Night flying in the mountians in a cessna 150,
Old February 26th 05, 03:17 AM
Peter Duniho
"Bob Noel" wrote in message
The odds of winning a lottery sometime in your lifetime are much better if
you
play the lottery every day of your life (assuming a nice long life) than
if you
just play the lottery once.
The odds are only higher at the beginning of your life.
For what you wrote to be true, you have to be calculating the odds at the
beginning of your life, and make some assumption about how often you'll play
(every day, for example), and about how long your life is (a year, for
example).
Once you make that calculation, then you go on with your life. Every day
you play the lottery. Every day that you fail to win the lottery, the
percentage chance of winning the lottery *during your life* is REDUCED (the
chance of winning on any given day, of course, is the constant chance anyone
has of winning on any given day). On the last day of your year-long life,
having not won the lottery, the chance of your winning the lottery is
exactly the same as the chance a person who has never played before and who
will only play this one day.
The only reason that it *seems* like people with high hours have a higher
chance of experience an engine failure is that the odds are being calculated
by assuming a fixed chance of the event over the entire number of hours.
But the hours already flown are irrelevant for the purpose of figuring your
chance of an engine failure for a given flight, as are the hours you expect
to fly after that flight.
Pete
  #82
Old February 26th 05, 03:21 AM
Peter Duniho
"Ron Garret" wrote in message
Yes it is, you just didn't read what I wrote very carefully. Pay
particular attention to the phrase "some time in your career."
Only if you're speaking of a hypothetical career prior to its start.
That depends on what you mean by "the odds". The odds on any one play
are the same, but the cumulative odds of experiencing a win or an engine
failure *at some point in your life* goes up with every play/flight.
Define "cumulative odds". The word "cumulative" implies that you're talking
about the odds as the flight hours accrue. In that respect, your claim is
false.
Specifically, if the odds of winning on a single try are P then the odds
of winning some time in your career are 1-(1-P)^N where N is the number
of times you play.
That statement is true only when you are calculating the odds prior to ALL
trials (flights), and have determined the number of trials (flights) in
advance. It's not a useful calculation for the purpose of this discussion.
No one knows before they've started flying how many flights they will make
in a lifetime.
Pete
  #83
Old February 26th 05, 03:24 AM
Steve.T
Ok, I fly IMC at night, single engine on the east coast. Granted, they
aren't as high as the Rockies or Sierra Nevada mountains. But day or
night, they still don't provide a good place to land.
When I fly at night, I have two flash lights (minimum), spare batteries
for both. If any light in/on the plane is not working, it is a no-go.
The GPS must have the most current map, the VORs must have just been
tested (e.g., in air, VOT, etc.), both radios must be functional, I
carry both VFR and IFR charts and both are marked for planned flight. I
generally file for 7,000 to 10,000 (well above the Min altitudes) and
ask for direct. My wife generally is following along on the VFR charts
to know where the closest airport is (and we use the GPS to assist in
this). Oh, did I mention I also have a hand-held GPS as well? And I
work at *NOT* getting into icing conditions (probably why the plane has
been in the hanger since November 04).
I am 49, 330+ hours, have a family that flies with me in IMC.
Regards,
Steve.T
PP ASEL/Instrument
  #84
Old February 26th 05, 04:14 AM
Morgans
Steve.T
I didn't ask you how old you are. I'll bite anyway.
I am not against any form of night flight, and I'll also say that East coast
mountains are different, but most of all, the amount of airports on the
right cost is vastly different.
Jim in NC
  #85
Old February 26th 05, 06:43 AM
NW_PILOT
"Nomen Nescio" ] wrote in message
-----BEGIN PGP SIGNED MESSAGE-----
engine
talking
is
false.
odds
of times you play.
ALL
discussion.
make
in a lifetime.
Pete
It is a useful calculation for making the decision as to "Should I fly
over
the mountains at night?"
