ADF static? question
Old December 28th 04, 12:16 AM
JFLEISC
Default ADF static? question
My friend has an ADF in his C-180 with the type of antenna that goes from the
windshield to the tail.
Says it works fine on the ground during taxi and runup but gets nothing but
static (over the phones and needle won't "track") about 3 to 5 minutes into
flight. Happens every time. There are no static wicks.
Any experience here? Could static buildup be that reliable regardless of the
weather? Any recommendations?
Old December 28th 04, 02:09 AM
M.
Hi Jim,
Remembering back to when I did my instrument rating, ADF's are particularly
suseptable to both precipitation static and mountain effect caused by
attenuation and spurious bouncing of signals due to high terrain.
With the exception of adding static wicks to the trailing edges, aot alot
else could be done about them IIRC except to tune into a higher frequency
signal or to fly alot higher than the terrain and attemp a line of sight
fix.
Mike
"JFLEISC" wrote in message
but
into
Old December 28th 04, 02:28 AM
JFLEISC
I had the same problem in my Bonanze. Replaced the ADF with a CD player
and had no more static from the ADF.
I like the way you think ;-)
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 06:07 AM
Question Charles S Home Built 4 April 5th 04 10:10 PM
FS: Avery Dennison Adds Static Cling Vinyls to Fasson® Rapid-Roll Dry erase easel pads that clings to most walls. M.Roy Home Built 0 February 11th 04 06:18 PM
Is a static port a precision thing? Larry Smith Home Built 8 August 12th 03 11:26 PM
Canard static port location Paul Lee Home Built 1 July 12th 03 03:55 AM
