#71
![]() "Russ MacDonald" wrote in message news:kJJRd.38393$uc.8144@trnddc03... An UNCONTROLLED field with E airspace to the ground?? Uncontrolled is G airspace! Yes, there are many uncontrolled fields with Class E surface areas. An uncontrolled field is one without an operating control tower, it has nothing to do with airspace. |
#72
![]() wrote in message ... I'm flying a contact approach when I'm cleared for a contact approach, regardless of what I use to navigate. You're flying a contact approach when what you're doing has the properties of a contact approach. Navigation by visual reference to the surface is a property of a contact approach. If you're not flying by visual reference to the surface then what you're doing does not have the properties of a contact approach and thus you are not flying a contact approach. Just because I must see the ground, doesn't mean I must use ground references to navigate. It doesn't say "must see the ground", it says "proceed to the destination airport by visual reference to the surface". That actually DOES mean you must use ground references to navigate. That shouldn't surprise anyone. After all, contact flight is done by visual reference to the surface. If you take contact flight out of the contact approach what kind of approach do you have left? |
#73
![]() wrote in message ... Where is it written that I am not? It's not. Now, where is it written that you are free to navigate any way you wish? In other words, where is it written that you can fly a contact approach without proceeding to the destination airport by visual reference to the surface? |
#74
![]() "Stan Prevost" wrote in message ... Yes, and I am trying to teach you this basic stuff, but you are very resistant to instruction. Well, that explains a lot! Here I thought I was trying to teach you and it turns out you're teaching me! D'oh! Well, I'm always eager to learn. Let's press on! You have agreed in previous posts that 91.155(a) defines VFR conditions and that 91.155(c) defines a restriction on VFR operations under certain conditions. I'm glad that you understand that. Now let's see if we can move you to the next level. I'm aware of only one condition in FAR 91.155(c), a ceiling of less than 1,000 feet. What condition or conditions am I missing? Just to have a clear common reference, I quote the P/CG, which applies to both pilots and controllers: VFR CONDITIONS- Weather conditions equal to or better than the minimum for flight under visual flight rules. 91.155(a) defines two things. One is a meteorological limit for VFR operations, which is flight visibility. The second is an operational restriction on pilots regarding how closely they may operate to clouds under VFR. There is no other restriction in that paragraph regarding clouds, such as ceiling, broken, overcast, scattered, etc. If sufficient flight visibility exists for the airspace and other conditions (day/night, altitude), then a pilot may conduct VFR operations in those conditions as long as s/he is able to maintain the required cloud clearance, unless further restricted, such as by 91.155(c). We then say that VFR conditions exist, in accordance with the P/CG definition. If the flight visibility falls below the required minimum value, then VFR conditions do not exist. If the clouds where the operations are to be conducted become such that a pilot is unable to maintain the required cloud clearance, whether vertical or horizontal, then VFR conditions do not exist because the conditions are such that they will not allow VFR operations to be conducted in accordance with 91.155(a). A ceiling higher than 1000 and reported visibility greater than 3 miles does not assure VFR conditions at an airport. The cloud condition must be such that VFR operations can be conducted in accordance with 91.155(a). It is not uncommon under scud-type conditions for there to be scattered clouds below the ceiling that will prevent being able to maintain the required lateral clearance (and flight visibility). Under this condition, VFR conditions do not exist. Interesting. Just to clarify, you're saying that clouds covering 3 to 4 octas of the celestial dome can require flight within a surface area to be done only by IFR or SVFR? Is that correct? And you say this is not uncommon? Odd, I've been flying for thirty years and making weather observations for twelve and it certainly seems uncommon to me. Is there anyone out there still reading this thread that can concur with Stan's position? If there is a ceiling and it is less than 1000 ft, then 91.155(c) prohibits VFR operations below that ceiling in a surface area designated for an airport. Since flight under VFR cannot be conducted due to a prohibition based on a meteorological condition, we can say that VFR conditions do not exist below the ceiling. But if there is a ceiling greater than 1000 ft and reported visibility is greater than 3 miles, that does not mean that VFR conditions do exist below the ceiling. Then how does a controller ensure that weather conditions at the airport are VFR prior to issuing a clearance for a visual approach in a surface area? So regarding the requirement for ATC to ensure that VFR conditions exist at the airport before issuing a clearance for a visual approach, we can see that 1000/3 in a surface area is necessary but is not sufficient. I hope this helps you to clarify your understanding. Not completely. What are the minimum conditions required prior to issuing a visual approach in a surface area? |
