I have been experiencing an odd problem with my digital EGT/CHT gauge.
The backlighting on the guage is controlled by the panel light dimmer potentiometer (or rheostat, which ever it is). When the dimmer switch is off, the gauge works fine. Once I turn the dimmer past the click, the instrument backlighting comes on but the digital readout goes blank. As I turn it further, the digital readout may or may not show up, and if it does, the reading is inaccurate. Once the dimmer rotates to full-dim, the display behaves normally again. I took a quick look behind the panel, and didn't see anything obvious. Of course, there are about a million wires crammed back there and I was laying upside down on my head at the time. Any ideas? |
My best guess is a bad ground.
wrote in message ups.com... I have been experiencing an odd problem with my digital EGT/CHT gauge. The backlighting on the guage is controlled by the panel light dimmer potentiometer (or rheostat, which ever it is). When the dimmer switch is off, the gauge works fine. Once I turn the dimmer past the click, the instrument backlighting comes on but the digital readout goes blank. As I turn it further, the digital readout may or may not show up, and if it does, the reading is inaccurate. Once the dimmer rotates to full-dim, the display behaves normally again. I took a quick look behind the panel, and didn't see anything obvious. Of course, there are about a million wires crammed back there and I was laying upside down on my head at the time. Any ideas? |
These symptoms, and a little common sense as to the sorts of errors an
installer might make, suggest that the ground connection for the gauge is not connected to the airframe ground but rather to the power source for the internal lighting. When the internal lighting is turned off or is set to max dim, the source voltage is very near ground potential, so the gauge works properly. At high or intermediate brightness settings the source voltage is closer to the power bus (battery +) voltage, so the voltage across the gauge is insufficient to allow it to work properly. This should be easy to check with a simple voltmeter, or even an ohmmeter -Elliott Drucker |
| Thread Tools | |
| Display Modes | |
| Cherokee ammeter revisted | Leo | Owning | 3 | January 15th 05 01:14 AM |
| CHEROKEE NATIONAL FLY-IN - MORE INFORMATION | Don | Piloting | 0 | June 16th 04 06:15 AM |
| CHEROKEE NATIONAL FLY-IN & CONVENTION - THIS MONTH! | Don | Owning | 0 | June 3rd 04 06:03 AM |
| Cherokee National Fly-In & Convention | Don | Owning | 0 | May 5th 04 09:13 PM |
| Cherokee National Fly-In & Convention | Don | Owning | 0 | March 20th 04 03:17 AM |
