Engine Mods
Old February 15th 05, 02:11 AM
Paul Missman
Default Engine Mods
I just had the O-235-L2C in my Tomahawk overhauled, and the 125 HP mod
performed at the same time. Now it is getting 2700 RPM at just under 400
degrees CHT, during break in, and cruising between 100-105 knots. Before
the rebuild, cruise was about 2400 RPM and about 90 knots.
I'm very happy with the engine mod, and would recommend it to anyone getting
an O-235-L2C overhauled.
Paul Missman
Old February 15th 05, 05:04 AM
houstondan
mind sharing some prices with & without the hp upgrade??
thx
dan
Old February 15th 05, 11:16 PM
Jon A.
The CHTs are too hot. Check your fuel flow, check the baffles. Even
new, you don't want those CHTs that high! That's the recipe for
cylinder problems.
On Mon, 14 Feb 2005 21:11:42 -0500, "Paul Missman"
Paul Missman
Old February 16th 05, 02:46 AM
Kyle Boatright
Tomahawks are infamous for relatively high CHT's. The modification to 125
hp makes it even worse. I'd say that 400 degree CHT's on a brand new engine
at full power during break-in ain't half bad for a 125 hp Tomahawk.
Paul could post his question to the Tomahawk group in Yahoo, and I think
he'd find that these temperatures are typical or maybe better than typical
for this installation.
KB
"Jon A." wrote in message
cylinder problems.
getting
Paul Missman
Old February 16th 05, 03:46 AM
On Tue, 15 Feb 2005 21:46:20 -0500, "Kyle Boatright"
Never offer up factual information to a demagogue, it's like trying to
teach a pig to sing.
Regards;
TC
Old February 17th 05, 12:42 AM
Paul Missman
"houstondan" wrote in message
thx
dan
Dan,
I can't answer as to overhauls, as prices will vary from one engine shop to
another. The engine shop I used charges $13k to overhaul an O-235-L2C,
which includes inspection and casework, inspection and possible replacement
of the cam, inspection and possible replacement of the crank, new cylinders
and pistons, new mags, plugs, wires, etc..
The 125 HP upgrade consists of installing 9.3:1 compression pistons, and, if
not already in place, an external oil cooler. From Air Mods NW, which holds
the STCs, I purchased the STCs, an external oil cooler and shrouds, and an
EGT/CHT guage. I let the engine shop supply the high compression pistons,
and the oil cooler hoses, and install the oil cooler and CHT/EGT.
Between my engine not needing a few accessories in the overhaul, and the
extra work for the mods, I paid $14k to the engine shop, which also put in
new engine mounts, repainted the mounting brackets, and did a beautiful job
with the wiring. I paid Air Mods NW for the STCs, the oil cooler and
shroud, and the EGT. I cut and pasted their prices from
www.pipertomahawk.com below :
BASIC KIT PRICES FOR THIS MODIFICATION
Packet of 3 STC's, Engine, Airframe, & Oil Cooler$ 495.00
Set of 4 high compression pistons, weight matched$ 652.00
Pistons only - no rings, pins, plugs, etc. included
Basic Kit Price, plus freight and applicable tax$1,147.00
Pre-Cut Materials Kit for Oil Cooler Mount$ 245.00
Ken Blackman, from Air Mods NW, started this mod years ago with a Grumman
that he had purchased years ago. He's quite happy to talk with people about
the modification, and its history, when he has the time. He has had it
placed in quite a few Tomahawks and a lot of Cessna 152s.
Paul Missman
Old February 17th 05, 12:53 AM
Paul Missman
cylinder problems.
Jon,
The engine shop that did the overhaul told me, for the first 10 hours, to
run it full rich, and everything short of either red line or 400 degrees
CHT. With the mod, about 2700 RPM is just below 400 degrees CHT, and the
red line is now 2800 RPM.
I bought the EGT/CHT guage at Ken Blackman's recommendation. He's the
holder of the 125 HP STCs. He recommended the guage, because, he said, in
climb, at 9.3:1 compression, it can get quite hot, very quickly, and not to
exceed 450 degrees.
Normally, the Tomahawk has no CHT/EGT guage. So, I never knew how hot the
cylinders ran before the modification.
Paul Missman
Old February 17th 05, 01:29 AM
Paul Missman
job with the wiring. I paid Air Mods NW for the STCs, the oil cooler and
Also, included in that price, they pulled the tach, and sent it out for
re-calibration and repainting of the red line.
Paul
Old February 17th 05, 03:40 AM
Jon A.
Appreciate the reply, even the blurb from Pope Toecutter the 1st, but
if you have a look at the real data being measured today (the 21st
century) you'll see that the Old Wive's Tales aren't holding any
water. Regardless, you make your own decisions.
http://www.advancedpilot.com/
On Wed, 16 Feb 2005 19:53:19 -0500, "Paul Missman"
cylinder problems.
Jon,
exceed 450 degrees.
Paul Missman
ROP masking of engine problems Roger Long Piloting 1 September 25th 04 07:13 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 06:11 AM
Motorgliders and gliders in US contests Brian Case Soaring 22 September 24th 03 12:42 AM
