Fuel leakage during in-flight refueling
Old March 24th 05, 01:48 AM
mark johnston
Default Fuel leakage during in-flight refueling
When refueling using the probe and drogue system, is it commonplace to have
fuel leakage from the drogue? At my day job, we have a foreign customer
asking about the resistance of an engine to fuel ingestion during refueling.
Apparently it is something of a problem for them, but they have not been
able to give us any specifics.
I thought someone here may have some real world experience they could share.
Do you get a brief mist of fuel when you disconnect? ... or can you
experience an continual "dribble" down the probe during the transfer? Any
info or war stories would be helpful.
Regards,
Mark Johnston
Old March 24th 05, 07:02 AM
As far as I saw this on a sort of film that is a mist, indeed. Bear in
mind the fact that in many planes the refueling probe is often quite
distant from the jet intake.
Any dumped fuel seemingly turns into mist as well.
One story I've heard from civil aviation: it happened probably in
France in the 1980s, when a passenger jet exploded after unluckily
coming into the cloud of fuel it dumped one lap before.
In Britain in WWII there was a weird idea to spray fuel in the air, to
make V-1 missile engines suck it, fly longer than expected, and then
overfly their targets.
Best regards,
Jacek
Old March 24th 05, 02:24 PM
Phormer Phighter Phlyer
Regards,
Mark Johnston
May get a wee bit when you pull out but no leakage when refueling.
Old March 24th 05, 05:36 PM
John
I am stretching here, but I seem to recall this is the reason that the
AAR probe on the A-4 Skyhawk was revised from a straight design to one
that incorporated a "dog leg." If I recall correctly, when the
Scooter backed away from the basket, a valve in the end of the probe
would sometimes allow a puff of fuel to escape. In the original
straight design, the puff would then be promptly ingested down the
starboard engine intake. This occasionally would do bad things to the
engine and create a bad day for the pilot. The "dog leg" design
moved the path of the fuel puff far enough away from the inlet to
prevent ingestion.
If I am wrong, I hope someone will correct me on this.
Blue skies . . .
Old March 24th 05, 06:04 PM
Ed Rasimus
prevent ingestion.
Blue skies . . .
Never tried to put my broad butt in a Scooter, but other aircraft with
the dog leg in the probe, such as the F-100, did it to move the
refueling point into quieter air out of boundary layer or to improve
pilot visibility for hook up.
The very small amount of fuel that sprayed at disconnect either from a
drogue or off the boom from a receptacle surely wouldn't do much to an
engine under normal conditions. In the F-105, the spray of mist would
fog the windscreen and then blow off in two seconds. Any fuel that
went down the intake could be sniffed in a second or two as it came
through the pressurization system--which is why the checklist for
refueling specified 100% oxygen.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
www.thunderchief.org
www.thundertales.blogspot.com
Old March 24th 05, 06:18 PM
John
I knew I was on thinning ice, but at least I know that being shot down
by Ed means I have been shot down by one of the better ones.
I just found this at http://www.skyhawk.org/2C/productionhistory.htm
regarding design changes to the A-4F.
"A unique recognition feature that first appeared on the A-4F was the
"bent" aerial fueling probe. The probe was so configured to preclude
electronic inteference with the wide-angle target acquisition
system."
Also found this at http://www.airtoaircombat.com/detail.asp?id=57 :
"The A-4M was fitted with a revised refuelling probe which canted out
to starboard to precent interference with a wider-angle target
acquisition system."
Now that Ed has thrown the thrid strike, it is time for me to head back
to the dug-out and resume lurking. (Smiling)
blue skies . . .
P.S. to Mr Rasimus - Is the new book actually out yet (fingers
crossed)?
Old March 25th 05, 01:44 AM
Sparerep
On 24 Mar 2005 10:18:18 -0800, "John"
system."
blue skies . . .
crossed)?
Don't be too hasty, John.
It is true that the off-set probe was installed as part of
AFC 461, titled Avionics; AN/APS 117 Shrike Target
Identification Acquisition System and it's also true that it
was installed because the straight probe interfered with the
sensor operation.
However, it was also found to prevent fuel vapor
ingestion/explosion when the coupling leaked during
in-flight refueling. A second part to the AFC (Part 2) was
issued a couple of years later to authorize off-set probe
installation on all aircraft not covered under the original
AFC. The part 2 title was changed to Fuselage; Offset IFR
Probe Installation and TIAS, Provisions For. That's why
some TA-4s had the off set probe. The original AFC was for
"designated" A-4Es and Fs.
I remember reading through A-4 accident summaries a few
years ago and it seemed that the USN/USMC lost and average
of a plane a year to fuel vapor ingestion during IFR.
In May 83 NAVAIRSYSCOM message 260109Z, all A-4 aircraft not
equipped with the off-set probe (AFC-461) were restricted
from aerial refueling from KC-135 aircraft equipped with the
boom to drogue adapter with the exception of operational
necessity.
The restriction was in response the loss of a TA-4J due to
the leaking/ingestion problem and several more reports that
it occurred. I don't remember that restriction ever being
lifted.
Tom Debski
Old March 25th 05, 02:26 AM
John Weiss
"John" wrote...
All too true! In the later years of the Scooter, inflight refueling was
prohibited with the straight probe.
Old March 25th 05, 12:26 PM
Doug \Woody\ and Erin Beal
On 3/24/05 8:24 AM, in article
1111674154.81566ae09bb49e973412b142c168a8e4@terane ws, "Phormer Phighter
Regards,
Mark Johnston
I disagree.
About 20% of the time (anecdotally) I've seen leakage from USAF tankers
(KC-135, KC-10 whether on the MIPR, WOPR, or iron maiden) during refueling.
My guess would be due to higher pressure. The puff during back out happens
nearly all the time though on Navy or USAF tankers.
It is VERY uncommon for that leakage to become a problem. Misting fuel will
smudge the canopy a bit though.
There was a Tomcat circa 1997 from VF-211, however, that during a severe
leak from the drogue ended up ingesting quite a bit of fuel down one motor
and landing at NAS Fort Worth. That jet's still at NAS FW, by the way.
--Woody
Old March 25th 05, 01:20 PM
Red Rider
"Doug "Woody" and Erin Beal" wrote in message
snip, snip, snip,
will
snip, snip, snip,
--Woody
Had hydraulics' go bad on launch once. With other things on my mind, I just
dumped excess fuel. Next liberty port I had to avoid a destroyer crew who
wanted to tell me that dumped fuel doesn't just disappear in a mist. They
were lucky I had already dumped the ordnance on them. grin
Red
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
