#11
On Fri, 11 Mar 2005 09:24:23 +0100, Bert Willing wrote:
There are components which are not fused internally (i.e. T/S indicators, Colibri etc). Bimetal breakers are disastreous in this case as they are very slow and will ultimately less pass about 10 times the nominal value before cutting off. This winter I was loocking into replacing my fuses by breakers, and I decided that I didn't want to have this crap in my gliders. The breakers to use are magnetic ones which are pretty fast - but the price tag is very different... so finally I kept going with fuses. Fuses for individual instruments don't protect those instruments, but do stop the larger battery fuse from blowing if the instrument fails in a way which draws a high current from the battery. This only works if the individual instrument fuses have a current rating smaller than the common battery fuse. If the common battery fuse blows, you lose ALL the instruments. If a single instrument fuse blows, you lose that instrument, but you were going to lose it anyway, as it is the failure of the instrument which blows that fuse. Cheers, John G. |
Yes and no. Of course one needs a big fuse (mine is 7 Amps) on the battery
to protect the cable running to the instrument panel. Individual fuses on simple instruments like a T/S do protect the main fuse to blow off. On more sophisticated intrumentation like a radio or a flight computer, the protect the instrument in the case you connect the battery with the instrument switched on. That usually produces a spike which some of the instruments (the LX160s is a good example) absolutely don't like. Fuses which protect an instrument need to be fast fuses, fuses protecting the main fuse or cables are slow fuses. -- Bert Willing ASW20 "TW" "John Giddy" a écrit dans le message de news: ... On Fri, 11 Mar 2005 09:24:23 +0100, Bert Willing wrote: There are components which are not fused internally (i.e. T/S indicators, Colibri etc). Bimetal breakers are disastreous in this case as they are very slow and will ultimately less pass about 10 times the nominal value before cutting off. This winter I was loocking into replacing my fuses by breakers, and I decided that I didn't want to have this crap in my gliders. The breakers to use are magnetic ones which are pretty fast - but the price tag is very different... so finally I kept going with fuses. Fuses for individual instruments don't protect those instruments, but do stop the larger battery fuse from blowing if the instrument fails in a way which draws a high current from the battery. This only works if the individual instrument fuses have a current rating smaller than the common battery fuse. If the common battery fuse blows, you lose ALL the instruments. If a single instrument fuse blows, you lose that instrument, but you were going to lose it anyway, as it is the failure of the instrument which blows that fuse. Cheers, John G. |
On Fri, 11 Mar 2005 14:57:37 +0100, Bert Willing wrote:
Yes and no. Of course one needs a big fuse (mine is 7 Amps) on the battery to protect the cable running to the instrument panel. Individual fuses on simple instruments like a T/S do protect the main fuse to blow off. On more sophisticated intrumentation like a radio or a flight computer, the protect the instrument in the case you connect the battery with the instrument switched on. That usually produces a spike which some of the instruments (the LX160s is a good example) absolutely don't like. Fuses which protect an instrument need to be fast fuses, fuses protecting the main fuse or cables are slow fuses. You would need very fast fuse to stop the spike you describe. Maybe a surge supressor on the line near the sensitive instruments would do a better job ? e.g. a 5W or so zener diode with a breakdown voltage of 14v. (or 16v if you are one of those who advocate 14v batteries) This will also blow the battery fuse if you connect the battery in reverse polarity by mistake, and prevent large negative voltages being applied to insufficiently protected instruments. It also saves you having to carry a supply of instrument fuses so you can replace the fuse of the instrument which was ON when you connected the battery. Cheers, John G. |
John Giddy wrote:
On Fri, 11 Mar 2005 14:57:37 +0100, Bert Willing wrote: Yes and no. Of course one needs a big fuse (mine is 7 Amps) on the battery to protect the cable running to the instrument panel. Individual fuses on simple instruments like a T/S do protect the main fuse to blow off. On more sophisticated intrumentation like a radio or a flight computer, the protect the instrument in the case you connect the battery with the instrument switched on. That usually produces a spike which some of the instruments (the LX160s is a good example) absolutely don't like. Fuses which protect an instrument need to be fast fuses, fuses protecting the main fuse or cables are slow fuses. You would need very fast fuse to stop the spike you describe. Maybe a surge supressor on the line near the sensitive instruments would do a better job ? e.g. a 5W or so zener diode with a breakdown voltage of 14v. (or 16v if you are one of those who advocate 14v batteries) This will also blow the battery fuse if you connect the battery in reverse polarity by mistake, and prevent large negative voltages being applied to insufficiently protected instruments. It also saves you having to carry a supply of instrument fuses so you can replace the fuse of the instrument which was ON when you connected the battery. Cheers, John G. Uh, there is no voltage spike produced from doing that. That's an old myth that comes from power planes, where the starter motor can induce big spikes in the system during starting. You don't want sensitive instruments powered on at that time. |
| Thread Tools | |
| Display Modes | |
| "zero" versus "oscar" versus "sierra" | Ron Garret | Piloting | 30 | December 20th 04 09:49 AM |
| Buying a plane versus renting | RD | Owning | 35 | March 5th 04 10:42 PM |
| leaving alternator breakers on all the time | Frank Ch. Eigler | Owning | 9 | October 24th 03 07:14 AM |
| Aircraft circuit breakers | Bill Staley | Soaring | 5 | October 6th 03 04:06 AM |
| Cessna 340 Tie down versus Hangar | endre | Owning | 11 | July 17th 03 02:49 AM |
