			#11
gracias'
	KK wrote: Ken, the site looks great and I appreciate the way you presented the rules changes. thanks! OC  |
"Eric Greenwell"  wrote
	Can experimentally licensed aircraft (like my glider) legally install C91 units? I'm not clear on that, but there are plenty of places selling EBC-102a ELTs, so somebody must be able to use them. I re-read the rule and since ELT's are not required for gliders (only airplanes as previously discussed here ad infinitum), I will change my opinion to say that none of the other requirements of the rule applies to gliders. I say this because the sentence that states no new installations may use c91 ELT's says "those required by paragraph (a) - and the ELT is not required by paragraph (a) for gliders, so I could argue that none of the FAR requirements are applicable to a non-airplane. But this view may not be shared by all FSDO's or IA's should you choose to make a new installation in your glider certificated in any category. I would also infer that the annual test and logbook entry would not be required, but I may be out on a limb here tilting a windmill or something like that. I'd certainly like to stick with my current C91 unit until the new, improved ELTs are cheaper! Amen - the FAA would allow you to do that - if they required an ELT in your aircraft. Don't they use their own rules, not the SSA rules? I'm assuming you mean the 1-26 Nationals. Or did you mean the Sports Class Nationals? The 1-26 Nationals are an SSA sanctioned contest, right? I'll need an SSA membership to fly in the contest, so I believe it qualifies under the proposed rule as an "SSA Competition". If not, I'd be interested to hear that from someone with the real scoop. Jim  |
			 jphoenix wrote: The rule should be amended (in my opinion) to allow continued use of TSO C91 units that are currently installed. Granted they are not as accurrate as the C91a units, but at least they are installed. A C91 ELT may be adequate for contest purposes in someone's estimation, but in no case may they be used for a new installation (FAR), so there's no chance of installing the C91 units if you don't already have it installed. A 406 mHz unit would be best, but I'd MUCH prefer to spend the money on a transponder - if I had to spend the money. At least with a transponder I could get a FL 180 waiver. My portable, parachute-mounted ELT does not comply with the proposed contest rule. This new contest rule means that all 1-26's participating in the Nationals in 2006 shall require an approved ELT installation. I'm thinking lead balloon on this one. Jim Reply and update on thinking. RC is reviewing and most likely will revise text to reflect C91 or C91a units. As to 1-26'rs, they are sanctioned by SSA but have their own rules system and do not fall under these rules. Thanks for input from all H Nixon RC Chair  |
			 Reply and update on thinking. RC is reviewing and most likely will revise text to reflect C91 or C91a units. As to 1-26'rs, they are sanctioned by SSA but have their own rules system and do not fall under these rules. Thanks for input from all H Nixon RC Chair That sounds good. Thanks Hank.  |
			 comcast webnews wrote: I personally feel that we should move in the direction of the WGC scoring formulas. Possibly adopt the WGC formulas 100%, or possibly a blend of our current system and the WGC system. I wonder how many pilots in favor of moving to WGC scoring formulas have actually read them? (Actually, how many poll respondents have actually read the US scoring formulas?!) The idea sounds nice, "let's score the way the worlds are, so our guys get used to that and do better." But when you actually look at the mess in the world scoring formulas, you realize "why should we screw up every contest in the US just because the world rules are screwed up?" Two small examples, second-hand from the last worlds. 1) Start gate with limited height but not limited speed or the US two-minute rule. Back to dive-bombing. Do you really want that? 2) MAT style task is distance in a set time. It allows the strategy of timing-out low, way downwind, then trying to scratch back to the airport to see if you can get the bonus for finishing at home. Do you really want to do this at US contests? And of course, world and European devaluation rules give a huge benefit to gaggling. I hear there was a day in an Australian worlds where pilots simply refused to go out on course since nobody wanted to be first. Again, do we really want that? Are US contests places for US pilots to have fun, compete, learn to do better in a safe environment, or are they just a training camp for the top 5 or so who want to go to the worlds? The poll question on "goals" suggested a lot more pilots in favor of the former, not the latter. If you move to WGC scoring, what do you do when you see obvious safety or procedural problems? Here, you call up UH or the current rules committee chairman, and it gets fixed. If you're committed to WGC scoring, fixing the simplest problem has to wait for the IGC to move on it. This is like having the UN in charge of parking regulations. John Cochrane (BB)  |
So let me think through the logic here for a minute.
