Night flying in the mountians in a cessna 150,
Old February 26th 05, 07:16 PM
C J Campbell
OK, having read through this thread for awhile, I might as well chime in
with a few observations:
1) Roll the dice often enough, and they will eventually come up snake-eyes.
The question is whether they are likely to do that before something else
gets you. Most people want to make it more likely that they will die of
cancer or heart disease than in an airplane crash. Apparently we want to die
slowly and old.
2) Here in the Pacific Northwest, flying at night in the mountains is
dangerous, no question about it. Indeed, the mountain ranges around here are
possibly some of the most dangerous in the world. The trouble is, flying
anywhere around here at night as not much better. The whole area is
mountainous, heavily forested, with large tracts of water that is barely
above freezing year 'round. Visible emergency landing areas at night are few
and far between. Low ceilings, low freezing levels, haze, mountain
obscuration, micro-climates with weather wildly different from anything
forecast -- these are the norm around here. Many students around here manage
to log over an hour of actual IFR before they get their private certificate.
On top of that, the days get real short and real dark during the winter, so
restricting yourself to daytime flight is difficult.
3) Even if you live through an emergency landing at night in this area, the
odds of surviving until you are found are vanishingly small, especially
considering that most pilots do nothing to increase their chances of
survival. They fly without jackets or coats, take no survival gear, have no
way of signaling rescuers, etc. You are going to be wet and cold and
probably injured. Not good.
OK, if you want to die slowly and old, don't fly at night in the Pacific
Northwest, especially in the mountains. If you don't want to kill your son
or anybody else, don't take them with you when you fly little single engine
airplanes at night in the mountains around here. But even if you don't give
a rip about yourself or anybody else, I would ask you not to do it anyway.
Too many good people are killed every year trying to rescue selfish,
thoughtless bozos who thought they were invulnerable to the laws of
averages.
  #93
Old February 26th 05, 10:09 PM
Howard Nelson
"George Patterson" wrote in message
Jose wrote:
But you would never say "the Appalachian ranges." For the same reason,
you
should never say "the Sierras" when you're talking about the Sierra
Nevada.
But we say "the Appalachians".
And it would be correct to say "the Nevadas." But not "the Sierras."
George Patterson
I prefer Heaven for climate but Hell for company.
Correct or not. I live out here and if you said in conversation:
I went hiking last weekend in the Sierra.
or
I think I will go skiing next week in the Sierra
or
Take I80 over the sierra.
You would sound kind of goofy to a local.
Howard
  #94
Old February 26th 05, 11:22 PM
Matt Whiting
On Sat, 26 Feb 2005 11:45:19 -0500, Matt Whiting
On Fri, 25 Feb 2005 17:16:35 -0800, Ron Garret
That's true, but the longer you fly (or play the lottery) the closer
your probability of experiencing an engine failure (or a lottery win)
some time your career approaches 1.
Of course, you might have to fly/play for a *very* long time before that
probability actually gets close to 1, but sooner or later it will be 1
to any desired degree of accuracy. So the statement "fly long enough and
you will experience an engine failure" is pretty close to being true.
The question is how long is "long enough."
rg
This just ain't so.
Every time you play the lottery, it's like the first time you ever
played it.
It doesn't matter whether you won a jillion yesterday, or haven't won
in 50 years, or never played. The odds are exactly the same.
Yes, for every given play you are correct. However, Ron is correct that
in aggregate, someone who plays more often has a higher overall chance
of winning at some point than a person who only plays once in their
lifetime. At least I think that is the point he was making.
Matt
no, I think his point is that you are more likely to have an engine
failure tomorrow if you have flown 10,000 hours than if you have flown
10 hours.
I just re-read what he wrote above, and while it could have been
clearer, I still think he meant the probably in aggregate, not the
specific probability on the next flight. However, I'll let him weigh in
with what he meant. :-)
Matt
  #97
Old February 27th 05, 12:02 AM
Ron McKinnon
"Ron Garret" wrote in message
I think the implication, with all due respect, in the way you worded
your post, is that the probability is increasing as you flying time is
increasing.
It depends on what you mean by "the probability". There
are two different probabilities being discussed: there is the
probability of a failure on any particular flight, which doesn't
change, and there is the cumulative probability of experiencing
failure on some flight, which does change (it increases with
each flight). This is clearly not the case, as I think we all
now agree.
There is also the probability (that Peter (I think) proposed)
stated as a cumulative probability in terms of an arbitrary
large number of trials (flights, or hours, or whatever).
If you convert this to a probability of occcurence with
a lower number of trials (flights, or hours, or whatever)
that probability will be lower. Looked at it this way,
if the probability of an 'occurrence sometime in (the
remainder of )one's career is known, then as the career
progresses, the probability of 'an occurrence sometime
(in the remainder of) one's career diminishes from
that value.