#75
![]() "Russ MacDonald" wrote in message news:CAyRd.2617$QQ3.2368@trnddc02... If it's low ATC will ask if we think we can get in visually, and if we say yes, they issue the visual approach. There is no weather reporting there, and they have never once asked if the field had 1000/3. 1000/3 is not applicable to fields without weather reporting. It sounds to me like the FAA heard about a solution and they tried to write rules to define it. How so? In actual practice it's not that complicated. There is no radar at most of these uncontrolled fields, and there are lots of commercial operations, and the last thing that ATC wants is for us to fly a full approach if there is any way to avoid it. That just stacks up the holding patterns, and it takes forever to unwind. Multiple IFR arrivals to uncontrolled fields can also stack up the holding pattern. If successive aircraft cannot see preceding aircraft visual separation cannot be used and everyone has to wait for the preceding aircraft to cancel IFR. |
#76
"Russ MacDonald" wrote in news:kJJRd.38393
$uc.8144@trnddc03: An UNCONTROLLED field with E airspace to the ground?? Uncontrolled is G airspace! An uncontrolled airport is one without a tower. It's not unusual for an untowered airport to have a Class E surface area. -- Regards, Stan "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin |
#77
![]() wrote in message ... Too ridiculous for words. To follow your interpretation means that if I am ffying a contact approach into an airport in the middle of the desert in the middle of the night, with a VOR on the field, I msut abandon the approach because I don't recognize a particular cactus. I haven't provided any interpretation. I'm just saying it like it is. I note that you still have not provided any support for your assertion. |
#78
![]() wrote in message ... I'll say it once more, and that's it. Maintaining "visual reference to the surface" is different from "navigating by visual reference to the surface" Yes, but "proceeding to the destination airport by visual reference to the surface" is the same as "navigating by visual reference to the surface". Don't bother to respond, because the ****ing match is over. You're not going to learn anything with that attitude. I'll take your withdrawal to indicate you cannot support your assertion that a pilot can simply follow a VOR radial or a localizer course, or use his handheld GPS or anything else that he feels will safely take him to the field, just as long as he maintains one mile visibility. |
#79
![]() wrote in message ... Bullsquat. No, it really is: CONTACT APPROACH- An approach wherein an aircraft on an IFR flight plan, having an air traffic control authorization, operating clear of clouds with at least 1 mile flight visibility and a reasonable expectation of continuing to the destination airport in those conditions, may deviate from the instrument approach procedure and proceed to the destination airport by visual reference to the surface. This approach will only be authorized when requested by the pilot and the reported ground visibility at the destination airport is at least 1 statute mile. |
#80
![]() "Steven P. McNicoll" wrote in message ink.net... "Stan Prevost" wrote in message ... Yes, and I am trying to teach you this basic stuff, but you are very resistant to instruction. Well, that explains a lot! Here I thought I was trying to teach you and it turns out you're teaching me! D'oh! Well, I'm always eager to learn. Let's press on! We all can continue to learn a few things, if willing. And I have learned a few things from you. You have agreed in previous posts that 91.155(a) defines VFR conditions and that 91.155(c) defines a restriction on VFR operations under certain conditions. I'm glad that you understand that. Now let's see if we can move you to the next level. I'm aware of only one condition in FAR 91.155(c), a ceiling of less than 1,000 feet. What condition or conditions am I missing? That it be a surface area. And you are assigning a meaning to the paragraph which is incorrect. You seem to be saying that if the reported visibility is three miles are greater and if there is not a reported ceiling of less than 1000 feet, then VFR conditions exist. It does not say that at all. It says what it says, which is that flight under VFR is prohibited in a surface area if there is a ceiling of less than 1000 ft. And it does not say reported conditions, it says conditions. It is a rule for pilots ("no person may operate an aircraft....") and pilots may not operate under VFR in a surface area unless they comply with both 91.155(a) and 91.155(c). 91.155(c) grants no exception to 91.155(a), it only defines an additional restriction. Until you understand and accept this, you will make no progress. 