Hi,
Is it really so hard to crash C172? On FS2002, I land with quite high vertical speed (-2 or -3), the bump and the sound is rather "hard", but the plane is OK. Of course, I have set "crash tollerance" to max. reality. I even once lande successfuly with vertical speed -5. Is that possible on a real plane? Thanks, latet |
latet wrote:
Hi, Is it really so hard to crash C172? On FS2002, I land with quite high vertical speed (-2 or -3), the bump and the sound is rather "hard", but the plane is OK. Of course, I have set "crash tollerance" to max. reality. I even once lande successfuly with vertical speed -5. Is that possible on a real plane? Thanks, latet By -5, do you mean -500 feet/minute? A normal descent rate from traffic pattern altitude to the last part of the final leg is about -500/feet per minute. However, as you prepare for the landing flare that number dwindles and final touch down is normally made at just a few negative feet per minute. I would think that touching down at -500 feet/minute would destroy just about anything except some military aircraft. Best, Randy |
pattern altitude to the last part of the final leg is about -500/feet per minute. However, as you prepare for the landing flare that number dwindles and final touch down is normally made at just a few negative feet per minute. I would think that touching down at -500 feet/minute would destroy just about anything except some military aircraft. That's what I thought. Then FS2002 sucks :-( Can't one make some changes in the config files to make crash tollerance more realistic? Greets, latet |
On Tue, 15 Feb 2005 21:08:30 +0100, "latet" wrote:
By -5, do you mean -500 feet/minute? A normal descent rate from traffic pattern altitude to the last part of the final leg is about -500/feet per minute. However, as you prepare for the landing flare that number dwindles and final touch down is normally made at just a few negative feet per minute. I would think that touching down at -500 feet/minute would destroy just about anything except some military aircraft. That's what I thought. Then FS2002 sucks :-( Can't one make some changes in the config files to make crash tollerance more realistic? 500 ft/min are like a free fall from 1 ft. It would not destroy the airplane, at least if you land on the main gear. Try 1000 ft/min, this is like a fall from 4 ft. and more likely to cause permanent damage. Cheers http://www.codecpage.com |
update on Montrose crash | Bob Moore | Piloting | 3 | November 29th 04 02:38 PM |
Bad publicity | David Starer | Soaring | 18 | March 8th 04 03:57 PM |
FS2002 Compass Anomaly - PLEASE HELP | GM EWA | Simulators | 0 | January 13th 04 11:20 PM |
Sunday's Crash in LI Sound | Marco Leon | Piloting | 0 | November 5th 03 04:34 PM |
Help needed - fs2004 zaps fs2002 props | Ian D | Simulators | 1 | September 11th 03 10:20 PM |
