Stall strips vs. Washout
Old February 21st 05, 09:55 PM
Default Stall strips vs. Washout
I've noticed a lot of aircraft are designed to use washout at the tips
to control stall behaviour. The idea as it was explained was that they
wanted the inboard part of the wing to stall before the outboard part
so aileron authority could be maintained a little longer.
I've also seen mention of stall strips being installed inboard to try
to affect the same thing.
It seems to me that trying to impart a twist of only a few degrees into
a structure that large, and have it maintain that twist under load and
over time (as opposed to jigged on a bench) is a fairly hard thing to
do correctly.
Also, with the washout, aren't you in effect constantly flying around
with the whole wing at a non-optimal AOA since each part of the wing is
slightly different AOA as you move out on the span?
Since airfoils are a trade off, among other things, of lift, drag, and
range of AOA, wouldn't it be better to extend the stall strip approach
to just having a progressive (or piece wise) airfoil cross section with
a sharper leading edge in-board moving out to a smooth rounded leading
edge near the tips (and ailerons)? So you have a lower drag, reduced
AOA range inboard, and higher drag albiet wider range AOA outboard.
And have no twist in the wing.
Discuss
Old February 21st 05, 10:16 PM
Rich S.
do correctly.
Not correct. The wing is not built "straight" and then twisted. It is built
with the "twist" jigged in.
Rich S.
Old February 21st 05, 10:57 PM
Bill Daniels
Wing twist, whether geometric or aerodynamic via a change in airfoil
spanwise is designed in. Stall strips are added later if the original
design proves to have unacceptable stall characteristics.
Stall strips hurt performance and should be avoided if at all possible. You
NEVER see stall strips on a sailplane. Careful selection of outboard wing
sections can produce very sweet stall behavior.
Twist, is usually an aerodynamic benefit across the whole speed range. It
helps maintain an elliptical spanwise distribution of lift.
Bill Daniels
do correctly.
Discuss
Old February 21st 05, 11:42 PM
Morgans
Constant cord (Hershey Bar) wings need no twist, or stall strips, as they
stall naturally on the inboard section, with the tips remaining flying to
the end. They are not as efficient at high speeds as elliptical or tapered
wings, but that is seldom the mission of planes that have constant cord
wings.
Jim in NC
Old February 22nd 05, 01:14 AM
Kyle Boatright
"Morgans" wrote in message
tapered
wings.
Jim in NC
This may be a good generalization, but I can think of at least two
exceptions. The Grumman AA-1 and the Piper Tomahawk. I've never paid much
attention to the Grumman AA-5, but I wouldn't be surprised to see 'em there
either.
KB
Old February 22nd 05, 02:47 AM
Morgans
much
there
either.
KB
An exception to what? Surprised to see what, where? You gotta incude more
hints, unless you want to play 20 questions! :-)
Jim in NC
Old February 22nd 05, 03:46 AM
Rich S.
My guess would be your statement that "They (constant chord wings) are not
as efficient at high speeds as elliptical or tapered wings, but that is
seldom the mission of planes that have constant cord wings".
I'll bet he's referring to stall strips as mentioned in:
stall naturally on the inboard section. . .
But he is a bit obtuse with his referents. :-)
Rich S.
Old February 22nd 05, 10:36 AM
Roger
On Mon, 21 Feb 2005 17:42:36 -0500, "Morgans"
roups.com...
wings.
The old "Hershey Bar Wing" Cherokees are the only planes I've flow
that I could put into a stall, keep it in the stall, and still make
turns using the ailerons. Many airplanes don't like that and in
particular the Bo series of planes are likely to roll over with which
ever wing you try to raise going down instead. It's amazing how fast
they can put the greasy side up.
www.rogerhalstead.com
Old February 22nd 05, 01:44 PM
Kyle Boatright
Sorry about that. I'm gonna blame nasty sinus infection combined with a
mixture of meds.
My follow-up was directed at JSMorgan's comments on hershey bar wings and
stall strips:
"Constant cord (Hershey Bar) wings need no twist, or stall strips, as they
stall naturally on the inboard section"
Like I was trying to say last night, the AA-1 and Tomahawk both have hershey
bar wings and stall strips.
KB
much
there
either.
KB
more
Jim in NC
Old February 22nd 05, 02:52 PM
Bill,
Could you advise a source where one could find info on "aerodynamic"
twist? As I understand it, newer designs like the Lancair Legacy do not
have a geometric twist but use different airfoils and taper to provide
the twist. Thanks
Tom
original
possible. You
wing
range. It
Bill Daniels
tips
they
part
try
into
and
to
do correctly.
around
wing is
and
approach
with
leading
reduced
Discuss
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Proper stall recovery technique Chris OCallaghan Soaring 0 February 2nd 04 11:33 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 02:27 PM
Wing Extensions Jay Home Built 22 July 27th 03 01:23 PM
