Is there a rule of thumb for 'speed of heat'? Meaning the speed in
knots where ice will not form on the leading edges of a wing. For example, the Saberliner had no de-ice or anti-ice system, just speeding up would remove or prevent ice build up. Thanks. |
I don't know the formula but Saberliners are too slow to offer reliable
deicing from speed alone although, like anything else, they change temp with velocity. I recall reading that you need 400kt indicated for complete protection. Mike MU-2 "vlado" wrote in message ups.com... Is there a rule of thumb for 'speed of heat'? Meaning the speed in knots where ice will not form on the leading edges of a wing. For example, the Saberliner had no de-ice or anti-ice system, just speeding up would remove or prevent ice build up. Thanks. |
In the Citation the temp difference is about 4 degrees. I think it goes
up exponentially as you approach the speed of sound. You have to get pretty close to the speed of sounds before you get much difference (I think). -Robert |
On 14 Mar 2005 21:23:47 -0800, "vlado" wrote:
Is there a rule of thumb for 'speed of heat'? I don't have a CR-2 with me, but it seems like the ram rise at M.82 is about 7 deg C. Icing conditions don't occur at flight levels for cruise anyway, so a jet aircraft will only ice during climb, decent, or holding. If the old gray matter serves me, I think Rockwell proved the aircraft could fly acceptably with any ice load it was expected to encounter. The type certificate for the military versions show them as VFR only when operating in the civil system. I doubt seriously it could pass the testing now required for certification. I seem to remember some de-ice mods to later versions, but I'm not sure. They did de-ice the engines and the windscreens are heated. Most of these aircraft are in the scrap yard by now I would imagine. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Don Hammer wrote: On 14 Mar 2005 21:23:47 -0800, "vlado" wrote: Is there a rule of thumb for 'speed of heat'? I don't have a CR-2 with me, but it seems like the ram rise at M.82 is about 7 deg C. The Mach heating temperature rise ratio (T_t / T_s) at M0.82 is .13348 referenced to absolute temperature regardless of altitude and other atmospheric conditions. For example, if the static air temperature (T_s) is -40F, then the total temperature (T_t) is +16F. The Mach heating formula is: TAU = T_t / T_s = 1 + ((gamma-1)/2)M^2 For a typical atmospheric gamma value of 1.4, the equation reduces to: T_t / T_s = 1 + .2M^2 Converting -40F to absolute: -40 + 459 = 419R Insert temperature and Mach into the formula: T_t / T_s = 1 + .2 * .82^2 = 1.13448 And: T_t = T_s * 1.13448 = 419 * 1.13448 = 475R = 16F So, if the outside air temperature is -40F ambient (zero velocity), then at M0.82 the total temperature would be +16F. Icing conditions don't occur at flight levels for cruise anyway, so a jet aircraft will only ice during climb, decent, or holding. This is not correct. Icing conditions can and do occur at any altitude in which visible moisture is present. If the old gray matter serves me, I think Rockwell proved the aircraft could fly acceptably with any ice load it was expected to encounter. The type certificate for the military versions show them as VFR only when operating in the civil system. I doubt seriously it could pass the testing now required for certification. I seem to remember some de-ice mods to later versions, but I'm not sure. They did de-ice the engines and the windscreens are heated. Most of these aircraft are in the scrap yard by now I would imagine. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com -- Kurt Todoroff Markets, not mandates and mob rule. Consent, not compulsion. |
(TripFarmer) wrote: Don't you eventually have to slow down? )Trip In article .net, says... I don't know the formula but Saberliners are too slow to offer reliable deicing from speed alone although, like anything else, they change temp with velocity. I recall reading that you need 400kt indicated for complete protection. Mike MU-2 "vlado" wrote in message oups.com... Is there a rule of thumb for 'speed of heat'? Meaning the speed in knots where ice will not form on the leading edges of a wing. For example, the Saberliner had no de-ice or anti-ice system, just speeding up would remove or prevent ice build up. Thanks. By the way, in the jet fighter business, we referred to the speed of sound (Mach) as the "speed of heat". -- Kurt Todoroff Markets, not mandates and mob rule. Consent, not compulsion. |
All of the others talk of temperature rise do to compressibility based on
mach number, but no one really addressed the speed accounting for friction of air molecules on the sheet metal which warms the aircraft. War story time, low level over the plains of eastern Montana, near Conrad and Havre Bomb Plots (Radar Bomb Scoring sites) and the outside air temp was about -15F, however, we were moving along at about .88mach at 500ft AGL, and the skin temperature was about 100F, not a worry about accumulating icing. Some one else referred to "Speed of heat" as being Mach 1, because most aircraft need after-burner or "heat" (reheat) as the Brits would say.. to make Mach1. BTDT BT "vlado" wrote in message ups.com... Is there a rule of thumb for 'speed of heat'? Meaning the speed in knots where ice will not form on the leading edges of a wing. For example, the Saberliner had no de-ice or anti-ice system, just speeding up would remove or prevent ice build up. Thanks. |
I found this formula:
http://williams.best.vwh.net/avform.htm#Mach Which shows a temp rise pretty close to what the MU-2 flight manual shows. Mike MU-2 "vlado" wrote in message ups.com... Is there a rule of thumb for 'speed of heat'? Meaning the speed in knots where ice will not form on the leading edges of a wing. For example, the Saberliner had no de-ice or anti-ice system, just speeding up would remove or prevent ice build up. Thanks. |
In article R5QZd.71896$Tt.15712@fed1read05,
"BTIZ" wrote: All of the others talk of temperature rise do to compressibility based on mach number, but no one really addressed the speed accounting for friction of air molecules on the sheet metal which warms the aircraft. War story time, low level over the plains of eastern Montana, near Conrad and Havre Bomb Plots (Radar Bomb Scoring sites) and the outside air temp was about -15F, however, we were moving along at about .88mach at 500ft AGL, and the skin temperature was about 100F, not a worry about accumulating icing. Some one else referred to "Speed of heat" as being Mach 1, because most aircraft need after-burner or "heat" (reheat) as the Brits would say.. to make Mach1. BTDT BT Hi BT, What were you flying? Most of my time is in the F-111D and the EF-111A. I've also flown the F-15, C-130, C-141, KC-10, E-3. Did your aircraft have a skin temperature indicator or a total temperature indicator? Aircraft component heating is due to Mach compressibility, not skin friction. I'm confident that your 100F value reflected total temperature which is based on Mach compressibility. The "speed of heat" received it's colloquial name because the speed of sound is based only on the static temperature of the fluid medium, not on pressure or density as is often mistakenly believed. -- Kurt Todoroff Markets, not mandates and mob rule. Consent, not compulsion. |
| Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 01:18 PM |
| Painting and air cooled motor? | CitizenX | Home Built | 5 | June 30th 04 01:47 PM |
| Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 09:35 PM |
| Va and turbulent air penetration speed. | Doug | Owning | 69 | January 11th 04 09:35 PM |
| Speed Astir | Guy Acheson | Soaring | 0 | December 11th 03 03:24 AM |
