Owner Change/rotate spark plugs?
Old February 14th 05, 07:32 PM
Don Hammer
I'm a long time A&P. Back in the old days I used to hang them on a
piece of safety wire, get them red hot, then drop them in water.
Worked great for me and I didn't have to go hunt some up in the stock
room. Of course, for me, the acetylene torch was closer than the
stock room.
  #32
Old February 14th 05, 10:45 PM
Dave Stadt
"Victor J. Osborne, Jr." wrote in message
Thanks for saying what I was thinking.
All I want to do is change/rotate the plugs (after sufficient oversight -
one time)
I'll buy bulk gaskets. All I need is a fire for trying to save a few
bucks.
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
If you can't heat spark plug gaskets without starting a fire maybe you
should rethink changing/rotating the plugs in your aircraft.
  #33
Old February 17th 05, 03:28 PM
When they get too thin they also get too large and slop around
on the plug, giving adequate warning that they should be tossed. Some
of the sparkplug-type CHT thermocouples are thinner than a gasket but
the plug still threads far enough into the head. No gasket is used with
the thermocouple.
Dan
  #34
Old February 17th 05, 11:07 PM
IMHE, they flatten by getting larger in outside diameter and smaller
in inside diameter..... they can be a pill to get off then...
depending on how far they have ridden up on the radius between the
threaded portion and the flange.
The thousands of copper gaskets I have changed have never shrunken
in ID and stuck on the plug. Automobile plug gaskets will, but they're
a hollow gasket that will reduce in ID when compressed. The coppers get
chucked when they get too big on the ID, as all of them eventually do.
I check every gasket before using it, as the annealing process will
blister it if it gets too hot. I use a propane spitfire torch; gets
really warm really quick. Annealing 100 gaskets takes maybe ten
minutes.
Dan
  #35
Old February 25th 05, 07:19 PM
Michael Houghton
Howdy!
RST Engineering wrote:
Oh, please, for the love of God, don't do this. This is how you HARDEN
them, not soften them for the annealing process. Heat them red hot with a
torch and let them cool in ambient air to soften them.
Copper and silver (and probably many other non-ferrous metals) are annealed
by quenching. You can't harden them by heat treatment. You harden them by
working them. Yes, this is opposite to how you harden/soften steel.
Google for "anneal copper". One site I found was
http://www.key-to-metals.com/Article25.htm
which seems to cover more than just annealing work-hardened copper.
Now, one can fairly wonder why one would want to reuse old gaskets when
they can be bought fairly inexpensively, but that is a different matter.
yours,
Michael
Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly
| White Wolf and the Phoenix
Bowie, MD, USA | Tablet and Inkle bands, and other stuff
http://www.radix.net/~herveus/wwap/
Spark plug question: Massive electrode or fine wire? Peter R. Owning 9 February 4th 05 02:03 AM
Which aircraft certification is required for R&D? Netgeek Home Built 5 November 23rd 04 05:59 AM
Bougies blindées BG à vendre/BG spark plugs for sale stef General Aviation 0 May 14th 04 04:57 PM
Color of spark plugs john smith Owning 5 March 2nd 04 03:08 AM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
