I am still in the design phase of my original plane. I am looking into a
composite built airplane. Can anyone share insight to the costs of different composites, and maybe some pro's and con's? |
And another dreamer gets the bug... Find your local EAA chapter... Join
it... Get to know the guys and see their projects... You will be more educated, more enlightened, and more likely to actually finish a project - and have it actually fly... |
"Denny" wrote in message
oups.com... And another dreamer gets the bug... Find your local EAA chapter... Join it... Get to know the guys and see their projects... You will be more educated, more enlightened, and more likely to actually finish a project - and have it actually fly... Better still, also visit and get to know some of the members of additional chapters, if there are more than one chapter in your area. Eight of ten years ago, my chapter appeared to be a "Cozy" chapter, and has since become more of an "RV" chapter, although there are numerous other types of aircraft and projects ... There is little question that a moldless composite is the cheapest form of construction and the easiest to form into complex shapes; and *if* you have the skill and mindset work the Burt Rutan used to do, it can also be the fastest to complete. However, fiber reinforced plastic has some real quirks. Although it would currently be my material of choice, I would also need a *lot* of advice before trying to go from the 'doodle pad' to a physical project. Back when the Vari Eze's were fairly new, and Burt Rutan was touring the country and giving seminars; I watched him work at one of them. That proved, beyond question, that moldless composite is the fastest possible construction method for 'plans built' or 'custom built' aircraft. However, the experience of chapter members on their projects suggest that there are multiple reasons for the project to 'bog down' ... Also, keep in mind that your building space, especially if you have to rent, is part of the project cost. Even though, for esthetic reasons, I don't like 'Hershey Bar' wings; an RV-9 Quick Build can start looking like a very good value, when you include the rental of a hangar or warehouse. So, join a chapter. Visit all you can reasonable drive (or fly) to. And pick as many brains as you can. |
I went to the local chapter. Most of the guys there built an ultralight in
the 60's, and that was it.... I am not saying anything bad about that chapter, or the EAA, but I need a little more guidance. I am looking at cost verses weight & stength. Any words of advice besides "Join EAA"? "Peter Dohm" wrote in message . .. "Denny" wrote in message oups.com... And another dreamer gets the bug... Find your local EAA chapter... Join it... Get to know the guys and see their projects... You will be more educated, more enlightened, and more likely to actually finish a project - and have it actually fly... Better still, also visit and get to know some of the members of additional chapters, if there are more than one chapter in your area. Eight of ten years ago, my chapter appeared to be a "Cozy" chapter, and has since become more of an "RV" chapter, although there are numerous other types of aircraft and projects ... There is little question that a moldless composite is the cheapest form of construction and the easiest to form into complex shapes; and *if* you have the skill and mindset work the Burt Rutan used to do, it can also be the fastest to complete. However, fiber reinforced plastic has some real quirks. Although it would currently be my material of choice, I would also need a *lot* of advice before trying to go from the 'doodle pad' to a physical project. Back when the Vari Eze's were fairly new, and Burt Rutan was touring the country and giving seminars; I watched him work at one of them. That proved, beyond question, that moldless composite is the fastest possible construction method for 'plans built' or 'custom built' aircraft. However, the experience of chapter members on their projects suggest that there are multiple reasons for the project to 'bog down' ... Also, keep in mind that your building space, especially if you have to rent, is part of the project cost. Even though, for esthetic reasons, I don't like 'Hershey Bar' wings; an RV-9 Quick Build can start looking like a very good value, when you include the rental of a hangar or warehouse. So, join a chapter. Visit all you can reasonable drive (or fly) to. And pick as many brains as you can. |
![]() "Pilot Guy" wrote in message ... I went to the local chapter. Most of the guys there built an ultralight in the 60's, and that was it.... I am not saying anything bad about that chapter, or the EAA, but I need a little more guidance. I am looking at cost verses weight & stength. Any words of advice besides "Join EAA"? snip I've been to three local chapters. The first one has about 20 people show up, nothing much happens there. The second one has about 30 people show up, I think I was the only one under 65 (maybe 70), no one was talking about building anything. The third one has about 60 people show up, everyone is building something, great conversations before and after the meeting. Guess which chapter I joined? ;^) |
![]() "Pilot Guy" wrote in message ... I went to the local chapter. Most of the guys there built an ultralight in the 60's, and that was it.... I am not saying anything bad about that chapter, or the EAA, but I need a little more guidance. I am looking at cost verses weight & stength. Any words of advice besides "Join EAA"? I still think that a chapter, or more than one, is a good starting point for other people's experience. As you point out, you may finda fairly hide bound group who are quite content with the past... However, they are the most easily accessible. EAA headquarters is also a resource for the members, and they also sell books on composite fabrication; as well as other methods. Additional sources that *may* be available could include AE/IA's, some of the guys in your nearby SCCA (Sports Car Club of America) who may have some experience with composites in racing cars, and boat builders (although they may have a nearly total disregard for weight). I have heard that carbor fiber is/was popular for outer bodies of race cars; but that it shatters on impact. Apparently very strong and very stiff, but low energy absorption. Assuming that you are already very comfortable with the design requirements, including the attachment of hard points and the transfer of loads from the wings, tail, and engine to the fuselage; the manufactures and dealers of the fiber, cloth, and resin will be the best source of prices as well as any special procedures specific to their products. By the way, if you are really comfortable with the design requirements of these highly directional materials and with their attachment to any necessary mounting hardware or dissimilar materials, evenbefore you know the weight, cost, and other specifics; then you are probably either much smarter or much more foolish than the rest of us! |
