Quickie engine stand?
Old March 11th 05, 01:21 AM
Michael Horowitz
Default Quickie engine stand?
I'm looking for suggestions for a quickie engine stand.
Fastest is probably one that holds the engine verticle, flange down.
doesn't need to be waist high.
Wood is probably my best bet.
I'm planning on lifting the engine (A-65) off the tires it's currently
laying on so I can mount the exhaust, carb., etc prior to mounting it
on the a/c.
Suggestions? Smarter approach?- Mike
Old March 11th 05, 01:57 AM
Vaughn
Is $39.95 too much? If it will hold a V8, I suppose it will hold an A-65.
http://www.harborfreight.com/cpi/cta...emnumber=32915
Vaughn
"Michael Horowitz" wrote in message
on the a/c.
Old March 11th 05, 12:32 PM
A-65.
Price is fine; if I had the time I could build a nice substantial
stand, but I'm looking for a fast and nasty for Sat. morning.
Currently thinking of bolting a 4' length of 2x6 (or 8) in place of the
prop,lifting the engine and then bolting the 2x6 to a 4x4 frame made of
2x4 with some kind of re-enforced corners. I'm trying to visualize the
twisting the engine weight might place on that 2x6. - Mike
Old March 11th 05, 07:53 PM
Montblack
(mhorowit wrote)
I build theater sets. Never hung an engine on stage though. :-)
If you are in a garage with rafters, run a 9' leg UP to the cross rafters
and secure - attach flange mounting board to leg. Build two legs like a
ladder if you would feel more comfortable with that set up. (One leg should
do it though)
Flange board can be a couple of pieces of 2'x2' plywood screwed together for
strength. (Will a 2x6 be wide enough for the bolt pattern?)
Engine will end up being mounted on the boards(s) the normal way -
horizontally like an engine stand.
To strengthen the leg going up to the rafters, attach stiffening boards up
the two sides - it'll look like a rain gutter or a flower box. 1x3's will
work fine here. Pre-drill. Too much work - grab some scrap 2x4's instead.
g
I'm thinking an 8' long board (2x4, shelving material, plywood sheet,
whatever) on the floor will lay flat so you can park something heavy on it -
car, motorcycle, brother-in-law? Floor board can run away from the engine -
opposite what an engine stand looks like, where the bottom piece with the
wheels is under the hanging engine.
1"x2" cross bracing would be fine here. No bracing would work too, just put
a small 2x4 block on either side of the flag pole leg, then attach the
blocks to floor board. Give yourself about 2' on the engine side and 6' feet
on the brother-in-law side. He can sit in a chair, so long as the chair is
on the floor board.
It sounds more complicated than it is. In the shop we could spit this out in
3 minutes. However, in the shop we have all the boards, screws, saws,
drills, quick-grips, etc right there :-)
Again, this is for a garage with exposed rafters. However, anything up on
the ceiling that you can attach the leg to will work. We're not talking that
much weight/force/torque up there, so long as you have the floor board in
place preventing the bottom from kicking out.
Good luck.
Montblack
Old March 12th 05, 02:14 AM
Ernest Christley
A-65.
My website is down because I just had to go messing with my router
(switching from Freesco to ClarConnect), but I have some pictures of the
stand I built for my 13B. Four 2x4 legs, with a 1/2x6 running around
the base. The top had 2x4 running around it, sized to just fit around
the oil pan. Screwed some nuts on four 3/8" bolts and drill holes form
them in the top of the 2x4 band, one in each corner. Drop the bolts
through washers into the holes, and the flange of the oil pan rested on
the bolts.
Slid the contraption to the front of the plane and I could adjust the
tilt and angle of the engine very accurately by adjusting the nuts on
the bolts. The plans called for 2/3degree upthrust, and I was able to
just dial it right in. Built the engine mount right in place. Had to
cut the stand apart to remove it (some of the mount legs ran through
it), but it took all of an hour to throw together from scrap wood.
ROP masking of engine problems Roger Long Owning 4 September 27th 04 07:36 PM
In-Flight Engine Failure O. Sami Saydjari Owning 59 April 30th 04 08:40 AM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
