I am planning to buy a factory-built LSA within a few months. All the
aircraft I am considering will be built by companies with a history of selling kits - e.g., Rans, Kolb, Kitfox, etc. Any homebuilders out there have any opinions about any of these companies and their products? Thanks |
Are any of those aircraft built under the "consensus standards"? Are the
consensus standards even finalized yet? "Willard" wrote in message ups.com... I am planning to buy a factory-built LSA within a few months. All the aircraft I am considering will be built by companies with a history of selling kits - e.g., Rans, Kolb, Kitfox, etc. Any homebuilders out there have any opinions about any of these companies and their products? Thanks |
On Mon, 3 Jan 2005 11:26:29 -0600, "Gig Giacona"
wrote: "Willard" wrote in message oups.com... I am planning to buy a factory-built LSA within a few months. All the aircraft I am considering will be built by companies with a history of selling kits - e.g., Rans, Kolb, Kitfox, etc. Any homebuilders out there have any opinions about any of these companies and their products? Are any of those aircraft built under the "consensus standards"? Are the consensus standards even finalized yet? The consensus standards have been released, you can order them from www.astm.org (Stock number: Aircraft04). It's an 80-page document, used in lieu of a few hundred pages of conventional FAR. Interesting read. The maintenance standard is still under discussion, but it will probably be out soon. The FAA is having its first course for DAR-LSAs this month, but I believe a standard DAR (or, of course, the local FSDO) can do the safety sign-off for a production LSA. Ron Wanttaja |
"Ron Wanttaja" wrote in message ... On Mon, 3 Jan 2005 11:26:29 -0600, "Gig Giacona" wrote: "Willard" wrote in message roups.com... I am planning to buy a factory-built LSA within a few months. All the aircraft I am considering will be built by companies with a history of selling kits - e.g., Rans, Kolb, Kitfox, etc. Any homebuilders out there have any opinions about any of these companies and their products? Are any of those aircraft built under the "consensus standards"? Are the consensus standards even finalized yet? The consensus standards have been released, you can order them from www.astm.org (Stock number: Aircraft04). It's an 80-page document, used in lieu of a few hundred pages of conventional FAR. Interesting read. The maintenance standard is still under discussion, but it will probably be out soon. The FAA is having its first course for DAR-LSAs this month, but I believe a standard DAR (or, of course, the local FSDO) can do the safety sign-off for a production LSA. Ron Wanttaja So it is. Though I couldn't find it with AVIATION04 as a search I did find this http://www.astm.org/COMMIT/F37.htm just ordered a copy. That still begs the question as to if a plane has been built to this standard yet or will be in a few months as the OP seemed to beleive. |
"Ron Wanttaja" wrote The consensus standards have been released, you can order them from www.astm.org (Stock number: Aircraft04). It's an 80-page document, used in lieu of a few hundred pages of conventional FAR. Interesting read. The maintenance standard is still under discussion, but it will probably be out soon. The FAA is having its first course for DAR-LSAs this month, but I believe a standard DAR (or, of course, the local FSDO) can do the safety sign-off for a production LSA. Ron Wanttaja Is it correct to say that the consensus standards do not apply, when it is a plans built? How about kit meeting 51% self built rule? I'm still not exactly sure I understand what an experimental LSA is, and what hoops must be jumped through. -- Jim in NC |
On Mon, 03 Jan 2005 22:30:18 GMT, (sleepy6) wrote:
In article , says... Is it correct to say that the consensus standards do not apply, when it is a plans built? How about kit meeting 51% self built rule? I'm still not exactly sure I understand what an experimental LSA is, a and what hoops must be jumped through. An ELSA is simply an SLSA that has been pulled off the production line at whatever point the customer wants. The customer then finishes the planes following the EXACT factory instructions but it must be identical to the SLSA. All factory parts and no modifications at all. It is subject to the same maintaince etc requirements as SLSA but can not be used for instruction or rental. Sleepy is correct. The LSA regs do not affect the classic 51% homebuilts *at all*. The same old process is in effect. If your 51% homebuilt meets the definition of a Light Sport Aircraft (gross weight, stall speed, etc.) it can be flown by a person with Sport Pilot privileges (either someone with an actual Sport Pilot license, or someone with a higher license and an lapsed medical) but the licensing and maintenance regulations are the same as they've always been. One small point that I'll correct Sleepy on: The Experimental LSA is not quite subject to the same maintenance requirements of a Special Light Sport Aircraft. On the SLSA: 1. Preventative maintenance can be performed by the owner (just like FAR 23 aircraft). 