O.K. another painting question:
All aluminum sailplane, newly constructed. 1. Scuff with Scotchbrite pads, two part epoxy primer, wet sand, paint? or... 2. Two part acid etch wash primer, epoxy primer, sand and paint? or... 3. Your recommendation I was once told by a venerable aircraft builder to attempt to use a paint process like the Schweizers (sailplane fame)used but cannot find out what that process was/is. He said that it was subcontracted to Grumman and they "got it right". And, where does Zinc Chromate fit into the picture in terms of the paint process. Confused as ever. Clark |
Stealth Pilot wrote in message . ..
On 3 Dec 2004 07:03:49 -0800, (c hinds) wrote: O.K. another painting question: All aluminum sailplane, newly constructed. 1. Scuff with Scotchbrite pads, two part epoxy primer, wet sand, paint? or... 2. Two part acid etch wash primer, epoxy primer, sand and paint? or... 3. Your recommendation I was once told by a venerable aircraft builder to attempt to use a paint process like the Schweizers (sailplane fame)used but cannot find out what that process was/is. He said that it was subcontracted to Grumman and they "got it right". And, where does Zinc Chromate fit into the picture in terms of the paint process. Confused as ever. Clark scuff lightly with scotchbrite. dilute phosphoric acid wash. alodine to passivate the surface. primer top coats. Stealth (watch your finger prints) Pilot This is the perfect answer.. he is also correct about the fingerpronts, always wear gloves and happy painting.... |
I'm still confused and I must have read every painting book out there, the
best of which is "How to Paint Your Car"/ www.motorbooks.com ..... however it doesn't say anything about preping a plane. For that I look at what's available from Aircraft Spruce and I wonder if the following is a good idea........ 1) Clean w/ Alumiprep #33 - Use to clean, brighten and transform badly corroded aluminum to its natural appearance. or, 1) Metal prep #79 - A brush-on, wipe-off aluminum cleaner and paint preparer in one powerful, easy-to-apply formulation. It etches the metal, neutralizes hand mards, is smutless on alloyu surfaces, removes oil and grease and will not burn. It provides a firm and lasting adhesion between aluminum alloys and paint. 2) Alodine #1001 - An invisible coat to provide indepth corrosion proofing to the brightened aluminum surface and act as a firm barrier against the elements and continued corrosion. or, 2) Alodine #1201 - After precleaning w/ Alumiprep 33 or Metal Prep 79, rinse with water. Apply Alodine without dilution by brushing or swabbing w/ a sponge. Rinse with water and surface is ready for paint. This is a visible coating which leaves surfaces with a golden coloration. The alodized surface provides protection against weather and firmly bonds paint. 3) Acrylic urethane....... base coat, clear coat. What do you think? "Ben Haas" wrote in message m... Stealth Pilot wrote in message . .. On 3 Dec 2004 07:03:49 -0800, (c hinds) wrote: O.K. another painting question: All aluminum sailplane, newly constructed. 1. Scuff with Scotchbrite pads, two part epoxy primer, wet sand, paint? or... 2. Two part acid etch wash primer, epoxy primer, sand and paint? or... 3. Your recommendation I was once told by a venerable aircraft builder to attempt to use a paint process like the Schweizers (sailplane fame)used but cannot find out what that process was/is. He said that it was subcontracted to Grumman and they "got it right". And, where does Zinc Chromate fit into the picture in terms of the paint process. Confused as ever. Clark scuff lightly with scotchbrite. dilute phosphoric acid wash. alodine to passivate the surface. primer top coats. Stealth (watch your finger prints) Pilot This is the perfect answer.. he is also correct about the fingerpronts, always wear gloves and happy painting.... |
In article xEJsd.175583$cJ3.21636@fed1read06,
"larsen-tools" wrote: I'm still confused and I must have read every painting book out there, the best of which is "How to Paint Your Car"/ www.motorbooks.com ..... however it doesn't say anything about preping a plane. For that I look at what's available from Aircraft Spruce and I wonder if the following is a good idea........ 1) Clean w/ Alumiprep #33 - Use to clean, brighten and transform badly corroded aluminum to its natural appearance. or, 1) Metal prep #79 - A brush-on, wipe-off aluminum cleaner and paint preparer in one powerful, easy-to-apply formulation. It etches the metal, neutralizes hand mards, is smutless on alloyu surfaces, removes oil and grease and will not burn. It provides a firm and lasting adhesion between aluminum alloys and paint. 2) Alodine #1001 - An invisible coat to provide indepth corrosion proofing to the brightened aluminum surface and act as a firm barrier against the elements and continued corrosion. or, 2) Alodine #1201 - After precleaning w/ Alumiprep 33 or Metal Prep 79, rinse with water. Apply Alodine without dilution by brushing or swabbing w/ a sponge. Rinse with water and surface is ready for paint. This is a visible coating which leaves surfaces with a golden coloration. The alodized surface provides protection against weather and firmly bonds paint. 3) Epoxy primer to bond between the Alodinized aluminum and the top coat of paint. Old 3) becomes 4) 3) Acrylic urethane....... base coat, clear coat. What do you think? "Ben Haas" wrote in message m... Stealth Pilot wrote in message . .. On 3 Dec 2004 07:03:49 -0800, (c hinds) wrote: O.K. another painting question: All aluminum sailplane, newly constructed. 1. Scuff with Scotchbrite pads, two part epoxy primer, wet sand, paint? or... 2. Two part acid etch wash primer, epoxy primer, sand and paint? or... 3. Your recommendation I was once told by a venerable aircraft builder to attempt to use a paint process like the Schweizers (sailplane fame)used but cannot find out what that process was/is. He said that it was subcontracted to Grumman and they "got it right". And, where does Zinc Chromate fit into the picture in terms of the paint process. Confused as ever. Clark scuff lightly with scotchbrite. dilute phosphoric acid wash. alodine to passivate the surface. primer top coats. Stealth (watch your finger prints) Pilot This is the perfect answer.. he is also correct about the fingerpronts, always wear gloves and happy painting.... |
Has anybody pointed out that you had better make sure you know how your
aircraft was manufactured? Grumman used bonded aluminum to a honeycomb structure in some of its aircraft. Use the wrong stripper, etc, and you damage the bond risking failure. (So I've heard...) Don't know if anybody else uses this process... Carl "c hinds" wrote in message ... O.K. another painting question: All aluminum sailplane, newly constructed. 1. Scuff with Scotchbrite pads, two part epoxy primer, wet sand, paint? or... 2. Two part acid etch wash primer, epoxy primer, sand and paint? or... 3. Your recommendation I was once told by a venerable aircraft builder to attempt to use a paint process like the Schweizers (sailplane fame)used but cannot find out what that process was/is. He said that it was subcontracted to Grumman and they "got it right". And, where does Zinc Chromate fit into the picture in terms of the paint process. Confused as ever. Clark |
| Newbie Question, really: That first flight | Cecil Chapman | Home Built | 25 | September 20th 04 06:52 AM |
| A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 06:07 AM |
| Blasting and painting | [email protected] | Home Built | 7 | June 3rd 04 04:14 PM |
| Question | Charles S | Home Built | 4 | April 5th 04 10:10 PM |
| Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 02:51 AM |
