#101
Bob Kuykendall wrote:
I tend to believe that the legacy of span-limited competition classes is such that sailplane buyers will tend to gravitate towards competition spans, even those with very weak inclination to ever compete. That's one of the reasons I'd like to see a distinct competition class for sub-15m ships; and I think that 13m would be a perfectly good place to draw the line. This effect should not be an issue here, since we are talking about performance identical to an LS4. So, it would do exactly as well in any contest as an LS4. I don't know if it would be immediately accepted into the club class since I'm not familiar with the rules, but if has the same performance as an LS4 and the same price, why not? A 13-meter class would collect all the Russias, Apii (Apia?), PW5s, and Sparrowhawks, though sadly leave the 14m L33 (TG-10D for USAFAians) out in the cold. It would give people at least a plausable excuse to buy these little gliders, and give developers an economic basis for developing them. And I think that it would be a kick-ass fun class to fly in, since I'm just the right size for it and I'm used to flying a few points short of a Libelle. I like the idea of encouraging smaller gliders with a class, but I'm more in favor of "performance bracket" classes than span classes. THe European club class is such a class. By handicapping over a small range of performance, say 10%, it's easier to accommodate performance differences fairly. Instead of the Sports Class we have in the US, I'd like to see something like "Sports A" (handicaps from 1.05 and up), and "Sports B" (handicaps from 1.04 and lower). Or maybe 3 classes? -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#102
Robert Ehrlich wrote in message ...
Kirk Stant wrote: ... I must be the only guy who thinks Rutan's designs are ugly and over-optimized. ... Certainly not, concerning the optimization. See http://inter.action.free.fr/publicat...ds/canards.htm Sorry, it is in French. Merci, c'est interessant! Eh oui, un amerloque qui parle Francais...et qui a vote pour W. Kirk |
#103
At 15:36 11 November 2004, Andreas Maurer wrote:
Frankly spoken, I doubt that this is possible without major compromises concerning cockpit size and crash protection. I need a certain cockpit cross-section to be able to sit comfortably, so the cross-section of the fuselage (which defines most of its drag) is fixed, independent of the wing span. Fuselage surface area is also fixed.... One solution could be to build the whole glider extremely light (like the Apis or Sparrowhawk) to get normal wing loadings of about 33 kg/m^2 at a high aspect ratio, but this is going to result in the inability to carry water, low Vne (hence the comparably bad penetration of the Apis compared to club class gliders with similar L/D and wing loading) and questionable crash protection. The Sparrowhawk and Apis look really good and are definitely state of the art - but to be honest, I would not like to rely on their cockpit shell strength when I impact at 50 kts or above. As to the question of fuselage integrety in smaller, lighter gliders the Apis manufactures seem to have given this some thought. See: http://www.albastar.si/ and look under construction on the menu bar Mike |
#104
At 02:12 12 November 2004, Mike Ziaskas wrote:
At 15:36 11 November 2004, Andreas Maurer wrote: Well, Andreas wrote to the effect that he did not want compromise in fuselage crashworthyness in the lightweight gliders (MZ) As to the question of fuselage integrety in smaller, lighter gliders the Apis manufactures seem to have given this some thought. See: http://www.albastar.si/ and look under construction on the menu bar Mike Mike Z |
#105
#107
I would always choose the 15 meter glider.......following what you have been
saying the 15 meter would then not be the "same" performance as the 13 meter glider.....but better! Also.having flown a lot of different types of glider and airplanes over several years, including some ultra-lite or 'lite" types there is still no way to compare these with the extra mass and groovy feeling of the (for the lack of a better word) real sailplanes..... tim "Eric Greenwell" wrote in message ... Erik mann wrote: What is it that economists always throw out... ceteris paribus... I agree that if one started with a clean sheet of paper, then maybe you can lop off a few pounds on the fuselage, change the planform, etc. (though, having looked at the structure of some of these ships, I'm not so sure I would want to fly them or land them off-field... but I digress). Keeping everthing else equal, is the "best" use of engineering to start with a shorter span as a design goal? Maybe it is, as the weight savings on the spar and carry-through structure allows for a good range of wingloading while bringing along the other benefits mentioned elswhere (ease of assembly, transport, etc.)? Or, maybe the design goal should be 40:1 performance at the lowest cost, irrespective of span? That was my proposed goal: LS4 performance at the lowest manufacturing cost. The obvious solution will be a smaller glider, made possible by the improved aerodynamics, design, and materials that became available in the 24 years since the LS4 was designed. A few have suggested 40:1 is not possible at less than 15 meter span, but when 15 meter spans can now do 48:1 or better, this is not sensible. Most people that have objected to this smaller span solution have done so mainly on the "it doesn't cost THAT much more to ..." grounds; i.e., proposing a more expensive glider than one that will just match the LS4. This might indeed yield a more viable product, but it doesn't meet the goal of a "cheaper LS4". Which would you prefer, at the same price: a new LS4, or an new 13 meter with identical performance, handling, and safety? I would choose the 13 meter glider, but many/most would not, even though it's smaller size and lighter weight would make it easier to rig, to push around, to retrieve, to tow (in it's trailer or behind a tow plane), even to wax! Old habits and dreams die slowly, I think. Glider pilots are mostly a very conservative bunch. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#108