2. Normal/major maintenance must be performed by an A&P or a person with a Light Sport-Maintenance (LS-M) Repairman Certificate 3. Annual inspections must be performed by either an A&P or a person with a LS-M Repairman Certificate. For the ELSA: 1&2. Preventative AND Normal/major maintenance can be performed by the owner 3. Annual inspections must be performed by an A&P, a person with a LS-M Repairman Certificate, or someone with the other new Repairman Certificate, Light Sport- Inspection (LS-I). The LS-I Repairman Certificate is similar to the Amateur-Built aircraft repairman certificate, with two significant exceptions: First, the applicant must complete a 16-hour training course. You can NOT receive an LS-I just by assembling an ELSA. You MUST take the course. Second, a person with an LS-I may perform the annual inspection on *any* ELSA they own. Unlike the Amateur-Built Repairman Certificate, it is not applicable to only one aircraft. Once you earn the LS-I, you can buy another ELSA kit or a completed ELSA aircraft and perform the annual inspections on it. Sleepy touches on one sporty item about the ELSA category. Like he says, the ELSA kit *must* be built exactly to the LSA kit manufacturer's instructions. You cannot install an alternate engine, use a different covering system, etc. It must be built precisely to the manufacturer's callout. However... as far as I can tell, the owner can then modify the aircraft however they chose, once the plane receives its formal ELSA airworthiness certificate. Owners of SLSAs (the production LSAs) must maintain their aircraft in precise accordance to the manufacturer's maintenance plan and continued safety directives to continue to conform to the consensus standard. But the FAA also says that owners of SLSAs can avoid having to follow the SLSA's manufacturer's safety directives by changing their plane's airworthiness to ELSA. It follows, then, that ELSAs are NOT required to continue to comply to the consensus standard, and owners can modify them once they've received their original ELSA certification. Ron Wanttaja |
On Mon, 03 Jan 2005 23:24:21 GMT, Ron Wanttaja wrote:
It is subject to the same maintaince etc requirements as SLSA but can not be used for instruction or rental. Sleepy is correct. Whoops, noticed something else. I believe ELSAs *can* be used for instruction and rental, through 2010. That's what's covering the two-seat ultralight trainers that must convert to ELSA. Ron Wanttaja |
Williard,
You will, no doubt get a lot of messages in response to your post regarding the LSA rules, the availability of factory built, sLSA certified aircraft and so forth. I will apply good common sense and assume that you will not be buying one of these airplanes until they are available (whenever that is, two months or 10 months) and answer the question that you actually asked. I have experience with RANS and Kitfox aircraft. I have personally built 5 RANS kitplanes and I have known Randy Schlitter since 1988. The airplanes are top notch, customer support and service are second to none. RANS has a production certificate in hand and can build S-7 Couriers today. To my knowledge, this is the only LSA legal, new airplane that is certified right now. The RANS S-6 Coyote is a great airplane and is very easy to build. As a matter of fact, I would encourage you to buy a RANS S-6 kit with Quickbuild option and put it together yourself. You can license it under Experimental/Amateur Built and fly it with a no-medical Sport Pilot license. By building it yourself, you can do your own annual condition inspections and repairs. One of the S-6's that I built was assembled in 48 days of part time work. That was before the quickbuild option was available. In regard to the Kitfox, it is a very nice airplane with good handling qualities. I have test flown one and ferried one for the owner when it was sold. I do not have any first hand knowledge of what the Kitfox is like to build or the company's customer service. Blue Skies! Rick Pellicciotti Willard wrote: I am planning to buy a factory-built LSA within a few months. All the aircraft I am considering will be built by companies with a history of selling kits - e.g., Rans, Kolb, Kitfox, etc. Any homebuilders out there have any opinions about any of these companies and their products? Thanks |
Is it correct to say that the consensus standards do not apply, when i t is a plans built? How about kit meeting 51% self built rule? I'm still not exactly sure I understand what an experimental LSA is, a nd what hoops must be jumped through. -- Jim in NC An ELSA is simply an SLSA that has been pulled off the production line at whatever point the customer wants. The customer then finishes the planes following the EXACT factory instructions but it must be identical to the SLSA. All factory parts and no modifications at all. It is subject to the same maintaince ect requirements as SLSA but can not be used for instruction or rental. Sorry, but you didn't catch what I asked. What about the plans built, or one that has no assembly, at all? What about the guy that designs one (one off) that fits under the specs of the rule? -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 04:13 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 03:31 PM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 06:15 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 08:29 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 3rd 04 12:41 AM |