Using Ron Garret's example of 1 in 100 chance of having an engine failure,
and assuming that an engine failure at night over the mountains has a
100% chance of being fatal (I know it's not 100%, but I'd bet it's awfully
close). And that you have a "99% chance" of having an engine failure if
you fly back and forth over the mountains "460 times". I agree with you
that on the 461st you have no more chance of having an engine failure
than the first time you make the flight. BUT....there IS a 99% chance that
you don't live long enough to make that 461st flight. While your assertion
is quite correct that the closer you get to the end of your flying career,
lower the odds of having an engine failure (and consequently, crash and
burn on a mountainside), the higher the odds are that you're already dead.
In other words, when you make that 461st flight.....chances are that
you're
in a box that's been loaded in the back of the plane.
This brings to mind the old saying:
"It's easy to beat death, but death's advantage is that it only has to win
once"
Yes it is a very old saying, especially since someone like me has already
been clinically dead once. I Guess I won that round.
  #86
Old February 26th 05, 06:54 AM
Ron Garret
Obviously. If the career is over then one need not invoke probabilities
at all. Probabilities are only useful when discussing things whose
outcomes are not yet known.
false.
The cumulative probability of an event over N trials is the probability
that the event occurs at least once in those N trials. In that respect,
my claim is true.
of times you play.
trials (flights),
Obviously we only care about the odds for the flights we have not yet
made. For the flights that we have made we already know whether the
engine failed or not.
and have determined the number of trials (flights) in advance.
No. That statement is true regardless of whether N is known.
That is a matter of opinion.
in a lifetime.
That is not necessarily true. My mother, for example, knows exactly how
many flights in GA aircraft she will make during her lifetime: zero.
And just in case you're too dimwitted to extrapolate from this example
I'll spell it out for you: one can *decide* on the basis of this
calculation to stop flying after some number of flight because flying
more than that results in a cumulative probability of disaster that
exceeds one's risk tolerance.
rg
  #88
Old February 26th 05, 02:44 PM
Thomas Borchert
Peter,
That's not true. The longer you play, the more opportunities you have to
win. But each time you play, you have the same exact chance to win (all
else being equal, which means ignore the variations in chance due to
different numbers of participants, etc), and there is NO length of time you
can play that will guarantee a win.
Or, in other words I like a lot: There is no law of small numbers.
Thomas Borchert (EDDH)
  #89
Old February 26th 05, 04:25 PM
Peter Duniho
Of course your odds of having an engine failure with two engines is
double of what it would be with one, and quadruple with four.
Only approximately. The only reason doubling (or quadrupling) the number of
engines doubles (or quadruples) the chance of an engine failure
(approximately) is that the failure rate is so low. For example, if the
failure rate were 50%, a doubling of that would cause you to expect an
engine to fail each flight (a 100% chance of failure), when in fact the
chance is actually only 75%.
Pete
  #90
Old February 26th 05, 04:29 PM
Peter Duniho
Knowing that your chances of having an engine failure are 1-(1-P)^N isn't
very useful information if you don't know what N is.
Tell me how I'm going to use the information then. Since you think it's so
useful.
make
in a lifetime.
For a person who will never make a flight in a GA aircraft, why in the world
would I consider at all how many engine failures she'll experience?
It's like trying to figure out how many live births I'll have in my
lifetime. Duh.
Only if they make that decision prior to flying those hours. I haven't met
a single person who has ever done such an analysis of their flying career.
I doubt one exists.
If you can find me one, I'll stand corrected. Otherwise, you are without a
point (I'll refrain from any implication that YOU are dimwitted, just 'cause
that's the kind of guy I am).
Pete
Routine Aviation Career Guy Alcala Military Aviation 0 September 26th 04 12:33 AM
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
Night Flying Tips BoDEAN Piloting 7 May 4th 04 03:22 AM
Headlight for night flying Paul Tomblin Piloting 22 September 27th 03 09:32 AM