#109
Eric Greenwell wrote:
A few have suggested 40:1 is not possible at less than 15 meter span, but when 15 meter spans can now do 48:1 or better, this is not sensible. Now we're getting to the crux of the matter. In order to continue this discussion, we need to avoid comparing apples to oranges. The 40:1 best L/D performance that you're seeking to match for an LS4 equivalent is the actual Johnson-tested and verified best glide performance of the LS4. It really does go 40:1 at best glide. I can't remember what the factory claimed for it, but it is probably on the close order of 43:1, right in the ballpark of what I'm claiming for the HP-24. The 48:1 best L/D performance that you say that 15m ships can do or better is just a claim. It is salesspeak. It is not verified by any impartial body. It is, in my mind at least, false until demonstrated true. When a well-designed 18 meter ship like your ASH-26E can barely hit 50:1, even when you feather in the squeakiest data points, you just have to wonder how good you really can do with three whole meters less. Now, I'm not going to say that I think that 48:1 or 50:1 is outside the realm of possibility for a 15m ship. But I will say that I don't see it in the impartial test reports that I have read. And I will note that this is a pretty sore topic with me. I'm developing a 15/18m sailplane for which I have released what I think is a reasonable best L/D claim. It has a well-designed wing, courtesy of my Stanford phd friend who does low-speed aero engineering for NASA Ames and campaigns in 15m national competition. So I think I have good reason to believe that my ship will meet my claims. And I also have a pretty good idea that there's no magic out there that is going to let you pull 50:1 out of 15 meters like you'd extract a rabbit from the eye of a needle. As for real, tested best glide performance available from a 15m ship, a good example is the Ventus. When Johnson tested the Ventus A in 1981, he got 45:1 out of it. Just incredible. Not many people were particularly enamored of its handling characteristics, but it went like stink. And after 15 years of evolution that produced a new fuselage and a new wing, Johnson tested the Ventus again in 1996 - this time the 2B model. His results show that the best L/D increased an entire negative 1 to 44:1. It was definitely a nicer glider, with the auto-connects and nicer cockpit and other improvements, but somehow the best L/D didn't go up. Going forward, I propose that if we're going to be tossing a lot of best L/D claims around, that we restrict ourselves to tested, verified best L/D performance values, for example the idaflieg or Johnson results. Otherwise I'm just going to have to join the Liar's Dice game and claim a patently unobtainable 50:1 for the HP-24. And I'd like to think of myself as a more honest person than that. Thanks, and best regards to all Bob K. http://www.hpaircraft.com |
#110
Going forward, I propose that if we're going to be tossing a lot of best L/D claims around, that we restrict ourselves to tested, verified best L/D performance values, for example the idaflieg or Johnson results. Otherwise I'm just going to have to join the Liar's Dice game and claim a patently unobtainable 50:1 for the HP-24. And I'd like to think of myself as a more honest person than that. How about the L/D ten years later after 1000 hours of exposure in the sun, 300 assemblys by trained monkeys, blowing dust and sand over the wings, and repeatedly forcing the canopy and gear up and down? I think there are more interesting questions than just some L/D figure. Does polyurethane keep airflow better after years of the conditions I just described than other finishes? How about wing flexing causing cracks? Do longer wings inevitably mean more cracks unless they get another $10k worth of finishing? Is a side opening canopy going to deform (like our L-13 canopy) over the course of many years? How heavy/sturdy does a canopy frame need to be to maintain it's shape (I remember watching Bob look at the HP canopy frame matching to the body with a careful eye)? And who sells a glider that has parts that don't fit flush with the disclaimer "in a year or two the parts will stretch and fit perfectly"? So I personally don't look too hard at the L/D by itself. The stall speed, the 80 knot sink speed, the possibility of ballast, and the tradeoffs of flaps vs. no flaps and how this is integrated, and retract gear, seem to be better indicators than some number. A glider with 1000+ hours, no refinish or new parts since manufacture, and then a flight test, is what I'm talking about. If it beats 350 fpm sink at 80kts, and stalls under 35kts at MGW, then it's time to move on and ask about other flight characteristics (stall/spin like SZD 50-3 and tricky takeoffs like PIK-20). In this sense the World Class concept I think was apt, because the goal was not L/D (perhaps with the knowledge that waviness and rough handling would negate the cost put into a high L/D anyway). -- ------------+ Mark J. Boyd |
New flying books from Germany | ArtKramr | Military Aviation | 0 | July 3rd 04 02:40 PM |
New War publications | ArtKramr | Military Aviation | 0 | December 20th 03 01:47 PM |
New Military Aviation Books from Germany | ArtKramr | Military Aviation | 0 | November 23rd 03 11:43 PM |
New Military Aviation Books from Germany | ArtKramr | Military Aviation | 0 | October 29th 03 02:33 AM |
New WWII books from Germany | ArtKramr | Military Aviation | 0 | October 13th 03 12:54 AM |