This is a direct consequence of
1) the premises (accepted by all here,
apparently) that
- the probability for any given trial (hour, flight, or
whatever) is assumed to be independent of any other
given trial (hour, flight or whatever) and
- the probability is assumed to be the same for each
such trial, and
2) the assertion that the probability of an occurrence
over n trials is (1-(1-p)^n, where p is the probability
of occurence in a single such trial.
Its the same problem worked back to front (or
front to back, depending on your point of view):
i.e.: Let p2 be the probability of an occurence in
n2 trials, and let p1 be the probability of an occurence
in n1 trials, if n1 n2, then p1 p2.
If you *start* with p1, as you consider an increased number
of trials the probability will increase, if you *start* with p2
and consider a decreased number of trials, the probability
will decrease.
Your statement is ambiguous because you don't say
which probability you're referring to.
Yes. The logical conclusion is determined from
the premises used. You only get out of it what you
put in.
Every day is a new day, and N gets reset to zero.
Not quite. Every day is indeed a new day, but with
every flight N is incremented by one.
It depends on upon from which premise you started.
If you're considering your probability in terms of
occurences per N trials, you might change N if you
start out with it being 'the number of trials in my
entire career', but the probability of an occurence
'in the next N trials' otherwise doesn't need any
change in N from day to day.
But 'the number of trials in my career' is moot
in the first place, and I'd argue that arbitrarily
specifiying the number of trials that are 'going to
occur' in your career is equally problematic, as
is coming up with such a probability in the first
place. The best you can get out this argument, I
think, starting out with a guess for the cumulative
probability of the 'entire carreer', is a qualitative
'probability is decreasing' as the career progresses,
and you can't really ever quantitatively say how
much.
  #98
Old February 27th 05, 12:36 AM
Ron Garret
In article P68Ud.515993$8l.368458@pd7tw1no,
"Ron McKinnon" wrote:
as the career
that value.
Yes, but only because N is lower. Whatever N is, after every flight N
is 1 less than it was before.
in the first place,
That is arguable. As a precise number you're probably right. But in
broad brushstrokes you can decide, e.g. never to try something, to try
something once and then never again, to try something a dozen times in
your lifetime, to do something once a month, once a week, once a day, or
multiple times a day. Each of these choices entails a monotonically
increasing risk of encountering certain kinds of disasters over your
lifetime.
My personal risk tolerance works out something like this:
Things I'm not willing to try even once: heroin, motorcycle racing
Things I'm willing to try once in my lifetime and never again: going
into space (assuming I ever have the opportunity)
Things I'll do a dozen times: aerobatics
Once a month (on average): skiing
Once a week: Flying GA aircraft
Once a day: getting out of bed in the morning :-)
Multiple times a day: driving on the freeway, eating sushi :-)
rg
  #99
Old February 27th 05, 02:03 AM
Peter Duniho
[...] the chance is actually only 75%.
How so?
The probability of both engines failing is .25, I agree, but I'm
talking a failure of either engine.
I am too. What chance do YOU think you have of having a failure of either
engine, if not 75% (in this example)?
If the chance of an engine failure is 50% (0.5), then the chance of either
engine failing when you have two engines is 1-(0.5)*(0.5). 75%.
The probability of both engines failing is indeed only 25%. The probability
of EITHER engine failure is 75%.
You need to do the subtraction because the chance of an engine failure is
actually the opposite of the chance of completing a flight without an engine
failure. To make the flight successfully without either engine failing
requires BOTH engines to not fail, and the way to calculate that is to
multiply the chances of each engine failing (which in this case is just two
engines, with identical chances).
The chance of you completing the flight without a failure is 25% (50% *
50%), so the chance of an engine failure on the flight is 75%.
Pete
  #100
Old February 27th 05, 02:06 AM
Peter Duniho
[...] If you think about it, there is absolutely no
difference in the risk calculation between making one flight with four
engines and four flights with one engine
The difference is that when you make a flight with four engines, you know up
front that you're carrying four engines. The calculation based on making
four flights with one engine is only useful when you know in advance you're
making four flights.
I certainly hope to make at least four more flights during my flying career,
but it's not certain that I will.
Sorry you can't see the difference. It's a crucial element to the question
of whether it makes sense to worry about the cumulative odds of an engine
failure.
Pete
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
Night Flying Tips BoDEAN Piloting 7 May 4th 04 03:22 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Products 1 November 4th 03 12:57 AM
Headlight for night flying Paul Tomblin Piloting 22 September 27th 03 09:32 AM