91.155(c) says nothing about visibility. That appears only in 91.155(a) where it defines visibility requirements in terms of flight visibility. You can't be selective about what provisions of 91.155(a) you want to apply. Just to have a clear common reference, I quote the P/CG, which applies to both pilots and controllers: VFR CONDITIONS- Weather conditions equal to or better than the minimum for flight under visual flight rules. 91.155(a) defines two things. One is a meteorological limit for VFR operations, which is flight visibility. The second is an operational restriction on pilots regarding how closely they may operate to clouds under VFR. There is no other restriction in that paragraph regarding clouds, such as ceiling, broken, overcast, scattered, etc. If sufficient flight visibility exists for the airspace and other conditions (day/night, altitude), then a pilot may conduct VFR operations in those conditions as long as s/he is able to maintain the required cloud clearance, unless further restricted, such as by 91.155(c). We then say that VFR conditions exist, in accordance with the P/CG definition. If the flight visibility falls below the required minimum value, then VFR conditions do not exist. If the clouds where the operations are to be conducted become such that a pilot is unable to maintain the required cloud clearance, whether vertical or horizontal, then VFR conditions do not exist because the conditions are such that they will not allow VFR operations to be conducted in accordance with 91.155(a). A ceiling higher than 1000 and reported visibility greater than 3 miles does not assure VFR conditions at an airport. The cloud condition must be such that VFR operations can be conducted in accordance with 91.155(a). It is not uncommon under scud-type conditions for there to be scattered clouds below the ceiling that will prevent being able to maintain the required lateral clearance (and flight visibility). Under this condition, VFR conditions do not exist. Interesting. Just to clarify, you're saying that clouds covering 3 to 4 octas of the celestial dome can require flight within a surface area to be done only by IFR or SVFR? Is that correct? And you say this is not uncommon? Odd, I've been flying for thirty years and making weather observations for twelve and it certainly seems uncommon to me. Just to clarify, what I said is in the text you quoted above, which reads in part "If the flight visibility falls below the required minimum value, then VFR conditions do not exist. If the clouds where the operations are to be conducted become such that a pilot is unable to maintain the required cloud clearance, whether vertical or horizontal, then VFR conditions do not exist because the conditions are such that they will not allow VFR operations to be conducted in accordance with 91.155(a)." See, you are being resistant to instruction. And you are suggesting that as a pilot you are willing to violate 91.155(a). Is there anyone out there still reading this thread that can concur with Stan's position? My position is what I stated. If there is a ceiling and it is less than 1000 ft, then 91.155(c) prohibits VFR operations below that ceiling in a surface area designated for an airport. Since flight under VFR cannot be conducted due to a prohibition based on a meteorological condition, we can say that VFR conditions do not exist below the ceiling. But if there is a ceiling greater than 1000 ft and reported visibility is greater than 3 miles, that does not mean that VFR conditions do exist below the ceiling. Then how does a controller ensure that weather conditions at the airport are VFR prior to issuing a clearance for a visual approach in a surface area? I don't know if there is any way, and have never suggested that I do. The first step for a controller is to learn what the rule actually says, which I am trying to help you with, and accept its actual meaning, not confusing that with what may be done in practice. The next step for a controller is to see if s/he can figure out a way to determine how to correctly comply with the actual meaning of the rule. If no such way can be determined, then that controller must decide whether to not issue a visual approach clearance under conditions which cannot be determined to be in compliance with the Order or to adopt practices which are not in strict accordance with the Order. I believe the latter is what is commonly (or universally) done in practice by ATC, but it ought to be done with proper understanding. So regarding the requirement for ATC to ensure that VFR conditions exist at the airport before issuing a clearance for a visual approach, we can see that 1000/3 in a surface area is necessary but is not sufficient. I hope this helps you to clarify your understanding. Not completely. What are the minimum conditions required prior to issuing a visual approach in a surface area? That VFR conditions exist. |
GPS approach question | Matt Whiting | Instrument Flight Rules | 30 | August 29th 08 03:54 AM |
Contact approach question | Paul Tomblin | Instrument Flight Rules | 114 | January 31st 05 06:40 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
