#51
On 17 Feb 2005 14:25:15 -0800, "John Galban"
wrote in .com:: Larry Dighera wrote: 3.) they seldom have radar coverage of the MOA, since it isn't their responsibility. This military controller apparently had me on radar. Desert MOA is more the exception than the rule when it comes to MOA coverage. Isn't that unfortunate. With the USAF requesting expansion of the subject MOA for low-level supersonic operations, perhaps they should include VFR advisory service as part of the package. The Air Force claims, that safety is their first priority, but they have the audacity to suggest that VFR aircraft transiting their MOA should avail themselves of see-and-avoid during supersonic flight is conducted within it. It's unfortunate the public meetings regarding the proposed MOA changes has past. Most MOAs I'm familiar with do not have a dedicated frequency for advisories. Perhaps that could be remedied too. |
#52
Larry Dighera wrote: On 17 Feb 2005 14:25:15 -0800, "John Galban" wrote in .com:: Most MOAs I'm familiar with do not have a dedicated frequency for advisories. Perhaps that could be remedied too. A remedy assumes a problem. Desert has a dedicated frequency because of the inordinately high amount of military and civilian traffic. In less congested MOAs, getting advisories from Center works just fine. John Galban=====N4BQ (PA28-180) |
#53
"John Galban" wrote in message
oups.com... Additionally, just because you are talking to "Nellis Control" does not necessarily mean that you are talking to a military controller. The FAA often provides radar services that one might assume were military. One example in the Phoenix area is Luke AFB Approach. While meandering through the Alert Area getting advisories from Luke Approach, you're actually talking to a civilian controller in the Phoenix Tracon. I'm not saying one way or the other whether Nellis Control is military or not, only that it can be hard to know for sure just by the name. Actually, Luke AFB has had it's own USAF approach control since at least the early 1980s. It is currently operated by the 56th Operations Support Squadron. The Nellis Air Traffic Control Facility (which includes both the RAPCON and Range Control) is also a USAF operation and is run by the 57th OSS. The point of not being able to tell if a facility is staffed by military or civilians simply by the name is correct. But the reality is it doesn't matter. In the US air traffic control is air traffic control and a controller is a controller - military or civilian. |
#54
On 17 Feb 2005 14:59:53 -0800, "John Galban"
wrote in . com:: In less congested MOAs, getting advisories from Center works just fine. Center radar probably can't "see" to as low an altitude as the military radar covering MOAs. And then, there is the issue of whether the military aircraft operating in the MOA are receiving traffic advisories from Center or not. |
#55
"Jeff Crowell" wrote in message ... Ed Rasimus wrote: Ask your local library or buy the paperback: Negative. Buy the hardback. We need to motivate Ed as much as possible to keep writing. Bought it the moment I saw it. I've read it twice already and waiting for the second one, semi-patiently. Glenn D. |
#56
In message , Blueskies
writes " Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com Sounds like a good book, Ed. I look forward to reading it some day.... Find it. Read it. Enjoy it. And look forward to the sequel. -- He thinks too much: such men are dangerous. Julius Caesar I:2 Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
#57
"Ed Rasimus" wrote in message ... How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? The Florida midair did not occur on a low-level training route. You might also note that aircraft below 10,000 MSL (except in some special use airspace) is already restricted to airspeeds below 250 KIAS. That's not correct. Aircraft below 10,000 feet MSL cannot exceed 250 KIAS unless the minimum safe airspeed for any particular operation is greater than that speed, the aircraft may then be operated at that minimum speed. |
#58
On Sat, 19 Feb 2005 20:43:01 GMT, "Steven P. McNicoll"
wrote: "Ed Rasimus" wrote in message .. . How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? The Florida midair did not occur on a low-level training route. It didn't occur in a MOA, didn't involve supersonic operations, and, the incident is not relevant to the discussion of the proposed changes to airspace in New Mexico were my points. You are correct, the midair did not take place on an LLN route. Feel better now? You might also note that aircraft below 10,000 MSL (except in some special use airspace) is already restricted to airspeeds below 250 KIAS. That's not correct. Aircraft below 10,000 feet MSL cannot exceed 250 KIAS unless the minimum safe airspeed for any particular operation is greater than that speed, the aircraft may then be operated at that minimum speed. You're entering this a bit late. Your additional phrase regarding operational necessity has been discussed in some detail here. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
#59
"Ed Rasimus" wrote in message ... What part of "accident" is so difficult to understand. For what crime would you prosecute the flight lead? Murder? Did he premeditate? What crime? The flight lead clearly did not intend for anyone to be killed, but his unlawful actions did result in the death of another human being. Sounds like manslaughter to me. We live in a litigious society. Folks threaten to sue when the spill hot coffee in their laps and to avoid the costs of the litigation, the prospective defendant will often reach a settlement. No criminal charges were brought, because no prosecuter with an ounce of judgement would be able to define a "crime" and no civil action was brought, because Ms Olivier really couldn't prove that a flight lead decision was in any way malicious toward her husband. Does malice have to be shown? Wouldn't malice make it murder and not manslaughter? |
#60
"Larry Dighera" wrote in message ... When a pilot deliberately descends into congested terminal airspace with the required ATC clearance, it's not an accident; it's reckless endangerment of all the aircraft operating legally within the terminal airspace. If you disagree, please explain how Parker could have _accidentally_ descended into the Class B and C airspace, perform a G Check, and search for the MTR? I don't recall anything in the report that indicated the descent into Class B or Class C airspace was deliberate. As I recall there was a significant navigational error. |
| AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 07:12 PM |
| AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Piloting | 12 | April 26th 04 07:12 PM |
| bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 05:26 PM |
| 12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 13th 03 12:01 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
