I'd prefer to file this in my never do list (from a winch driver perspective). 'Never winch launch unassisted' 'Never winch launch downwind' Frank By us there is no wing runner for winch launch, only a wing holder. The acceleration is so that nobody would be able to follow the glider, nor any vehicle whose propulsion relies on friction on the ground, since the friction coefficient will never be sufficient to provide such an acceleration. So the wing holder could easily be replaced by any object (wing stand, tyres heap, etc.) having the same function, although we never do it because we want to keep the watching capability of the wing holder. |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Vandenberg Launch, April 17 | Piloting | 5 | April 9th 04 02:21 AM | |
Ground launch and the incremental vanishing of soaring | Mark James Boyd | Soaring | 24 | March 8th 04 10:50 PM |
Pegasus/TRACE Launch Photos Posted | Brian Webb | Military Aviation | 0 | February 21st 04 03:50 PM |
Friendly fire pilot may testify against wingman | Otis Willie | Military Aviation | 0 | October 11th 03 09:32 PM |
