wing levelers
Old March 14th 05, 08:34 PM
Dan, U.S. Air Force, retired
Dale Larsen wrote:
As I see it, accelerometers and GPS together are all that's needed. If the
vectors from all 3 accelerometers are in the right direction, and the
average GPS heading is not moving much- you're straight and level.
Ron-Using accelerometers in 3d space will soon become inaccurate due to
small errors in the accelerometers, math rounding errors and drift. How do
you propose to 'erect' such a device to keep the shiny side up?
Add a VG.... let's see the second integral....
OK, too complicated...keep a cat in the cockpit, periodically drop it on
the floor, since cats always land feet first.....
No, cats tend to get cranky when you do that.....
  #82
Old March 15th 05, 01:50 AM
Ron Webb
do you propose to 'erect' such a device to keep the shiny side up?
The only constant acceleration is the acceleration of gravity. A "leaky
integrator" with a 2 or 3 second Tau should work fine.
If it can be done mechanically, it can be done electronically.
  #83
Old March 16th 05, 08:57 AM
Roger
On Mon, 14 Mar 2005 16:50:34 -0900, "Ron Webb"
How so? the plane doesn't know if it's right side up or not.
You can do a barrel roll, or loop and always keep "down" through the
bottom of the seat.
www.rogerhalstead.com
  #84
Old March 17th 05, 04:43 AM
Ron Webb
bottom of the seat.
Roger
That's a good question. I have run every other scenario over in my mind, and
it looks to me that the proposed system should deal with them under any
normal circumstances.
However, I had not considered a constant acceleration "barrel roll" while
maintaining the same heading.
How to sense that???
My original idea had included an electronic "Gyroscpe"
I had eliminated it when I discovered how hard the iMEMS ADXRS300
http://www.analog.com/en/prod/0,,764...S300%2C00.html
are to get, but I may have to put it back.
A homemade version is available.
http://home.comcast.net/~scottxs/pie.../piezindex.htm
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Wing tip stalls mat Redsell Soaring 5 March 13th 04 05:07 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 03:52 AM
