Colibri Ipaq problem!
Old March 2nd 05, 01:43 AM
Default Colibri Ipaq problem!
I just installed a colibri and IpAQ system.
I'm running a ipaq 5550 w/ SeeYou Mobile
The colibri "knows" where it is(shows correct long/lat and altitude)
but when I turn the ipaq on, the colibri beeps and the lcd says "19200
connect "
At the same time SeeYou says "no GPS Data"
However "Connect Me" recognizes colibri
Has anyone had this problem?
How do you fix it?
Thanks
Devin Bargainnier
Old March 2nd 05, 01:55 AM
If connectme is running in the background, then Seeyou
won't be able to use the serial port, quit connectme.
Todd
Old March 2nd 05, 02:54 AM
I quit connectme which stoped the beeping and now the lcd gives the gps
status of 3d and 6 satalites.
SeeYou mobile still says "no Gps Data"
any other suggestions.
Thanks
Devin Bargainnier
Old March 2nd 05, 03:03 AM
Kevin Christner
Do a soft reset of the ipaq. Push in the small hole on the bottom of
the iPaq with the stylus. This should reset everything.
If you use both pieces of software, you need to make sure you exit one
before you use the other.
Kevin Christner
Old March 2nd 05, 03:27 AM
Good idea but still no GPS data
Devin Bargainnier
Old March 2nd 05, 04:34 AM
Kevin Christner
In the colibri setup menu, there is a section about NMEA data. Check
this section to assure that there are several strings with a "Y" next
to them. If not, enable the the first three options by moving the N to
the Y.
Kevin
Old March 2nd 05, 06:07 AM
keithw
Adjust the Baud rate from 19,200 to a lower setting , some units only
respond at 4800 .
keithw
Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ]
- A website for Australian Pilots regardless of when, why, or what they fly -
Old March 2nd 05, 11:41 AM
Mal.com
Buy a Volkslogger !
Old March 2nd 05, 03:12 PM
respond at 4800 .
keithw
Thanks that did it!
what are the disadvantages of the lower baud rate setting if any?
Thanks
Devin Bargainnier
Old March 2nd 05, 04:26 PM
f.blair
If the unit cannot understand the data at the faster rate, it just can't
read it. Just like if someone is talking too fast, you can't understand the
words.
respond at 4800 .
keithw
Thanks that did it!
Thanks
Devin Bargainnier
Colibri problem Ian Cant Soaring 1 August 19th 04 08:30 AM
iPaq wiring, cradles and mounts for gliders - Ideas?? Jim Kelly Soaring 12 December 5th 03 12:45 AM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 10:10 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 10:10 PM
iPaq screen viewability Raphael Warshaw Soaring 7 July 27th 03 07:02 PM