	1. We would like to promote contests and ideally get as many if not all sailplanes and pilots participating. This has many good benefits by promoting soaring, public image, and pilot profecency. 2. We want to require ELT's in (nearly) all gliders participating in contests due to the additional safety they provide. Does not 1+2 equal we would like nearly all gliders to have ELT's? If this is such a saftey issue, Why don't we offer credit to all gliders entered into an SSA Sanctioned Contest (reduced entry fee) for a few years. Basically I am thinking that we offer a maximum of a $200 credit per glider entered spread out over a few years. In this way a contestant can basically get their money back for installing an ELT. Sure this would reduce the already limited income to the SSA but as has been quoted here before "what is the price of safety?" especially when someone else is paying for it. Brian wrote: Would someone please tell me - without rancor and name calling - how the rule requiring ELT's for all SSA events in 2006 came to be. If I read the 2004 poll correctly, 58% of the respondents did not want ELT's required at all and only about 22% wanted them by 2006. If the polls are not going to have a bearing in the rules then why do them? Tom Idaho Ken Kochanski (KK) wrote: http://sailplane-racing.org/ Ken Kochanski SRA Secretary  |
			 I feel strongly ELT contest requirement will lead to the removal of glider ELT exception. The exemption loss will cost us $2,000+ with transition to 406 MHz units. It will be hard for the SSA to argue that ELTs are not essential for all gliders when the SSA states they are essential for contest rescue efforts. Why would anyone accept the argument that the whereabouts of a downed contest pilot is more important then the whereabouts of a casual weekend pilot. Wayne "Brian" wrote in message oups.com... So let me think through the logic here for a minute. 1. We would like to promote contests and ideally get as many if not all sailplanes and pilots participating. This has many good benefits by promoting soaring, public image, and pilot profecency. 2. We want to require ELT's in (nearly) all gliders participating in contests due to the additional safety they provide. Does not 1+2 equal we would like nearly all gliders to have ELT's? If this is such a saftey issue, Why don't we offer credit to all gliders entered into an SSA Sanctioned Contest (reduced entry fee) for a few years. Basically I am thinking that we offer a maximum of a $200 credit per glider entered spread out over a few years. In this way a contestant can basically get their money back for installing an ELT. Sure this would reduce the already limited income to the SSA but as has been quoted here before "what is the price of safety?" especially when someone else is paying for it. Brian wrote: Would someone please tell me - without rancor and name calling - how the rule requiring ELT's for all SSA events in 2006 came to be. If I read the 2004 poll correctly, 58% of the respondents did not want ELT's required at all and only about 22% wanted them by 2006. If the polls are not going to have a bearing in the rules then why do them? Tom Idaho Ken Kochanski (KK) wrote: http://sailplane-racing.org/ Ken Kochanski SRA Secretary  |
			 comcast webnews wrote: I looked over the 2004 opinion poll again because I remembered that there was a fairly strong mandate to change our Scoring formulas. quote: 8.0 WGC-style Scoring 8.1 Should SSA contests adopt the scoring and devaluation formulas used at the World Gliding Championships? Yes 104 61% No 54 32% Twice as many people agreed as disagreed, so why was no action taken on this? I personally feel that we should move in the direction of the WGC scoring formulas. Possibly adopt the WGC formulas 100%, or possibly a blend of our current system and the WGC system. I think adopting it will help us select and breed pilots so the US be more competitive in the world championships. As a negative side effect of the WGC system there seems to be such a stronger bias toward speed that middle of the score sheet pilots such as myself used to scoring 750-900 points per day would likely be discouraged by scoring much lower [300-600points?]. This could cause frustration and pilots more likely to drop out of competition flying. However I'm in favor of moving toward the WGC formulas at least partially. Chris Reply: Chris Who? Always nice to know who we are sharing with. Change to WGC scoring , or somehting similar, is a major change that requires significant study, testing, and feedback before adoption. There are many attributes of scoring and tasking at the World level which may well not fit how we race here. In any case- minutes of RC meeting, which are also available to you at the same site say: 40 Use IGC scoring system Comments Discuss later. Under study. No change for 2005. Possibly try on a dual scoring basis once we work out the details. 2xx agreed to chair a sub sub committee to study this. Thanks for sharing UH RC Chair  |
	snip Chris Reply: Chris Who? Always nice to know who we are sharing with. "Chris Who", well let me reply by asking "UH Who?" - hey just playing games here. Chris Ruf - a name you will find on the lower half of the score sheets. Change to WGC scoring , or somehting similar, is a major change that requires significant study, testing, and feedback before adoption. There are many attributes of scoring and tasking at the World level which may well not fit how we race here. In any case- minutes of RC meeting, which are also available to you at the same site say: 40 Use IGC scoring system Comments Discuss later. Under study. No change for 2005. Possibly try on a dual scoring basis once we work out the details. 2xx agreed to chair a sub sub committee to study this. Thanks for sharing UH RC Chair So long as it is not forgotten that is fine. I am not proposing that we adopt all the WGC rules instead of US rules. High speed dangerous start gates and forced downwind landouts are not what I would seek to adopt. My goal would be to look at how cross-country and speed skills are rewarded in the WGC scoring system, then compare it to the US scoring formulas. There may be some adjustments we can make that would help us better pick and breed US pilots to be competitive in Worlds. Hopefully a compromise could be found that does not require a massive overhaul, but would bring us more in alignment. I think it is a topic worthy of more study and discussion. I don't have a fixed opinion on the matter. Chris Ruf  |
Did anyone even bother to contemplate the effect the 2006 mandatory ELT
	rule would have on US contest participation? I am a casual contest pilot, normally flying in only one or two a year. If the rule comes down, I won't be happy about it, but I probably will scrape together the money. But, it isn't someone like me you have to worry about. What it's going to do is kill off a lot of the regional contests out here are the west coast (and probably elsewhere). The pilots who are already hooked on contests will pay the price. Those who participate even less frequently than I, or who just want to try it out (and may eventually get hooked) will hem and haw about getting an ELT, and then simply won't show up. You'll also lose most of the entrants that fly club ships in Sports Class. I'd guess that at least half of the entrants in the 2004 Region 11 FAI contest would not have participated if ELTs had been required. I'd also guess that the Region 11 Sports Class contest would cease to exist if the ELT rule was in place. I, too, have sat around in a gliderport office late into the evening waiting (in vain) for a missing pilot to show up alive. I understand the desire to reduce this burden on contest officials in the future. But, if the result of this seemingly sensible rule is a significant reduction in the number of people participating in US contests, is it really worth the cost? Marc  |
| Thread Tools | |
| Display Modes | |
| Third Military-Civil MAC Jan. 18, 2005 | Larry Dighera | Piloting | 37 | February 14th 05 04:21 PM |
| millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 6th 04 12:14 AM |
| The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 04:58 PM |
| FLASH! U.S.A. Rules Committee to Address Rules Complexity? | SoarPoint | Soaring | 1 | February 3rd 04 03:36 AM |
| New SRA Site - New 2003 Rules Minutes and 2004 Rules Summary | Ken Kochanski | Soaring | 0 | December 17th 03 04:38 AM |
