Yes, IMHO accelerometers are a better way to go initially. This sort of thing has been done in commercial products, years ago although I don't know the details. Stangely enough, this is what I do for a living. No kidding. I am an engineer at Bently Nevada, Corp, the industry leader in machinery diagnostics. Most of our claim to fame is for rotating machinery; however, we do quite a bit of work with reciprocating engines as well. An accelerometer will work well. So will proximity (vibration) probes. We do all kinds of little tricks like putting a notch in the crankshaft to use as a phase reference. Then we can determine at what point in the cycle an anomaly occurs, which can lead to different diagnoses. We do a whole lot more, but I can't give away all of the trade secrets ;-) Adam N7966L Beech Super III |
"mindenpilot" wrote We do all kinds of little tricks like putting a notch in the crankshaft to use as a phase reference. Then we can determine at what point in the cycle an anomaly occurs, which can lead to different diagnoses. How does the notch help in telling the rotational position? -- Jim in NC |
"Morgans" wrote in message
... "mindenpilot" wrote We do all kinds of little tricks like putting a notch in the crankshaft to use as a phase reference. Then we can determine at what point in the cycle an anomaly occurs, which can lead to different diagnoses. How does the notch help in telling the rotational position? -- Jim in NC It takes a little nick out your finger as it goes by? Rich "Ow ow ow ow owow ow ow ow ow owow" S. |
Morgans wrote:
"mindenpilot" wrote We do all kinds of little tricks like putting a notch in the crankshaft to use as a phase reference. Then we can determine at what point in the cycle an anomaly occurs, which can lead to different diagnoses. How does the notch help in telling the rotational position? It adds a known vibration to the system? ;-) Presumably, it gets used as a timing mark of some kind. I guess that monitoring the spark time to the No 1 cylinder would almost give you the same. "Almost" because of course the spark can be advanced/retarded. Frank |
"Morgans" wrote in message ... How does the notch help in telling the rotational position? -- Jim in NC Without giving too much away... The notch depth is more significant than any vibration. If using a proximity measurment, it is easy to determine when the notch occurs. The notch is aligned with a known position (engineer inserts notch when pistons/crank is in known position). This gives a phase reference. You can compare where in the cycle a disturbance (knock, rub, etc) occurs with relation to the notch. On recip applications, often a multi-tooth wheel is used in addition to a phase reference for more accuracy. Adam N7966L Beech Super III |
"sleepy6" wrote That notch causes a much larger timing blip in the signal than any crank movement will cause. By measureing the time between the timing blips you can determine the amount of rotation after a timing blip that you see an up or down crank movement event. What sort of technology does a proxomity detector use? Magnetics, sonic, radio waves? -- Jim in NC |
Without giving too much away............ (yuk yuk yuk)
One can always post your questions at: http://www.vibinst.org/default.htm and usually somebody will be happy to answer. Phase indicators can be a variety of schemes or devices. Proximity probes, and notch. Strobe light. Magnetic interrupter. Photocell. Even the old proverbial pencil and masking tape! Kent Felkins Tulsa |
Jim, I have a Memsic demo board, which displays LEDS on two axis with their tilt and motion sensor. I am done with it, would you like to play with it? George Graham RX-7 Powered Graham-EZ, N4449E Homepage http://bfn.org/~ca266 |
| Thread Tools | |
| Display Modes | |
| Wierd vibration -- Prop or engine, balance or not??? | Chuck | Owning | 17 | December 1st 04 03:12 PM |
| Pinging Ron Wanttaja - "Unporting?" | Bob Chilcoat | Home Built | 13 | November 24th 04 08:28 PM |
| Vibration Testing | Jim Weir | Home Built | 20 | October 10th 04 08:22 AM |
| Vibration Testing | Jim Weir | Owning | 21 | October 10th 04 08:22 AM |
| Survey - 3 blade prop conversion- Cockpit vibration, happy or not | Fly | Owning | 20 | June 30th 04 06:32 PM |
