Trailer tire rims
Old January 20th 05, 03:36 PM
Gary Carter
Default Trailer tire rims
I have an older Cobra trailer (1980ish - aluminum) and need to find another
tire rim (I had an axle mishap and lost one of my tire/rims). The rim is a
4 x 100 metric (four lug holes and 100 mm between each lug) and supports a
13 inch tire. Does anyone have a rim for sale or can suggest a source in
the US hopefully close to Atlanta, Georgia to get one?
Thanks for your help.
Gary Carter
Old January 20th 05, 03:53 PM
WDM
Try this site, they have cross references for bolt patterns used on cars:
http://www.discountedwheelwarehouse...._Reference.cfm
I went to the local junk yard once and pulled rims and good tires(the
spare)from a wrecked Plymouth Horizon (bolt pattern 4X100 13"). They
only charged me $10 per tire.
Gary Carter
Old January 20th 05, 06:25 PM
Tim Mara
try the local salvage yard.....
I'm sure this is the same as many small car wheels..you do need hoever to
use wheels designed for drum brakes, disk brake wheels are
different.......years ago I had an older Komet trailer, I found Plymouth
Horizon wheels fit perfectly....and most of these cars came with space saver
spare tires.....the type that was fully inflated, not the ones with the air
can to fill as needed....the neat thing was that these wheels are the same
on the spare tires as those on the ground, just the tire was
different........everyone hated these space saver spares so junk yards had
dozens of them, usually brand new they couldn't sell to anyone....and the
wheels were fairly attractive, slotted type wheels...I got brand new, no
rust silver painted wheels complete with the tire for about $10.00
each....had I just wanted to by a used, probably bent wheel they would have
charged $25 each.....and the Horizon was a typical 70-80's cheapo car with
rear drum brakes....
try it.....worked perfectly for me
tim
www.wingsandwheels.com
"Gary Carter" wrote in message
nk.net...
another
a
Gary Carter
Old January 20th 05, 09:13 PM
Tim.Ward
How does the rim know whether it's being stopped by a disk or drum
brake?
Or is this just your way of pointing out that the offsets may be
different?
Tim Ward
Old January 20th 05, 09:38 PM
Tim Mara
offset
tim
"Tim.Ward" wrote in message
brake?
different?
Tim Ward
Old January 20th 05, 10:06 PM
GeorgeB
On Thu, 20 Jan 2005 16:38:36 -0500, "Tim Mara"
offset
tim
There is a little more to it than that ... the offset can be the same,
but there not be clearance for some parts. Example; I have a Venture
"minivan" and our daughter drives a Lumina ... the offset and bolt
pattern are the same, but even with both having disc brakes, I cannot
put my Venture wheels on her Lumina ... parts interfere with one
another. She had a flat, and I was going to do that to drive it to te
tire store ...
roups.com...
brake?
different?
Old January 20th 05, 11:49 PM
Brian Iten
There is a reason the rim off of your Venture would
not fit on the Lumina..... They are two totally different
wheels, rims, brake assemblies and hubs.
As for the idea of the horizon rims and being disc
or drum brakes, the horizon came with front disc and
rear drums. You can rotate the tires front to back
without a problem. Look for an old Horizon or Plymouth
Omni and they should work on the trailer.
At 23:36 20 January 2005, Georgeb wrote:
On Thu, 20 Jan 2005 16:38:36 -0500, 'Tim Mara'
offset
tim
can be the same,
I have a Venture
'minivan' and our daughter drives a Lumina ... the
offset and bolt
brakes, I cannot
with one
to drive it to te
tire store ...
'Tim.Ward' wrote in message
groups.com...
a disk or drum
brake?
offsets may be
different?
Old January 21st 05, 03:15 PM
Gary Carter
Thanks for the great advice and your responses. I am on my way to the local
junk yard. I have also found some original Comet trailer ties, but they
could be more costly in the long run..
"Brian Iten" wrote in message
offset
tim
can be the same,
I have a Venture
offset and bolt
brakes, I cannot
with one
to drive it to te
tire store ...
egroups.com...
a disk or drum
brake?
offsets may be
different?
Eberle trailer wheel rims Bob Soaring 7 November 25th 11 05:39 PM
Tire question Jay Honeck Owning 30 February 8th 05 07:55 PM
Trailer spare - who woulda thunk? Bill Daniels Soaring 7 May 20th 04 04:47 PM
Tire Stiffness & trailer swaying - resolution chris Soaring 6 October 26th 03 03:50 PM
Tire Stiffness & trailer swaying chris Soaring 42 October 22nd 03 03:51 AM
