whats the deal with those 100$ gizmos that plug your cellphone into the
headset. does that work??? dan |
They work great.
houstondan wrote: whats the deal with those 100$ gizmos that plug your cellphone into the headset. does that work??? dan |
I second that... on the ground, and if you can get signal... in the air
too... Make a call right before center hands you over to approach to let yer ride know you are 20 mins out. OOOPS.. dont tell the FCC... Dave Newps wrote: They work great. houstondan wrote: whats the deal with those 100$ gizmos that plug your cellphone into the headset. does that work??? dan |
"Dave S" wrote: I second that... on the ground, and if you can get signal... in the air too... Make a call right before center hands you over to approach to let yer ride know you are 20 mins out. My CellSet works great, but I've never been able to use it in the air. My Nextel phone always says "no service" when airborne. Does Nextel have some built in software that cuts you off if you connect to too many towers at once? -- Dan C-172RG at BFM |
I have Sprint PCS with automatic cellular roaming. I don't use the
Cellset regularly and the last time I did was on a XC into Dallas.. or maybe Tyler... cant remember which. I seemed to recall not being able to get a dependable signal until descending below 5k. On the ground it worked fine. Dave Dan Luke wrote: "Dave S" wrote: I second that... on the ground, and if you can get signal... in the air too... Make a call right before center hands you over to approach to let yer ride know you are 20 mins out. My CellSet works great, but I've never been able to use it in the air. My Nextel phone always says "no service" when airborne. Does Nextel have some built in software that cuts you off if you connect to too many towers at once? |
I have a Cellset also and always get a useable signal. I use Verizon
but the phone will use any other CDMA signal when necessary. Dan Luke wrote: "Dave S" wrote: I second that... on the ground, and if you can get signal... in the air too... Make a call right before center hands you over to approach to let yer ride know you are 20 mins out. My CellSet works great, but I've never been able to use it in the air. My Nextel phone always says "no service" when airborne. Does Nextel have some built in software that cuts you off if you connect to too many towers at once? |
Dan Luke wrote: My CellSet works great, but I've never been able to use it in the air. My Nextel phone always says "no service" when airborne. Does Nextel have some built in software that cuts you off if you connect to too many towers at once? The old analog 800 Mhz phones (the ones the FCC prohibits in the air) used to work just fine at cruising altitudes. The downside was that you lit up every cell within your line of site and ****ed off the phone company. The newer digital services (operating on frequencies not prohibited by the FCC for air use) don't seem to work once you get a few thousand feet AGL. I was talking to a Sprint engineer about it and he told me that the antenna patterns on the newer cell services are angled downward in most places, which degrades the signal received in the aircraft. John Galban=====N4BQ (PA28-180) |
houstondan wrote: whats the deal with those 100$ gizmos that plug your cellphone into the headset. does that work??? What $100 gizmo? My Lightspeed headset came with a cell phone cable. -Robert |
John Galban wrote:
The old analog 800 Mhz phones (the ones the FCC prohibits in the air) used to work just fine at cruising altitudes. The downside was that you lit up every cell within your line of site and ****ed off the phone company. ....and the dozens of other cell phone users on the ground that had their call drop because of you. The newer digital services (operating on frequencies not prohibited by the FCC for air use) Urban myth. The table of allocation in Part 1 does not authorize the frequencies allocated to PCS to be used for air to ground service, period. These tables are controlling regardless of what your interpretation of Part 22 may be. don't seem to work once you get a few thousand feet AGL. I was talking to a Sprint engineer about it and he told me that the antenna patterns on the newer cell services are angled downward in most places, which degrades the signal received in the aircraft. True; the down tilts are used to mitigate against inter-cell interference. |
Others should not have their calls dropped no more than if a person is
calling from top of a hill or in a good position seeing different towers. A cell phone "dialogs" with every tower in sight and ties up only ONE channel on each. Which means you use more total channels than necessary, possibly denying new call service (but not necessarily) to others in bussy times. If all cell phones in use were doing the same thing there would be very limited number of chanels open for new phone calls. Doug Carter wrote: ...and the dozens of other cell phone users on the ground that had their call drop because of you..... |
| Barbra Olson Story Debunked! Proof Cellphones Work in Aircraft. | G.R. Patterson III | Piloting | 14 | February 4th 05 03:15 AM |
| Ping Sport Pilot Barbra Olson Story Debunked! Proof Cellphones Work in Aircraft. | Sport Pilot | Piloting | 0 | January 21st 05 08:05 PM |
