#21
Bill wrote:
often impractical to go IFR because they force you so high. You will also find that in many areas in the West that they make you fly well above the MEAs even on victor airways. Complaining doesn't help. Bill: the victor airway LVS-TAFOY-SAF has MEAs of 12.3 over LVS, 8.4 at TAFOY and 11.3 at SAF. However, let me reiterate...assuming VMC, there's no reason to file IFR for LVS-TAFOY-SAF. It can safely and easily be done at 10.5 or even 8.5 as VFR. Now, if the weather isn't good, that's another story. But still, the 12.3 point in the LVS block is west of LVS itself. LVS itself is only 6900. V60 to TAFOY then V62 to SAF avoids cumulo granite. It's V190 and V263 that run right into them thar hills. Second issue is "mountains". Those of us that live out here do not fly "in the mountains" as a rule in a single engine aircraft. Well, maybe in a Pilatus, but certainly not in my cherokee 180. Even something higher performance will still require careful planning and most people will head straight for the passes and not go over the tops. The LVS-TAFOY-SAF route is very practical and a wise choice for someone who's never been out here before. There's a number of mountain flying CFIs on this list who can provide more insight. There are a number of CAP pilots on this list also, who *have* flown single-engine "in the mountains" out here -- and they're very-very-very-VERY good and wise pilots. |
John R. Copeland wrote:
Adding another item -- The runways at the Santa Fe airport can be fiendishly hard to see from a distance. The pavement seems to blend in to the surrounding sand. I'd suggest planning on an instrument approach regardless of weather. Nah...Come right over the SAF VOR, follow the straight line over the prison and there you are. Helps to have the GPS on. But the SAF tower is very helpful to the pilot that states "unfamiliar with the area" and will guide you right in. But then, just about every airport around here blends in with the surrounding dirt. |
In article , Blanche
wrote: the victor airway LVS-TAFOY-SAF has MEAs of 12.3 over LVS, 8.4 at TAFOY and 11.3 at SAF. Hmmm...the chart I'm looking at (NAS) has an MEA of 10K between LVS and TAFOY and 10K between TAFOY and SAF Vortac. I understand that one can go lower VFR, but where do the altitudes you quote above come from? |
Tom Fleischman wrote:
wrote: the victor airway LVS-TAFOY-SAF has MEAs of 12.3 over LVS, 8.4 at TAFOY and 11.3 at SAF. Hmmm...the chart I'm looking at (NAS) has an MEA of 10K between LVS and TAFOY and 10K between TAFOY and SAF Vortac. I understand that one can go lower VFR, but where do the altitudes you quote above come from? I'm looking at L5/L6 IFR Low Enroute (ok, it's July 2003 but mountains rarely move). The square with LVS has off-route obstruction clearance alt as 15.3 and yes, you're right (my bad...I was reading the OROCA in a generic mode as the MEA) the MEA is 10K. Oops is all I can say. (*sigh*) Sorry. |
"Blanche" wrote in message =
... John R. Copeland wrote: Adding another item -- The runways at the Santa Fe airport can be fiendishly hard to see from a distance. The pavement seems to blend in to the surrounding sand. I'd suggest planning on an instrument approach regardless of weather. =20 Nah...Come right over the SAF VOR, follow the straight line over the prison and there you are. Not meaning to pick nits, Blanche, but coming "right over the SAF" isn't greatly different from the VOR Rwy 33 approach. That's roughly the same as I suggested. We eastern pilots can get unnerved by being unable to see a runway ten miles away in 50-mile visibility. I remember once telling the SAF tower I could see the airport, but not the runway. :-[ |
"Blanche" wrote in message John R. Copeland wrote: Adding another item -- The runways at the Santa Fe airport can be fiendishly hard to see from a distance. The pavement seems to blend in to the surrounding sand. I'd suggest planning on an instrument approach regardless of weather. Nah...Come right over the SAF VOR, follow the straight line over the prison and there you are. Not meaning to pick nits, Blanche, but coming "right over the SAF" isn't greatly different from the VOR Rwy 33 approach. That's roughly the same as I suggested. We eastern pilots can get unnerved by being unable to see a runway ten miles away in 50-mile visibility. I remember once telling the SAF tower I could see the airport, but not the runway. :-[ Go ahead, pick nits...I deserved it...Since I don't fly into SAF unless it's VMC, I never take the VOR approach... And I can't count the number of times I've done go-arounds at airports out here because I didn't see the runway until the last minute and was too high, too fast or both. And sometimes, didn't even see the airport.... |
... John R. Copeland wrote: I remember once telling the SAF tower I could see the airport, but not the runway. :-[ =20 Go ahead, pick nits...I deserved it...Since I don't fly into SAF unless it's VMC, I never take the VOR approach... =20 And I can't count the number of times I've done go-arounds at airports out here because I didn't see the runway until the last=20 minute and was too high, too fast or both. And sometimes, didn't even see the airport.... Oh, good. That means it's not just me. :-) Tom Fleischman, take note! |
#28
wrote: Tom Fleischman wrote: wrote: the victor airway LVS-TAFOY-SAF has MEAs of 12.3 over LVS, 8.4 at TAFOY and 11.3 at SAF. Hmmm...the chart I'm looking at (NAS) has an MEA of 10K between LVS and TAFOY and 10K between TAFOY and SAF Vortac. I understand that one can go lower VFR, but where do the altitudes you quote above come from? I'm looking at L5/L6 IFR Low Enroute (ok, it's July 2003 but mountains rarely move). The square with LVS has off-route obstruction clearance alt as 15.3 and yes, you're right (my bad...I was reading the OROCA in a generic mode as the MEA) the MEA is 10K. Oops is all I can say. (*sigh*) Sorry. No problemo....thanks for all your input ![]() |
#29
In article , John R. Copeland
wrote: "Blanche" wrote in message ... John R. Copeland wrote: snip And I can't count the number of times I've done go-arounds at airports out here because I didn't see the runway until the last minute and was too high, too fast or both. And sometimes, didn't even see the airport.... Oh, good. That means it's not just me. :-) Tom Fleischman, take note! Thanks, I have. |
| Thread Tools | |
| Display Modes | |
| Want simple flight planning software | marc | Home Built | 13 | December 20th 04 05:36 AM |
| Want simple flight planning software | marc | Piloting | 13 | December 20th 04 05:36 AM |
| Free Flight Planning Software | Dean Wilkinson | Piloting | 20 | September 25th 04 04:38 AM |
| Free Flight Planning Software | Dean Wilkinson | Products | 0 | September 18th 04 11:44 PM |
| Route planning question | Paul Tomblin | Instrument Flight Rules | 3 | April 4th 04 03:40 PM |
