On a self-launch with pylon mounted prop, the prop wash can interfere with a
probe mounted on the vertical fin. One way to get around this is to use a pneumatic switch to change from tail probe to nose pitot/fuselage static when running the engine. Question is, what plumbing is best to switch, pitot, static, TE or combination of these? Glider in question is equipped with a 302 using pneumatic compensation (not electronic) and Tasman electronic back-up vario (no flask). Currently tail TE is plumbed to both varios direct (no switching). Two ganged pneumatic switches are used for the 302 pitot and static inputs to switch these from fuselage when motoring, to tail probe when soaring. ASI is connected to nose pitot/fuselage static (no switching). This configuration seems to work okay, but is this really the optimal configuration? For more sensitive detection of lift during self-launching, would it be better to switch the vario/s TE input from tail TE to cockpit or fuselage static, and forgo switching either pitot or static to the 302? Thanks for any input on this. all the best, bumper |
bumper wrote:
This configuration seems to work okay, but is this really the optimal configuration? For more sensitive detection of lift during self-launching, would it be better to switch the vario/s TE input from tail TE to cockpit or fuselage static, and forgo switching either pitot or static to the 302? If it were my glider, I'd always run the 302 off the nose pitot and fuselage static, using the 302s (excellent) electronic total energy compensation. The Tasman would always be connected to the TE probe, and just ignored when the engine is running. There is no need to add the complication of pneumatic switches... Marc |
I have my varios plumbed as Marc suggests, but in my case the other
vario is a Winter. It bounces all over the place while under power, while the 302 provides an excellent aid in finding and centering a thermal ASAP after launch. -Tom |
That's how my TwinIII SL was working. With a Peschges VP 6, that did
it's own thing with Pitot and static for TE compensation. The ship did have a Pneumatic switch, and simply turned the Probe on and off in the back. I think I was able to also feed the VP 6 with the probe, but never did, and compared Dieter |
T o d d P a t t i s t wrote:
Marc Ramsey wrote: If it were my glider, I'd always run the 302 off the nose pitot and fuselage static, using the 302s (excellent) electronic total energy compensation. As MIke Borgelt recently pointed out, this produces two in phase error signals. Running with the pitot and static both on the nose or both on the tail, preferably with the pitot twice as far from your CG, will produce canceling errors for electronic TE. Yes, I'm sure it makes sense in theory. In practice, I'm flying a glider with an electronic TE vario (C302) on nose pitot and tail boom static (which is all that is available), and I've never seen it shown any "errors" that weren't also present on the B40 running on the TE probe by itself. But, YMMV... I've had problems in the past, in several different gliders, with the combined pitot/static/TE tail probes (I've got 3 different types of multi-probes gathering dust in the closet, right now) measuring airspeeds that vary by several knots from the nose pitot, fuselage static setup. It's, of course, hard tell which was more accurate (unless you're Dick Johnson), but given that the POHs inevitably require use of latter setup for the ASI and altimeter, I'd rather have everything working off the same source... Marc |
"T o d d P a t t i s t" wrote in message ... Marc Ramsey wrote: If it were my glider, I'd always run the 302 off the nose pitot and fuselage static, using the 302s (excellent) electronic total energy compensation. I'm flying a glider with an electronic TE vario (C302) on nose pitot and tail boom static (which is all that is available), and I've never seen it shown any "errors" I have very limited personal experience with electronic TE. I'll take your word for it that it works for you on the nose pitot and tail static. That said, however, I have found Mike Borgelt's comments to be right on target every time, so even if it works for you, others may see problems. When I ordered my 302, I talked with Dave Ellis about using the tail probe inputs vs. using the 302's electronic compensation. This was several years ago, so I may be leaving something out. The gist of it was that he felt the 302's electronic compensation was very good, but not quite as good as a well installed fin mounted TE probe with good plumbing. I also discussed pneumatic switching for a self-launch with Dave . . . and he agreed this to be an acceptable approach. That's were the old brain starts to fade a bit, as I can't remember if we discussed exactly *what* to switch (g) . . . and that's why I posted my original question. I am aware that I can simply use the 302's very good electronic TE. However, since I went to the effort to design and install a remote mount for two Clippard pneumatic switches near the forward end of the glareshield (where they take no panel space), I'll continue to use them *if* that turns out to be the best solution. The switching works fine BTW, no leaks and so far reliable. Absent a better suggestion, I'll leave it the way it is. all the best, bumper |
| Thread Tools | |
| Display Modes | |
| Flap handle activated Climb/Cruise switching | Andy Smielkiewicz | Soaring | 5 | March 14th 05 05:54 AM |
| Switching to JeppView | Travis Marlatte | Instrument Flight Rules | 16 | December 19th 04 05:25 PM |
| Airmen at Osan switching from M16A2 to lighter M4 carbine, By Franklin Fisher, Stars and Stripes | Otis Willie | Military Aviation | 0 | April 29th 04 05:07 AM |
| Switching to ground.... | David Rind | Piloting | 85 | April 16th 04 07:53 PM |
| Transponder code switching | Ken Pruchnick | Instrument Flight Rules | 30 | October 12th 03 09:31 PM |
