Excel Formula minutes convert to hours
Old December 12th 04, 11:20 AM
Mal
Default Excel Formula minutes convert to hours
Hi does anyone know the formula for excel so it will add the minutes after
the decimal and convert them to hours.
Need to check my log book times and make a database off information types
flown etc.
EG
1.33
1.56
=2.89
Needs to say 60 mins is one hour
so
1.33
1.56
=3.29
=SUM(E1:E23)
=IF(A31000,TIMEVALUE(LEFT(A3,1)&":"&RIGHT(A3,2)),T IMEVALUE(LEFT(A3,2)&":"&RIGHT(A3,2)))
The formatting of the cells in column B is HH:MM.
Thanks Mal
Old December 12th 04, 11:54 AM
André Somers
Try a newsgroup dedicated to Excel... The fact that this is about adding up
your logbook does not make it less off-topic.
André
Old December 12th 04, 11:58 AM
CV
I found it easier to do hours and minutes in separate Excel columns.
Say J is the hours column and K is minutes for each entry.
Then we sum up total hours, including decimal fractions of hours,
in a hidden L column:
L10=L9+J10+K10/60
(note: L9 was the previous total, before this entry)
Then the total time in hours and minutes is represented in
column M (hours) and N (minutes) respectively:
M10=INTEGER(L10)
N10=L10*60-M10*60
Cheers CV
Old December 12th 04, 02:35 PM
OscarCVox
Why not format the cells to a time format thus-
Format - cells - time - 37:30:55
This will give time in hours minutes and seconds that can be added
Old December 12th 04, 02:47 PM
Keith W
"CV" wrote in message
after
L10=L9+J10+K10/60
M10=INTEGER(L10)
N10=L10*60-M10*60
Cheers CV
At the risk of being too trivial, if the figures are already input, can
split them by:
say hour:mins in A1, put B1=INT(A1) (gives hours in B1), C1=(A1-B1)*100
(gives minutes in C1)
Keith
Old December 12th 04, 05:07 PM
Peter Seddon
"OscarCVox" wrote in message
Sorry excell dont work like that. If you try to enter say 1hr 30min as 1.5
it trys to use it as a date function and displays 12:00:00 and if you try to
add times it treats them also as dates such that 12:00:00 + 12:00:00 =
0:00:00.
I use two columns and add one mod 60 etc.
Peter.
Old December 12th 04, 05:23 PM
Vaughn
"André Somers" wrote in message
I respect your opinion André, but I must disagree. I have had exactly this
problem for years, and have gotten around it in various (mostly unsatisfactory)
ways. I therefore find the subject very interesting and topical.
If we were talking about painting gliders would you consider that also
something OT to be taken to some paint newsgroup?
Vaughn
André
Old December 12th 04, 06:00 PM
BTIZ
I formatted the cell to "Time" and display hh:mm
Then when you "SUM" the column, the math is correct.
to get the totals to total a large number of hours.. like 310:20 (310 hrs
20 minutes) log book total.. you will need to pick the hh:mm:ss format. the
display will now read 310:20:00
BT
"Mal" wrote in message
flown etc.
EG
1.33
1.56
=2.89
so
1.33
1.56
=3.29
=SUM(E1:E23)
Thanks Mal
Old December 12th 04, 06:05 PM
BTIZ
sorry... excel does work like that... you have to format the time..
and don't use decimal to denote minutes.. 1.30 is not 1hr 30 min, 1.5 is
one hour thirty minutes.. or format the cell to TIME, and 1hr 30 minutes is
1:30
BT
"Peter Seddon" wrote in message
to add times it treats them also as dates such that 12:00:00 + 12:00:00 =
0:00:00.
Peter.
Old December 12th 04, 07:21 PM
CV
split them by:
Yep, that would do the job for one single entry.
However it would not allow you to add two or more
entries to make a total.
To keep a running total of your flying time
you need something a bit more elaborate.
CV
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
Excel formula for logbook Wizard of Draws Instrument Flight Rules 11 August 30th 04 12:55 AM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
