Can someone suggest a low-current, light-weight, inexpensive 12 volt fan to
use in the defrost branch of the cabin heat line for clearing up a windscreen while still on the ground, when ram air from the prop may not amount to much? thanks |
![]() "John S" wrote in message ink.net... Can someone suggest a low-current, light-weight, inexpensive 12 volt fan to use in the defrost branch of the cabin heat line for clearing up a windscreen while still on the ground, when ram air from the prop may not amount to much? thanks Scrounge through some dead computers. Some of the muffin fans are about the size of a scat tube, and put out a substantial amount of wind. They also happen to be 12 volt DC. -- Jim in NC |
On Thu, 24 Mar 2005 03:16:11 GMT, "John S"
wrote: Can someone suggest a low-current, light-weight, inexpensive 12 volt fan to use in the defrost branch of the cabin heat line for clearing up a windscreen while still on the ground, when ram air from the prop may not amount to much? thanks Many hair driers have 12 volt dc blowers in them. I used a pair of them in my electrified Fiat 128 for defrosters. Used another one for a motor cooling fan. When I scrapped the fiat I saved one of them and used it for blowing up an air-bed for camping. |
Or try your local car wreckers. The heater fans are quite powerfull in many
models and run quite happily on 12 volts with hot air as well. Hope this helps, Peter wrote in message ... On Thu, 24 Mar 2005 03:16:11 GMT, "John S" wrote: Can someone suggest a low-current, light-weight, inexpensive 12 volt fan to use in the defrost branch of the cabin heat line for clearing up a windscreen while still on the ground, when ram air from the prop may not amount to much? thanks Many hair driers have 12 volt dc blowers in them. I used a pair of them in my electrified Fiat 128 for defrosters. Used another one for a motor cooling fan. When I scrapped the fiat I saved one of them and used it for blowing up an air-bed for camping. |
On Fri, 25 Mar 2005 11:04:23 -0500, Bryan Martin
wrote: They're also quite heavy and way over powered for this application. A small computer fan would do the job nicely for way less weight and electrical load. Not to mention the fans are virtually ALL built into the heater assembly, and being squirel cages, are useless outside the case. in article , Bushy Pete at wrote on 3/25/05 7:56 AM: Or try your local car wreckers. The heater fans are quite powerfull in many models and run quite happily on 12 volts with hot air as well. Hope this helps, Peter wrote in message ... On Thu, 24 Mar 2005 03:16:11 GMT, "John S" wrote: Can someone suggest a low-current, light-weight, inexpensive 12 volt fan to use in the defrost branch of the cabin heat line for clearing up a windscreen while still on the ground, when ram air from the prop may not amount to much? thanks |
Constant Speed Prop vs Variable Engine Timing | Jay | Home Built | 44 | March 3rd 04 10:08 PM |
Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) | Peter Stickney | Military Aviation | 45 | February 11th 04 04:46 AM |
High Altitude operations (Turbo charge???) | Andre | Home Built | 68 | July 11th 03 11:59 PM |
