QNH???
Old February 22nd 05, 08:17 AM
Marlbra
Default QNH???
my instructor told me not to worry about what "qnh" actually
means......... can someone here enlighten me please? i know it has
something to do with the barometric pressure and setting alt meter,
but what does QNH stand for...... as always thanks for your patience
guys and gals.....Im new here
Old February 22nd 05, 08:44 AM
Frank van der Hulst
QNH is the pressure that the air would be at sea level, if it wasn't for
the land all being above sea level. If you were to bore a hole down to
sea level, and lower a barometer down the hole to the bottom, then QNH
is what pressure the barometer would read. Theoretically.
If you set your altimeter to QNH, then it will accurately show you
altitude above sea level, so you can avoid busting into someone's
controlled airspace. It will also show the airfield elevation when
you're on the ground at the airfield.
Frank
Old February 22nd 05, 12:41 PM
Robert Bonomi
It means do it "Quietly, No Hu-hu".
Well, you *asked* grin
Seriously, it is just a "code". an *arbitrary* symbol to which a particular
meaning has been assigned.
"Q" codes date from the days of Morse-code communications, where there was
a definite performance advantage to be gained by having "short-cut' symbols
for many "common" messages/phrases. example: it is *much* faster to
send the 3 Morse-symbols for "QRU" than it is to transmit "I have no traffic
for your station".
Old February 22nd 05, 03:43 PM
Jan Carlsson
Yes but...
"QNH is a calculated number that makes your altimeter read
correctly (true altitude = pressure altitude) "
True alt is above sea or land in true feet or meter.
Pressure alt. is alt above the Std 29.92/1013.25 level, and that surface can
be above or below SL depending on atmosphere pressure.
Jan Carlsson
www.jcpropellerdesign.com
"T o d d P a t t i s t" skrev i meddelandet
news
I think "Theoretically" is the important part of this. When
you set QNH at the local airport, the altimeter reads
correctly only at the altitude of that local field (unless
the atmospheric temp and pressure changes with altitude in
the standard way, which it almost never does.) So, just
like there is a difference between true altitude and
pressure altitude when flying above the airport, the
imaginary barometer-in-the-hole won't really read QNH when
at the true altitude of the sea.
correctly (true altitude = pressure altitude) at the
altitude/elevation of the reporting station. Everywhere
else (including at the true altitude of the sea) it's wrong,
but as long as we're all wrong by the same amount, we don't
run into each other.
(Remove DONTSPAMME from address to email reply.)
___
Make a commitment to learn something from every flight.
Share what you learn.
Old February 22nd 05, 10:59 PM
Samm Munn
QNH, QFE, QFF, QNE
When an airport measures the local air pressure, then this pressure is
called QFE. An airplane which has set the altimeter to the QFE value will
read zero feet on the altimeter when it is on the ground at this airport.
The QFE can be transformed into QNH by calculations and/or tables or
diagrams. In fact what happens is that the measured QFE is being corrected
for non-standard temperature, non-standard-humidity etc.
The resulting value is called QFF. This QFF value is then corrected for
field elevation, that means that it is transformed into a pressure as it
would have been at mean sea level (MSL) under standard conditions QNE (29.92
inches or 1013.2 mb of mercury at 59 degrees fahrenheit or 15 degrees
centigrade).
The resulting value is a local pressure value which we call QNH. An
airplane which has set the altitude to QNH value will read the field
elevation on the altimeter when it is standing at this airport!
Samm
I fly because it releases my mind from the tyranny of petty things . . . -
Antoine de St-Exupéry
"Marlbra" wrote in message
Old February 23rd 05, 11:54 AM
Jan Carlsson
I agree, but you sat tru alt=Pressure alt, that will only happend if QNH is
1013.25 if flying with any other QNH setting pressure alt will not be what
you see on the altimeter, it will be the alt above SL (with its errors from
dif. temp. and other factors)
Jan
Aside from the fact that you snipped off the last part of my
sentence - what was the "but" part. Did you disagree with
me? Looks to me like a case of contentious agreement :-)
"Jan Carlsson" wrote:
Yes but...
can
Jan Carlsson
meddelandet
news
for
___
___
Old February 23rd 05, 08:47 PM
Dean Wilkinson
Back when I worked at Boeing one of the test pilots told me that QFE and QNE
stood for Queen's Field Elevation (altimeter reference to the field so it
read zero on the runway) and Queen's Normal Elevation (altimeter referenced
to sea level). I don't know if this was just a memory aid, or if QFE and
QNE are actually acronyms for Queen's Field Elevation and Queen's Normal
Elevation.... anyone know?
Dean
Old February 23rd 05, 10:02 PM
Robert Bonomi
Yup. *NOT* true. 'Q codes' are just that _codes_. Not Acronyms.
Furthermore, "logic" shoots down both your 'memory aid' interpretations.
an "elevation" is a _distance_ measurement above a reference point, not
a 'pressure' reference. One can trust the "Queen's English" to use words
properly. grin
Old February 23rd 05, 11:49 PM
Jughugs
On top of that... manned flight was invented HERE in the US... not in that
dental-challenged, pompus, take credit for everything, dung-hole!
"Robert Bonomi" wrote in message
QNE
referenced
properly. grin
