Cobra Trailer Hookup
Old January 10th 05, 06:17 PM
Default Cobra Trailer Hookup
Due to a senior moment, my cobra trailer became unhooked as I was
pulling it out of my back yard. The emergency trailer brake activated
and broke the safety chain I had installed as well as the trailer
wiring, fortunately all this happened at a very slow speed before I got
on the road and it was no big deal to repair.
I had not realized that if you are going to use a safety chain it
should be shorter than the cable which activates the emergency trailer
brake. Probably everyone knows this but I thought I would pass this
along.
The other bit of knowledge I wish I would have known before my first
towing trip is to remove or somehow secure the front wheel as it can
loosen and drop down to the road surface.
Old January 11th 05, 05:57 AM
keithw
The use of a single chain is also a dangerous thing to do and can lead
to an uncontrollable trailer swinging wildly behind your vehicle, or
worse tracking off in another direction throwing your vehicle out of
control . Trailers should all have TWO chains for this purpose, and
they should cross under the tongue in an X fashion . In the event that
the trailer should seperate from the vehicle the tongue will fall onto
the crossed chains and not the roadway , this keeps the trailer
tracking straight behind the tow vehicle . It prevents the tongue from
digging into the ground and last but not least it keeps the tongue of
the trailer from going up too far under your vehicle .
A number of safety chains sold on the market only have a single hook on
the end of the chain . This hook can fall out of place on rough roads
so a hook with a "gate" on it , or a different style of clasping
mechanism is prefered. Make sure that your chains can not contact the
road , this is especially inportant on gravel roads because the chains
can cause stones to fly up onto your trailer.
If in doubt contact a RV Dealer or a Hitch Shop .
keithw
Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ]
- A website for Australian Pilots regardless of when, why, or what they fly -
Old January 11th 05, 07:33 PM
I think removing, carrying and reinstalling the jack is too much
hassle.
I thread a chain through the jack's wheel housing and attach both ends
via a climber's snap clamp to the trailer's tow bar. Takes about 20
seconds.
Bela
Old January 12th 05, 12:02 AM
John Sinclair
I thought the same thing until I wore big flat spots
in 2 tires. It happens as you enter or leave gas stations.
Tow vehicle rear wheels drop into the low drainage
area at the curb, trailer wheel contacts pavement,
can't swivel because we pulled it all the way up and
locked it. BTW, I'm convinced this is the scenario
that over-stresses your trailer tongue and leads to
failure.
JJ
is too much
hassle.
attach both ends
Takes about 20
seconds.
Bela
Old January 12th 05, 02:16 AM
Bob Korves
"Eric Greenwell" wrote in message
Since the chain broke so easily, I suggest you install a much stronger
one. A trailer that comes off the towing vehicle will whip around and
apply much more force to the chain(s) than even fully applied brakes will.
I have done the same thing, Eric (installed strong chains), and I guess it
is good advice.
Note, however, that glider trailers are set up from the European factories
to not use safety chains at all. It appears that the idea in Europe is that
it is safer, if the trailer somehow releases from the tow vehicle, for the
brake to self apply via the cable. The loose trailer (and the other traffic
on the road!) can fend for themselves.
That concept is not legal here in the U.S. and I don't necessarily recommend
it, either. If you do agree with the European idea then it might be smart
to use the weakest chain that is legal where you are based...
-Bob Korves
Old January 12th 05, 03:58 AM
Eric Greenwell
is good advice.
-Bob Korves
I suspect the reason is the generally smaller vehicles that they use for
towing, compared to ours in the US. It might be safer for the trailer to
break loose than send the trailer AND the car flying into the oncoming
traffic.
Eric Greenwell
Washington State
USA
COBRA Skin Trailer Protector - Commercial John Seaborn Soaring 0 July 20th 04 05:38 PM
Cobra Trailer Axel Replacement Carter Soaring 7 July 7th 04 03:06 PM
Cobra Trailer Question Deputy Dog Soaring 7 January 3rd 04 04:11 PM
Cobra Trailer Soaring 1 September 28th 03 02:14 PM
Cobra trailer fittings for different glider makes & models John W Soaring 4 September 24th 03 04:21 PM