Pilot Guy wrote:
I went to the local chapter. Most of the guys there built an ultralight in the 60's, and that was it.... Yes, but, did you look into other chapters nearby? For example, there are two chapters near me- one is about a 45 minute drive, the other chapter is an hour away. It so happens that farther one's monthly meetings work much better with my own work schedule. Luckily both chapters happen to have a variety of construction styles in the completed projects- tube/fabric, composite, and of course, lots of RVs. Also, have you tried simply walking into the FBO at any small airport? I bet you need to talk to just a few people before somebody knows somebody who can point you to a homebuilder working on their project. Go in, share some coffee and chatter, and offer to help out fixing or building whatever on their airplane... seriously, try this out. I am not saying anything bad about that chapter, or the EAA, but I need a little more guidance. I am looking at cost verses weight & stength. Any words of advice besides "Join EAA"? If you join EAA the members area of their website has a great deal of articles. It may take you literally a few days to read through everything. Also, check out the matronics website: http://www.matronics.com/emaillists/ It hosts several email lists, and you should find at least one or two (probably more) to be very suitable to your purpose. Those lists are also archived on that website, so even without subscribing to any of the lists you have a few more good days of solid reading. Keep looking online- try an archives search for this newsgroup. Google search things like "homebuilt composite design construction," I bet you'll find some personal websites with detailed construction logs. Even the Aircraft Spruce catalog has a few pages of general info on each major construction method. Uh, that's just off the top of my head. ![]() |
I built my own kayak and canoe and went through the same questions. Because
you often need to carry the kayak and canoe, weight is a big factor. I got most of my answers at Tap Plastics. Any local plastics outlet will have the various cloths that would be used, together with books and clerks who know the various materials. RVs seems to be popping up everywhere, and that tends to diminish the need to learn about various materials. So, you may run into a campaign for you to build an RV if you visit an EAA chapter. So, visit the kayak websites and any local kayak manufacturers. You should be able to find a chart of various materials used in constructing kayaks, and you can visit the websites to see the hype for that material (do not necessarily believe all of it. Kayaks going through white water need to be tough. 73, K7FM |
COLIN LAMB wrote:
I built my own kayak and canoe and went through the same questions. Because you often need to carry the kayak and canoe, weight is a big factor. I got most of my answers at Tap Plastics. Any local plastics outlet will have the various cloths that would be used, together with books and clerks who know the various materials. RVs seems to be popping up everywhere, and that tends to diminish the need to learn about various materials. So, you may run into a campaign for you to build an RV if you visit an EAA chapter. So, visit the kayak websites and any local kayak manufacturers. You should be able to find a chart of various materials used in constructing kayaks, and you can visit the websites to see the hype for that material (do not necessarily believe all of it. Kayaks going through white water need to be tough. 73, K7FM I would think it's a different kind of toughness what with bouncing off of boulders and all. Dan, U.S. Air Force, retired |
![]() "Jim Carriere" wrote in message ... Pilot Guy wrote: I went to the local chapter. Most of the guys there built an ultralight in the 60's, and that was it.... Yes, but, did you look into other chapters nearby? For example, there are two chapters near me- one is about a 45 minute drive, the other chapter is an hour away. It so happens that farther one's monthly meetings work much better with my own work schedule. Luckily both chapters happen to have a variety of construction styles in the completed projects- tube/fabric, composite, and of course, lots of RVs. Also, have you tried simply walking into the FBO at any small airport? I bet you need to talk to just a few people before somebody knows somebody who can point you to a homebuilder working on their project. Go in, share some coffee and chatter, and offer to help out fixing or building whatever on their airplane... seriously, try this out. You expressed it a lot better than I did, and the local airport is also a great idea on more than one level. In addition to the projects in work, some of the pilots may have experience with aircraft having the same 'optomizations' that a would-be designer is considering--their advice will be opinionated, and will also give a preview of some limitations. (A frequent example is that canard designs are very forgiving in flight; but like lots of runway, and pushers like it paved... ) I am not saying anything bad about that chapter, or the EAA, but I need a little more guidance. I am looking at cost verses weight & stength. Any words of advice besides "Join EAA"? If you join EAA the members area of their website has a great deal of articles. It may take you literally a few days to read through everything. Also, check out the matronics website: http://www.matronics.com/emaillists/ It hosts several email lists, and you should find at least one or two (probably more) to be very suitable to your purpose. Those lists are also archived on that website, so even without subscribing to any of the lists you have a few more good days of solid reading. Keep looking online- try an archives search for this newsgroup. Google search things like "homebuilt composite design construction," I bet you'll find some personal websites with detailed construction logs. Even the Aircraft Spruce catalog has a few pages of general info on each major construction method. Uh, that's just off the top of my head. ![]() |
Jet Ranger Operating Costs? | greenwavepilot | Owning | 5 | February 3rd 05 03:31 PM |
The frustrating economics of aviation | C J Campbell | Piloting | 96 | July 21st 04 04:41 PM |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
Lockheed's JSF Costs to Rise $45 Billion | Henry J Cobb | Military Aviation | 3 | April 6th 04 09:33 PM |
Defining Composites (long) | B Lacovara | Soaring | 1 | September 13th 03 08:04 PM |
