Dave Butler wrote:
Interesting. I didn't see anything like that. Do you have to be at a low altitude to see the obstacles? Actually I was in simulator mode- whaetever altitude that mode defaults to. I don't recall the zoom level- 5 miles maybe. |
Dave Butler wrote:
Oh yeah, in simulator mode it would from time to time pop up "Obstacle warning!". I'm not sure what radius or direction the obstacle had to be to trigger the warning. I just figured out that you can control this (to some extent) by hitting the menu button while on the map page. From there you can get to "Set Up Obstacles" which lets you set a "Caution Elevation" and "Look Ahead Time". They default to 1000ft and 120 seconds respectively, but can be set as low as 500ft and 60 seconds which result in less frequent warnings. Also I noticed that Obstacle Warnings would pop up even if the map was zoomed beyond the level require to actually display the obstacles. In which case you have to manually zoom in until the obstacle becomes visible- kind of stupid. I've concluded that the 'auto' setting you mentioned is fine, but dulling the sensetivity to obstacle alerts is the way to go. You'll basically get an alert if there's a real problem, otherwise you'll just never have to be bothered with obstacles on the screen. -max |
George Graham ----Garmin 95XL database | Bill Zaleski | General Aviation | 2 | April 28th 11 09:14 PM |
Aviation database for Garmin 2610/2620? | Slav Inger | Piloting | 12 | September 9th 04 07:08 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Garmin 295 & Jeppesen database | Paolo | Products | 0 | April 25th 04 06:07 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
